AC Thermostat Kit Install - Page 2 - LotusTalk - The Lotus Cars Community
 1Likes
post #21 of 31 (permalink) Old 07-20-2012, 06:15 AM
Arch. Project Manager
surferpkt's Avatar
Mine used to freeze up with in minutes down here in hot/humid Florida until I adjusted the sensor to be closer to the evaporator coil that was freezing up. I believe it was 1/8th to 1/4" off of the coil. I adjusted it to be more like a 1/16th of an inch off the coil, not touching though, and have not had a problem in over 4 years.
Cheers
"This car is more fun than the entire french air force crashing into a firework factory." - Jeremy Clarkson
2005 BRP ELISE:
Sport Pack, Hard Top, Black Mesh Grills, Cup Air Box, TitanQR, Difflow diffuser, Larini Club Sport Exaust, Rear Panel Delete, RTD Brace w/Nitron Toe Pins, Mono-ball bushings, PRORAD, Reverie CF Side Scoops & CF Splitter, CF door pulls, Odyssey PC680. Filled seams including a custom one piece front paint protection film.
surferpkt is offline
post #22 of 31 (permalink) Old 07-22-2012, 06:38 AM
Shawn C's Avatar
I have a small snag, Any Idea where this black plug goes? The system seems to work without it but I have no idea where it goes...
http://www.youtube.com/jerusdc
BOE TVS
Shawn C is offline
post #23 of 31 (permalink) Old 07-22-2012, 07:01 AM
SirLotus's Avatar
I think that connector may go to the temperature actuator. Just in case you did not get these instructions.
SirLotus is offline
post #24 of 31 (permalink) Old 07-22-2012, 11:09 AM
Shawn C's Avatar
Got it! Thanks
BOE TVS
Shawn C is offline
post #25 of 31 (permalink) Old 07-22-2012, 11:16 AM
So my '09 Elise has recently begun displaying the same problem. Works fine for 10-15 minutes, then drop in airflow and increase in temperature. Shut off AX for 20-30 seconds, air flow increases substantially, turn on AC nice and cold. Given that it's a 2009, I'm assuming I have the newer thermostat, so perhaps relocating the sensor is the next thing to try, if I confirm thermostat is good (I guess it could be the electronic version, but have gone bad).
Dylan is offline
post #26 of 31 (permalink) Old 07-22-2012, 01:17 PM
SirLotus's Avatar
Your car has the upgraded electronic thermostat and should not exhibit the symptoms you describe.. I would suggest, firstly, to make sure the sensor (thermistor) is positioned as per the instructions I posted above. Then I would check all of the connections and if all is OK then maybe you do have a defective unit.
SirLotus is offline
post #27 of 31 (permalink) Old 08-08-2012, 01:58 PM
Stale_Hotdog's Avatar
My January 08 build 08 Exige s240's AC was exibiting the lack of airflow symptoms. Even though I kept complaining to the 3 different dealers (two of them no longer exist) they swore up and down that . (Probably because they know it's a clam off repair (for the Exige) and lotus obviously doesn't want to foot the bill.) I tried to get them to install a new AC thermostat but luck was on their side and my warranty expired. Since owning the car i've realized that lotus uses old parts even when there are TSB's or recalls to install new parts months to years before. Anyway, while upgrading the oil cooler lines I took the opportunity to replace the AC thermostat. I do indeed have an electronic thermostat and the probe was installed in the correct orientation but the part numbers (65265) did not match the new part. There were also a few slight differences in the connectors as well.
Finally, the AC works great now and consistently flows cold air! I no longer have to turn off the AC every 15 minutes to let the condenser thaw out.
Stale_Hotdog is offline
post #28 of 31 (permalink) Old 08-08-2012, 02:26 PM
SirLotus's Avatar
Glad it is finally working fine for you.
SirLotus is offline
post #29 of 31 (permalink) Old 03-01-2015, 09:47 PM
Does ANYONE know if the Electronic Sensor is compatible with the 2002 Lotus.
Latest shape - Rover Motor. It seems to look the same as your pics above.
Thanks in advance.
Supa is offline
post #30 of 31 (permalink) Old 03-26-2016, 02:38 PM
CALtd's Avatar
Thanks HocusLotus for pictures and commentary. I never would have been able to do the update without them. Took longer than 1.5 hours but much of that was because of Tony Wa's coolant modification.
2005 Elise was updated without taking Clam Off.
CALtd is offline
post #31 of 31 (permalink) Old 04-27-2019, 06:14 AM
yellowlotus's Avatar
is the new switch a Denso part?any way to cross reference the part?A120P0149S
05' US Elise.240hp,HRM edition,Sport pack,Touring pack,Katana supercharged,starshield,custom painted engine covers,S111 boomerang rear hook, Hurricane air filter,2bular 6" exhaust,Lotus driving lights,Infinity speakers,Lid Bone,V1 radar with remote audio/display,Tesla Roadster double din conversion with Kenwood ddx9902 headunit-subwoofer-rear cam,TRmotorsports wheels,lightweight Braille battery,aluminum radiator,silicon hoses,alotaluv....
yellowlotus is offline
