Another Air Conditioning question - LotusTalk - The Lotus Cars Community
post #1 of 8 (permalink) Old 08-07-2018, 09:45 PM Thread Starter
not-a-number's Avatar
Just bought an 05 Elise with no aircon.
50 Psi pressure (on a refill kit gauge, have a better low and high pressure gauge coming)
Pump clicks and rpm changes
It will go from ambient to hot (implying the vent is moving)
Turning the aircon though stays ambient
Question is. If it is at 50 psi does that mean Im good for refrigerant?
If its going from ambient to hot does that mean the flap is moving?
I havnt added any refrigerant yet.
Sorry to ask the same old question but I havnt found the same situation through search.
not-a-number is offline
post #2 of 8 (permalink) Old 08-08-2018, 03:52 AM
What does it read when the AC is off? In hot weather it would be higher than that
50 PSI at idle would not be unusual, but it should drop as you rev it up to something in the 30's or 20s
You do need both gauges to truly knwo what is going on
exigegus is online now
post #3 of 8 (permalink) Old 08-08-2018, 05:14 AM
lotus72Eur's Avatar
If the low side is reading 50 with the car running and the ac compressor engaged you most likely are over charged. First I would make sure that the compressor is engaging. Look at the compressor to ensure that it is turning. Not just the outer ring but the inner ring. If not it might be a bad compressor clutch. Dual gauges are you best tool to find the problem.
"It always seems to be something!"
lotus72Eur is offline
post #4 of 8 (permalink) Old 08-08-2018, 06:01 AM Thread Starter
With engine off, 50psi. With engine at idle, 50psi. I didnt go above idle.
Ill try it again once I have the dual gauges.
The rpm changes as expected when engaged. Speeds up when disengage etc. Ill try physically see it.
Can a system go from being correctly charged (or atleast working) to being over charged by itself?
post #5 of 8 (permalink) Old 08-08-2018, 06:39 AM
50 psi static pressure is low, it should be more like 80 when not running at ~75 degrees.
your idle goes up, but your compressor is probably not running
post #6 of 8 (permalink) Old 08-08-2018, 07:03 PM Thread Starter
Can the compressor clutch be engaged and the pump be 'running' but not actually pumping? Even if it has refrigerant?
Do you know what the factory quantity and pressure should be?
post #7 of 8 (permalink) Old 08-09-2018, 04:14 AM
Weight is in the shop manual
something like 22 ounces
there is no factory pressure.
Like I said 50 psi is low for static pressure, which depends on ambient temp.
You need to rev it up to 2000 rpm or so to see if the pressure drops from compressor function
If you are not comfortable, bring it to a shop
post #8 of 8 (permalink) Old 08-10-2018, 05:10 AM
Patiotray's Avatar
Also, flap may move to heat but get stuck moving to AC. My car had this issue when I bought it. Spent a lot of time and money recharging system only to learn flap was problem all along.
"It corners like a housefly!"
05 Lotus Elise
13 Fiat Abarth
Patiotray is offline
