-   A/C, Heating and Ventilation (https://www.lotustalk.com/forums/f313/)
-   -   Celica AC swap? (https://www.lotustalk.com/forums/f313/celica-ac-swap-310169/)
wek120 06-17-2015 07:27 PM
Celica AC swap?
177 Attachment(s)
Ok so this is probably a longshot, and sorry in advance for making a kind of noob proposal, but since the celica 2zz engine is virtually identical, would using an ac pump from a celica (or maybe even the whole system) work by any chance?
LiveToDrive 06-18-2015 08:56 AM
Yes the Celica compressor will work, it's been done several times. The only difference is it has a larger pulley, but from what I've read it works just as well. If anything this is a good thing as it spins the compressor slightly slower which is easier on the pump and the engine.
wek120 06-18-2015 10:32 AM
177 Attachment(s)
So that being the case could you ramp up the pressure a bit more then to compensate?
LiveToDrive 06-18-2015 11:30 AM
If you dig through this section I'm sure you'll find some of the threads on the Toyota Compressor. Everyone who did it says the AC is perfectly cold with a normal charge. It's what I'll probably try next myself. Getting to that compressor is a bitch though.
