DIY Blower Motor Resistor Pack Replacement - Page 9 - LotusTalk - The Lotus Cars Community
 1Likes
post #161 of 169 (permalink) Old 05-07-2016, 06:22 PM
Saffron Yellow is Lighter
XtinctElise's Avatar
I would try hot-wiring it directly without the resistor pack and see if the blower motor functions properly
XtinctElise is offline
post #162 of 169 (permalink) Old 05-08-2016, 04:20 PM
thats just the thing though, it was working when i took it apart. so everything works..... just intermittently. could this be a switch issue? even when the blower is not working and the switch is on, I am able to cycle the AC button, making me think that the switch is fine and the issue was down stream some where. but all the blower parts look to be in excellent condition. at a bit of a loss here.
miketurbo is offline
post #163 of 169 (permalink) Old 05-12-2016, 09:25 PM
JvegasExige's Avatar
I wasn't able to find the 0.5 ohm so I did some searching and found the resistor pack for $65 on elise parts. Everyone else was asking $150 and up for it. Here's the link if anyone is interested.https://www.eliseparts.com/products/...-speed-module/
JvegasExige is offline
post #164 of 169 (permalink) Old 06-29-2016, 05:54 AM
GPA
GPA's Avatar
Regarding the Resistor Pack Upgrade and Troubleshooting this issue.....
I have a 2005 Elise.
My Blower Fan is not working on ANY speed. Reading this thread, I see Sir Lotus states that "fan speed #3 is a direct path to the blower motor (does not go through Resistor Pack)." Does this mean that if fan speed #3 is not working, then the problem cannot be the Resistor Pack??
Any input appreciated.....
Greg
GPA is offline
post #165 of 169 (permalink) Old 06-29-2016, 06:22 AM
No, while we call it a resistor issue, it is really a connector issue, and the main connector to the resistor pack will burn up leaving no fan at all
Check fuses etc, but it is most likely the resistor pack
you can access the wiring through the access panels and check if there is voltage to the wires going to the resistor pack. If it has voltage there, she must come apart
exigeg2 is offline
post #166 of 169 (permalink) Old 08-01-2016, 11:40 AM
where is the resistor pack
Before I tear the whole car apart, my 2007 was built in April 2007. Is the resistor pack under the blower motor. These wires look like they go to the blower motor, haven't had a chance to chase them the other direction, but any help on where they lead to if they do go to a relocated resistor pack would be great.
Thanks,
speedycar is offline
post #167 of 169 (permalink) Old 08-01-2016, 12:28 PM
looks like the connector type for the evaporator thermostat. The fan wires go through a rectangular black plug. Chase where they come from
exigegus is offline
post #168 of 169 (permalink) Old 12-15-2016, 06:29 PM
This is one job I will be glad to never do again.
Added 2 feet of cable to the direct motor lines. Will run them up toward the fuse area beneath the upper clam. Just wired for 1 speed now, I can come back and add the aftermarket resistors easily this way though if I want to.
Reach is offline
post #169 of 169 (permalink) Old 03-22-2017, 07:11 AM
Originally Posted by SirLotus View Post
Just for information, it is not usually the resistors that go bad, but rather the terminals that corrode.
Additionally, there is a method to bypass the resistor pack with a little cutting, and the clam is not removed.
How do you do this?
T.Lund is offline
