ELISE AIR CONDITIONING - Page 3 - LotusTalk - The Lotus Cars Community
post #41 of 55 (permalink) Old 07-25-2008, 06:09 AM
CosmosMpower's Avatar
Get ready to sweat. I've been driving mine around with no a/c in the 100 degree heat this whole week.
CosmosMpower is offline
post #42 of 55 (permalink) Old 07-25-2008, 06:18 AM
Kaliuzhkin's Avatar
FWIW, my observations on heat build up.
As warm as the cockpit gets with the engine running and a/c on, when I turn off the engine (and a/c) it gets hot almost immediately. I'm talking about seconds.
In fact, heat builds up even with the top off. Its odd to run the a/c while the top is off and the windows are down, but that's the way it is.
Dan
Kaliuzhkin is offline
post #43 of 55 (permalink) Old 07-25-2008, 06:54 AM
So do you apply the clear 3m crystaline tint to the front windshield and if so on the outside or inside?
Harponian is offline
post #44 of 55 (permalink) Old 07-25-2008, 06:58 AM
SirLotus's Avatar
Yes, front windshield, it is the largest source of solar I/R heat and it is applied to the inside. Not too many installers will attempt the windshield, especially on this car.
SirLotus is offline
post #45 of 55 (permalink) Old 06-30-2009, 05:51 PM
I had to sell my Elise because I couldn't tolerate the poor AC performance. I didn't even live in that hot a climate but I still wound up having to park it most of the summer. If lotus upgrades the AC I would consider buying another one...
Joetz is offline
post #46 of 55 (permalink) Old 07-17-2010, 09:01 AM
muziksnger's Avatar
Hi,
To answer the question if the A/C is up to task for Florida heat I would have to say no....here is why...
I live in Melbourne, Cocoa Beach Fl a few hours north of you and the ONLY thing that I don't like about my lotus IS the air conditioner. My most miserable times are the summer for driving my car. The a/c system does blow cold for a little while but if your in stop and go traffic and want to stay cool it won't happen. The A/C air starts to get warm and to get cooled off I have to close all vents but the ones on the drivers side to get any air circulation. I have test drove other Lotus Elise's at the dealer just to see if it was just my car but they all do the same thing. I am new to the forum but I understand there are some things you can do to get better air flow and make it cooler that I am learning myself. If your looking to purchase a Lotus I would make sure you also take a good test drive in stop and go traffic. I use my car as a daily driver and I have never had any mechanical issues. I just keep up on the service's and the car drives just like it was new everyday. You almost have to make a decision if you want A/C as a priority or the driving experience:-)
muziksnger is offline
post #47 of 55 (permalink) Old 07-17-2010, 01:37 PM
Gregbj8's Avatar
Do The Viper mods! I drove my 2005 Elise today, two up, in 95 degree Central Florida heat, for over an hour with no real issues. Granted it is not cold but the cabin is just comfortable. The mods do work.
Gregbj8 is offline
post #48 of 55 (permalink) Old 07-17-2010, 02:45 PM
SirLotus's Avatar
And here they are Improved AC
SirLotus is offline
post #49 of 55 (permalink) Old 07-17-2010, 08:51 PM
xxxotic's Avatar
To get better airflow take off the metal covers by the footwells. It makes a big difference. Before level 3 was like level 1 in a normal car, and you could barely tell the difference between position 1 and postion 3.
I drive from New Smyrna to Palm Beach Gardens a lot and after doing the outer insulation and tonywas heater bypass, I've started getting cold after about half an hour, when the outside temperature was around 90. At first I thought the heater bypass didnt make a difference, but now I am noticing that it helps make it a few degrees cooler.
muziksnger, if your car is a 05, check to make sure that the a/c temperature probe is in the correct location. Early cars needed to have them moved so they wouldnt freeze up.
xxxotic is offline
post #50 of 55 (permalink) Old 08-07-2015, 11:03 AM
Saffron Yellow is Lighter
XtinctElise's Avatar
Arrow Keep Recirculated Air always ON
Rather than start a new thread on the same topic I thought I would ask here.
Has anyone tried to tweak the AC/Heater controls to keep the Recirculated Air always on? Either physically or electronically? I hate how both the recirculate and A/C buttons turn off each time with the car and do not retain their previous states.
XtinctElise is offline
post #51 of 55 (permalink) Old 08-08-2015, 08:07 AM
Such moderate
Doge's Avatar
Yes, covering up the outside air ducts behind the grill pretty much makes it on recirc all the time.
See here:
https://www.lotustalk.com/forums/f313...-system-71031/
Doge is offline
post #52 of 55 (permalink) Old 08-08-2015, 11:16 AM
See here:
Yes, I have done that and realize that the air will come from inside then, however if the electronic recirculation button is not engaged, then the flow may be decreased slightly. So I was curious if anyone has a way to keep it on permanently.
Thanks for the reply.
post #53 of 55 (permalink) Old 08-10-2015, 08:00 AM
Such moderate
Doge's Avatar
From 06 and up, I believe it come back on if it was on when you turned the car off. It "remembers" that it was on when you turn the car back on. Same with the actual a/c switch. It doesn't do this on 2005's, I kind of wonder if it is the switch pack module that does this and if we could install one from a 2006. But IMO, I don't think the cost would be worth it. I'd rather just reach down and press the button.
Doge is offline
post #54 of 55 (permalink) Old 08-10-2015, 08:06 AM
Thanks for the info, I did not realize they changed that in 06. If anyone could test that out, I would love to make that mod!
post #55 of 55 (permalink) Old 08-10-2015, 08:49 AM
Such moderate
Doge's Avatar
Doge is offline
