Exige AC Blower not working, But compressor is? - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 05-10-2016, 03:35 PM Thread Starter
JvegasExige's Avatar
Hello,
I know their is countless threads on this topic, but I wanted to get some opinions from people who may have had the same problem. My AC in my 2009 Exige stopped working. If i turn on the AC button you can hear the compressor kick on, but I get no airflow through the vents. It sounds like it could be the blower motor since i'm getting no airflow at all. How much does this cost and could I do it myself? Any advice? Thanks everyone!
Jonathon
JvegasExige is offline
post #2 of 4 (permalink) Old 05-11-2016, 08:25 AM
Such moderate
Doge's Avatar
This would most likely be your issue:
https://www.lotustalk.com/forums/f313...acement-78524/
Doge is offline
post #3 of 4 (permalink) Old 05-11-2016, 08:35 AM
cyow5's Avatar
While the resistor pack is a common issue and very likely, there are other (cheaper, easier) possibilities to check first. The simplest is that the hose connecting the blower housing to the distribution plenum is loose (mine has done that). The blower motor also has all the current pass through the control panel knob, so see if there are any visible signs (burned wire, loose wire, etc). You might also be able check the resistance to ground here for the three outputs (high speed has no resistance except for the motor, and medium and low speed are increasing resistance). Since you have the motor inline, this will only work if the motor parked in just the right way, so it may read open for all three whether or not there is a problem, but if you get reasonable resistances then that rules out the resistor pack.
cyow5 is offline
post #4 of 4 (permalink) Old 05-11-2016, 12:44 PM Thread Starter
Perfect Thanks guys!
