no air coming from vents - LotusTalk - The Lotus Cars Community
 1Likes
post #1 of 23 (permalink) Old 03-06-2016, 11:57 AM Thread Starter
I was going to recharge my ac today but it decided not to blow air out of the vents so I couldn't turn on the ac. I have had them on before but they only work when they feel like it. Any ideas on what the issue could be. I need ac!
Jos3torr3s is offline
post #2 of 23 (permalink) Old 03-06-2016, 11:58 AM
because racecar
dallasreed's Avatar
Resistor pack
dallasreed is offline
post #3 of 23 (permalink) Old 03-06-2016, 12:15 PM
Gunpilot's Avatar
Resistor Pack.
2012 Evora 2+0 IPS.
2007 Exige mental track toy.
2005 Elise.
1982 Brunette.
"CHARLIE DON'T SURF"
Gunpilot is offline
post #4 of 23 (permalink) Old 03-06-2016, 12:18 PM Thread Starter
Ugh so much work for such a small item. So clam has to come off?
post #5 of 23 (permalink) Old 03-06-2016, 12:25 PM
TachItUp's Avatar
Yep. While you're in there replace the stock radiator with an all aluminum unit. Buy once and cry once.
TachItUp is offline
post #6 of 23 (permalink) Old 03-06-2016, 12:28 PM Thread Starter
Thanks for the help guy's wish it would be easier to access but it is what it is
post #7 of 23 (permalink) Old 03-06-2016, 12:35 PM
cyow5's Avatar
That is a common problem, but there are other problems given your vague description. Does it whirr and just no blow? Or does the fan not work at all at any position? Have you tried changing the direction to face level, feet, or defrost?
glb likes this.
cyow5 is online now
post #8 of 23 (permalink) Old 03-06-2016, 03:28 PM Thread Starter
It doesn't work no matter what I do. Change the fan speed or press any other button no noise at all nothing happens
post #9 of 23 (permalink) Old 03-06-2016, 03:35 PM
yup fan resistors
exigegus is online now
post #10 of 23 (permalink) Old 03-06-2016, 04:03 PM
cyow5's Avatar
Originally Posted by exigegus View Post
yup fan resistors
Wouldn't max speed still work? I'm thinking the ducting us simply loose between the fan and diverter
cyow5 is online now
post #11 of 23 (permalink) Old 03-06-2016, 04:07 PM
Gunpilot's Avatar
You can check, after you pull the clam off. See the red duct?
2012 Evora 2+0 IPS.
2005 Elise.
1982 Brunette.
Gunpilot is offline
post #12 of 23 (permalink) Old 03-06-2016, 04:12 PM
cyow5's Avatar
You don't even have to pull the clam to check it - I had mine come loose once and panicked at first, too. Again, I'm basing this off my understanding that max speed still works since the failed resistors only affect reducing the speeds. I see how corrosion there could kill the whole though, but that duct is too easy to check first to ignore
cyow5 is online now
post #13 of 23 (permalink) Old 03-06-2016, 04:42 PM
actually it is referred to the resistors failing but it seems usually it is the terminals on the resistor housing that fail, so, no fan
post #14 of 23 (permalink) Old 03-06-2016, 05:47 PM
glb
glb's Avatar
You did check the fuse, right?
glb is offline
post #15 of 23 (permalink) Old 03-07-2016, 08:23 AM
Such moderate
Doge's Avatar
First things, first!
No. It's the terminal for power/max speed that usually corrodes off of the resistor, so nothing would work.
Doge is offline
post #16 of 23 (permalink) Old 03-07-2016, 08:34 AM
@Jos3torr3s where are you located? I just recently had to do this on my car and it was the resistor pack that had failed. If you are in the northern va area I could assist with clam removal if you want.
06 Elise is offline
post #17 of 23 (permalink) Old 03-07-2016, 09:49 AM Thread Starter
Thank you for the offer but I am in bakersfield california
post #18 of 23 (permalink) Old 03-07-2016, 09:50 AM Thread Starter
I will check the fuse later today but would it be the fuse if today the fan worked again? It only works when it wants to. Also which fuse is it
post #19 of 23 (permalink) Old 03-07-2016, 10:00 AM
pretty sure you need to check the cabin fuses, which should be under the passenger side tray, which is under the airbag. You should see a harness there. I'm not sure which fuse. If it is cutting in and out of working this was my key indication that it was in fact my resistor pack that was going bad.
06 Elise is offline
post #20 of 23 (permalink) Old 03-07-2016, 10:01 AM
06 Elise is offline
