no air coming from vents - Page 2 - LotusTalk - The Lotus Cars Community
 1Likes
post #21 of 23 (permalink) Old 03-07-2016, 10:07 AM
pretty sure you need to check c1
06 Elise is offline
post #22 of 23 (permalink) Old 03-07-2016, 10:38 AM Thread Starter
Originally Posted by 06 Elise View Post
pretty sure you need to check the cabin fuses, which should be under the passenger side tray, which is under the airbag. You should see a harness there. I'm not sure which fuse. If it is cutting in and out of working this was my key indication that it was in fact my resistor pack that was going bad.
Makes sense,I will check it out after work thank you for taking the time to look that up
Jos3torr3s is offline
post #23 of 23 (permalink) Old 03-08-2016, 08:32 AM
Such moderate
Doge's Avatar
If it started working again, then it is most likely the resistor. The terminal is making contact sometimes, and sometimes it isn't.
Doge is offline
