-   A/C, Heating and Ventilation (https://www.lotustalk.com/forums/f313/)
-   -   No blower when engine is on (https://www.lotustalk.com/forums/f313/no-blower-when-engine-464960/)
Agent_86 12-17-2018 08:55 AM
Apologies in advance if this is a stupid question. I just bought a 2005 Elise with low miles. Everything seemed good with the HVAC and the car passed a full PPI. Now, I can turn the blower on any of the 3 speeds when the engine is off but the key in and on, but with the engine running it doesn't seem to respond to any AC controls. Am I doing something wrong, or is something broken?
Agent_86 12-17-2018 08:57 AM
To clarify, it doesn't respond to any HVAC controls, AC, heat, or anything and none of the lights come for the controls like they do when I can turn the fan on.
exigegus 12-17-2018 09:33 AM
OK so you are being a little fragmented, here
SO, with the key in, but not turned what happens?
with the key turned on, what happens, prior to starting?
With the car running
If the fan works normally in any one of the above conditions, I would suspect either a fuse or some kind of wiring issue.
The recirc light etc is fed from the switch, so were it a resistor issue I would expect the lights to still come on
Agent_86 12-17-2018 11:15 AM
I haven't tried it with the key in, but not turned on.
With the key in and turned on, I am able to turn the knob to any speed and get air as normal, all lights on, performing as expected.
With the car running (engine on), the controls are dead. Turning any of the knobs does nothing, no air blowing, no lights on.
exigegus 12-17-2018 12:17 PM
that is really strange
anything else in the car not work?
I guess the place to start is chase the wiring diagram back to see what fuse that is on and what else it is connected to. See if the fuse has power under the same conditions as the fan functions
check grounding also. weak grounds can make odd things happen
Agent_86 12-17-2018 01:31 PM
No issues with anything else that I'm aware of. I guess it's chasing British electrical gremlins now. Can you point me in the direction of the main grounds to check? Thanks.
Agent_86 02-15-2019 04:16 AM
Update in case this helps anyone figure out what is going on...I was able to track the issue to how far the key is turned vs whether the engine is on or not. The A/C and heat won't work when I turn the key as far as it will go, but if I stop a bit before that, everything works, including the engine. Anyone know a fix? Is it safe to drive just being careful how far I turn the key, or does that sensitivity indicate some sort of potentially dangerous short?
exigegus 02-15-2019 04:44 AM
feels like bad ignition switch, but I am thinking other things should not work
glb 02-15-2019 08:49 AM
Safe?
Turn the engine on and see if jiggling the key a bit turns it off.
If yes, car is not safe.
