Really fast flashing left turn signal - LotusTalk - The Lotus Cars Community
 3Likes
post #1 of 103 (permalink) Old 09-20-2009, 07:21 PM Thread Starter
This is the second day having the car and this happens...
I turn on the car to get some food with a friend. I turn on my headlights and proceed with my drive. I go to use the left turn signal and it's flashing extremely fast. I thought that a light had burnt out causing the turn signal to blink faster. I check all the lights and everything is working. I tried the right turn signal and that's working fine. I turned off my headlights and left turn signal was working as it should. Normal speed. I turn on the headlights again and I does it again! At this point was getting irritated and really hungry so I continued driving. Well About 2 min into the ride the left turn signal worked fine. And it stayed working fine the rest of the drive. I thought, cool it fixed itself. I was wrong. I came back to my car after dinner and it did it again. Turned the car on the headlights on and tried left turn signL. Blinked fast. Too fast. Right turn signal worked good. Turned off the headlights and it was back to normal. Headlights on. Blinks fast. I started driving home. 2 min in, it was back to normal.
Has anyone else had this problem? Is it common? Any threat of something in my car burning up(fuses?)? I'm about a 2 hour drive from the nearest lotus dealership. Would not like to make that drive if this is an easy fix. Any help would be greatly appreciated.
Eric
18 Sept 09: 2009 Lotus Elise Purist Manaco White.
Mileage New: 6
Mileage Current: 20,000+ and going strong
15 Oct 09: Factory Supercharger Kit
22 Oct 09: Janspeed Stage 2
04 Dec 09: K&N Apollo Intake
09EliseMW is offline
post #2 of 103 (permalink) Old 09-20-2009, 07:28 PM
...m...'s Avatar
...it sounds like one of the bulbs has an intermittently bad contact - possibly a loose connection, possibly corrosion...
...85,000 miles and aging beautifully...
...m... is offline
post #3 of 103 (permalink) Old 09-20-2009, 08:48 PM
shay2nak
shay2nak's Avatar
if you have the LED rear lights, then it's the relay. Happened to me 2 times. Now make it 3, I just replaced the passenger side rear taillight and it started flashing fast. Forget it, I'm not taking it in any more. I'll just wait till the drivers side goes bad and I'll have 2 fast flashers.
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #4 of 103 (permalink) Old 09-21-2009, 02:39 AM Thread Starter
Which relay was it? This car is extremely new to me. Still learning everything.
Mileage New: 6
post #5 of 103 (permalink) Old 09-21-2009, 03:32 AM
SirLotus's Avatar
Eric,
The headlights are inducing a voltage drop. Have it fixed under the warranty.
SirLotus is offline
post #6 of 103 (permalink) Old 09-21-2009, 05:15 AM Thread Starter
Originally Posted by TheViper View Post
Eric,
I would like to get it fixed under warranty. But like I said earlier. It's a 2 hour drive to the dealer. Would much rather get it fixed at my house if it's a simple fix. I work on electronics on helicopters so fixing this shouldn't be hard. Just need to know where to start.
Mileage New: 6
post #7 of 103 (permalink) Old 09-21-2009, 05:21 AM
SirLotus's Avatar
I would probably start by testing the resistance of the rear LED's that work, and then compare it against the side that does not operate correctly. Also make sure all the side repeaters are functioning.
SirLotus is offline
post #8 of 103 (permalink) Old 09-21-2009, 07:58 AM Thread Starter
All the lights work. I didn't see anything burnt out. That relay that theviper was talking about sound like it could be the problem.
Mileage New: 6
post #9 of 103 (permalink) Old 09-21-2009, 09:59 AM
SirLotus's Avatar
The relay is ruled out because the flashers work OK on one side and it uses the same relay. Look for a high resistance between the turn signal switch and any light on that defective side.
SirLotus is offline
post #10 of 103 (permalink) Old 09-21-2009, 10:29 AM
OSX Black hat
charliex's Avatar
i have the same problem, supposedly they change out the whole led unit on the bad side.
i'd call a few dealers, its a common enough problem for them to verify whats changed.
Black Exige S / Elan M100. Don't run a smaller pulley without an upgraded fuel pump! http://www.goth.am ecu stuff.. New reflash box coming soon!
charliex is offline
post #11 of 103 (permalink) Old 09-21-2009, 11:32 AM
MulhollandMotors's Avatar
It could be the tail light, but more commonly the turn signal module goes bad. It is a black box attached to the tail light inside the boot. Try swapping them left to right. If the right side starts flashing fast and the left returns to normal you found your problem. Should be covered under warranty no problem.
Mulholland Motorsports -Premium Collision Center specializing in Lotus service and performance upgrades.
8630 West Pico Blvd. Los Angeles, CA 90035
(310)360-0948
www.mulhollandmotorsports.com
MulhollandMotors is offline
post #12 of 103 (permalink) Old 09-21-2009, 03:06 PM Thread Starter
This isn't something that could possibly harm anything is it? Maybe burn up or do something crazy? I'll take it to criswell when I get my first service done. See what they say about the tail light going bad being a common thing.
Mileage New: 6
post #13 of 103 (permalink) Old 09-21-2009, 03:20 PM
SirLotus's Avatar
No, it will do no damage, unless there is a short somewhere, but that seems unlikely, and anyway that is what fuses are for.
SirLotus is offline
post #14 of 103 (permalink) Old 09-21-2009, 04:11 PM Thread Starter
thats good to know. thanks. ill just wait till i go to va this week and take it to criswell...
funny thing is. i drove the car tonight and it didnt do it once. maybe it was just a hickup for that brief amount of time. ill see what happens the rest of the week.
Mileage New: 6
post #15 of 103 (permalink) Old 09-21-2009, 05:29 PM
SirLotus's Avatar
Good luck Eric, let me know if I can be of any further help.
SirLotus is offline
post #16 of 103 (permalink) Old 09-25-2009, 04:22 PM Thread Starter
so i went to the dealership today for my first service. and had them look at the left turn signal. the tech said that i had A led light out(i checked them all before i went in, they all worked). they changed the whole light assembly and also the control module. or something. i cant remember what he said. but it fixed it. and im glad. no more really fast flashing turn signal. it started to get really annoying sitting at a light with the left blinker on. covered under warranty. wouldnt expect it not to be though. thanks everyone for your inputs.
Mileage New: 6
post #17 of 103 (permalink) Old 05-31-2010, 05:03 AM
David Craig's Avatar
Same Problem
Great to find this post.
I have a 2009 Elise and I now have the fast blinking turn signal issue. It was just the left signal at first. Now it seems to be both the left and right signals. I think all of the lights are working.
The fast rate starts as soon as the parking lights are turned on. So with either just the parking lights or with the headlights on as well, the blinking is about three times as fast as normal.
I know exactly what you mean about sitting at a traffic light with the turn signal blinking so fast. You immediately get the feeling that something is about to blow up.
The other day my left rear light fell out into the trunk and I put it back. A few months ago this happened too. But this time the bulb actually disengaged from the connector. The connector fell into the trunk and the blub was lying inside the rear light fixture. Maybe the bulb is just loose now? I'm going to check. I think it is the bulb that turns on when you put the car in reverse.
David Craig is offline
post #18 of 103 (permalink) Old 05-31-2010, 05:24 AM
...ran down to the underground parking just now.
With the lights on, I verified that each of the four circles of LEDs are all on -- none are burnt out.
The white reverse bulb mentioned in the previous post seems unbroken and inserted tightly.
I guess I'll discuss this with the dealer the next time I'm there.
post #19 of 103 (permalink) Old 06-02-2010, 11:45 PM
A line's Avatar
turn signals
I have an 09 also with under 200 miles. First just the left side now both sides. Sometimes they are normal, sometimes not.
figured I would take it in at 600 miles and let the dealer mess with it.
AC didn't work at all last night either???
2009 Lotus Elise White
2008 Nissan Titan--2002 MBZ S430
2008 Aprilia Tuono--2010 Harley Road King
2008 Aprilia RXV 550/KX 250
Tons of mountain bikes
A line is offline
post #20 of 103 (permalink) Old 07-12-2010, 06:29 AM
Dealer fixed
I phoned the Toronto area dealer and mentioned this problem. They said that they knew what it was. A few days later they phoned me to say that they had some parts they could swap.
A few days later I dropped by the dealer and they swapped some cabling in the trunk area. The cabling has some resistors embedded inside and apparantly they were bad. The problem has been resolved. I was only at the dealer for about 10 minutes.
Great service Gentry Lane!
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Electrical > Lighting
