Evora 400: P1613, U0401 - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By xxaarraa
post #1 of 3 (permalink) Old 12-01-2018, 01:13 PM Thread Starter
Hello,
Upon startup today, I got a constant CEL and transmission MIL. Car ran smoothly and shifted normally. Went to autozone and they pulled:
  • P1613: Secondary air injection system driver
  • U0401: Invalid data received from ECM/PCM
They cleared the codes and the transmission MIL went away but CEL remained. So I purchased a better scanner (Innova 3100i) and pulled codes again myself. This time, I pulled:
  • P0174: System too lean (bank 2) - generic stored
  • P0101: Mass or Volume Air Flow Circuit Range / Performance - generic stored
  • P0700: Transmission Control System (MIL request) - generic stored
  • P0174: System too lean (bank 2) - generic permanent
  • U0401: Invalid data received from ECM/PCM - generic permanent
  • P1613: Secondary air injection system driver - generic permanent
I cleared the codes again with the new scanner, and the CEL disappeared and has not reappeared since then.
Any idea what this could be about? I did install a K&N air filter, but that was over 500 miles ago though. Car hasn't skipped a beat and runs great.
xxaarraa is offline
post #2 of 3 (permalink) Old 12-01-2018, 02:42 PM
PLAY-DOH's Avatar
Is it cold where you are? Mine blubbered on start up once and threw a check engine light because it was cold. Cleared the CEL and it never happened again. It was cylinder misfire
2011 Lotus Evora N/A Quartz Silver
PLAY-DOH is offline
post #3 of 3 (permalink) Old 12-02-2018, 12:18 AM Thread Starter
No, Im in Texas and it was mid 60s yesterday when this happened. The "cylinder bank too lean" strikes me as possibly related to the K&N air filter install, though it happened quite a bit after the install.
PLAY-DOH likes this.
xxaarraa is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Powertrain (Engine, Transmission, etc) > Check Engine Codes
