Please help, no power - LotusTalk - The Lotus Cars Community
 3Likes
  • 2 Post By Twaszak!
  • 1 Post By Michoacan
post #1 of 16 (permalink) Old 05-19-2019, 07:00 AM Thread Starter
Michoacan's Avatar
At the track grid, got the thumbs up and the gas pedal gave little acceleration. I was able to drive 40 mph, regardless of gear. Then 1 minute later it went to idle only power. Then it died and now wont start. It sputters only.
I'm still at the track so any ideas would be appreciated.
Michoacan is offline
post #2 of 16 (permalink) Old 05-19-2019, 07:14 AM
not your dad's puns
Turbopun's Avatar
MSR Houston? Any other Lotus drivers about?
That's not a lot to go on, but here's a few ideas that come to mind...
electrics:
  • bad fuse
  • inertia switch
  • bad spark plug
  • bad coil or lead
fuel:
  • fuel pump or filter
  • bad injector
  • bad gas - you did check that right?
Is this an Elige? Throttle or DBW?
because racecar
Turbopun is offline
post #3 of 16 (permalink) Old 05-19-2019, 07:33 AM Thread Starter
Michoacan's Avatar
05 elise.
post #4 of 16 (permalink) Old 05-19-2019, 07:35 AM Thread Starter
Michoacan's Avatar
Yes, msr Houston. The other lotus guys are confounded too.
I drove the car here in the morning. It only acted funny starting from waiting at the grid waiting for session 1.
post #5 of 16 (permalink) Old 05-19-2019, 07:52 AM Thread Starter
Michoacan's Avatar
Resetting battery and inertia switch didnt help.b
post #6 of 16 (permalink) Old 05-19-2019, 12:15 PM Thread Starter
Michoacan's Avatar
Okay, she is dead. Plan is tow to gas head next week.
post #7 of 16 (permalink) Old 05-19-2019, 06:21 PM
Addict
LostPawn's Avatar
Check engine light?
LostPawn is online now
post #8 of 16 (permalink) Old 05-20-2019, 05:26 AM Thread Starter
Michoacan's Avatar
No check engine light even...
post #9 of 16 (permalink) Old 05-20-2019, 06:42 AM
Addict
LostPawn's Avatar
While not a great sign that should help limit a few items as well, the typical items that would give a code. Can you hear the fuel pump? Any fuel leaks? Does it sound normal when cranking?
post #10 of 16 (permalink) Old 05-20-2019, 08:34 AM Thread Starter
Michoacan's Avatar
Sounds normal, no leaks. Heard the fuel priming.
post #11 of 16 (permalink) Old 05-20-2019, 08:47 AM
Lotus Technician
Sounds crazy, but I had 2 similar situations. In one instance, the 3amp fuse in the front fuse box for the immobilizer popped (figured out later it was a wiring harness rub issue in the center console area). Replaced the fuse (2 times) and we got the guy home. The other time, the airbox had a rodent moving in and it had made a nest in the airbox blocking all air flow, cleaned it out and back up and going again.
One other thing to check, off top of my head, is the ground location on the back side of the head attached to the VVL housing (trans side) that is the ground for the injectors and coils.
Last thing to check, one of the race teams I support, had a similar issue at Road Atlanta, it was because the wring to the crank sensor had a broken lead. Could be worth checking, if you have the equipment there to jack the car up.
Best of luck!!
T.J.
Kubera and TachItUp like this.
Twaszak! is offline
post #12 of 16 (permalink) Old 05-22-2019, 08:55 AM Thread Starter
Michoacan's Avatar
Bad fuel pump... runs, but doesnt give fuel.
Twaszak! likes this.
post #13 of 16 (permalink) Old 05-22-2019, 09:08 AM
Race & Pamper
Kubera's Avatar
@Michoacan did you change the fuel pump? Is it ok now?
Kubera is offline
post #14 of 16 (permalink) Old 05-22-2019, 09:09 AM
Thanks for letting us all know.
Bell47king is offline
post #15 of 16 (permalink) Old 05-22-2019, 09:33 AM Thread Starter
Michoacan's Avatar
Going to be a minute, I'm going to take the opportunity to install baffled fuel tank at the same time. I'll update when all is complete and final status.
post #16 of 16 (permalink) Old 05-22-2019, 10:02 AM
Addict
LostPawn's Avatar
I was almost close with a fuel leak... The nice thing about the BOE surge tank is I have a fuel pressure gauge to help troubleshoot.
Glad you found the issue and hope you're back out quickly, at least as quickly as that baffled tank takes to arrive.
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Powertrain (Engine, Transmission, etc) > Engine/Control System Malfunctions
Similar Threads
CLICK CLICK....no start... JUMP...no Start...PLEASE HELP lotuscupcar General Discussion (Lotus related) 22 03-10-2015 10:27 AM
No Power Please Help stozo2011 General Discussion (Lotus related) 3 02-25-2015 07:58 AM
No Power to Fuel Pump & No Spark Please Help 1986lotushci Lotus Esprit 19 09-10-2013 02:51 PM
no power steering... no power brakes... ewalberg Other Cars and Comparisons 11 01-24-2008 09:01 PM
Oh no. No no no no no no no NOES! Sensitive folks, avert your eyes! gotapex Suspension (including wheels, tires, brakes) 21 02-28-2006 04:22 PM
