Oil Line Recall + radiator swap...how much $? - Page 2 - LotusTalk - The Lotus Cars Community
post #21 of 45 (permalink) Old 11-22-2013, 04:31 PM
gray's Avatar
Originally Posted by Rza.I View Post
Thread revival: quote close to $800 in labor for rad swap.
That's less than what I paid.
Drives a Prius (clearly knows nothing about cars).
Lots Of Trouble Usually Serious
Leave Out The Unnecessary Stuff
gray is offline
post #22 of 45 (permalink) Old 11-22-2013, 04:43 PM
Lotus F1's Avatar
Seems a bit high, isn't that like almost 7hrs of labor just for the rad?
Lotus F1 is offline
post #23 of 45 (permalink) Old 11-23-2013, 11:48 PM
spiller's Avatar
Is that figure including removing and replacing the clam?
spiller is offline
post #24 of 45 (permalink) Old 11-26-2013, 11:23 AM
Greg Fannin's Avatar
Two stupid questions:
1. Is there an easy way to find out if your secondhand (or more) 2005 Elise has had the recall service performed?
2. Is there a time limit on when it needs to be done?
Greg Fannin is offline
post #25 of 45 (permalink) Old 12-16-2013, 10:02 AM
I assume they should be able to check the their database and see a log if the recall has been done on it?
I assume that there shouldn't be as it's a safety issue, but I wouldn't wait to find out before it's too late. It cost me $$ when mines blew and left me stranded on the freeway. I would set an appt as soon as possible.
jhentr is offline
post #26 of 45 (permalink) Old 01-27-2014, 05:29 PM
Jack FFR1846's Avatar
Replaced my radiator preventatively. I modified my speedy bleed brake bleeding pressure system to work with the coolant. Filling and getting rid of air was about 2 minutes once I did that.
It sounds to me like the dealers are charging for complete clam removal and replacement with these prices and times quoted. I'm in the process of putting the clam back on and never having done this before, I'm going to be well below 7 hours from start to finish of time working on the car.
I also took a good look at the oil lines and I don't understand why they would remove the clam. They are not difficult to get to, in my opinion.
Jack FFR1846 is offline
post #27 of 45 (permalink) Old 02-03-2014, 08:02 AM
sturgeongeneral's Avatar
Just a word of caution when getting your oil line recall done. Make sure the dealer shimmed the front clam properly! You can tell by fully opening both doors. If not properly adjusted the door will contact the panel in front when opening.
05 Elise
56 VW Dune Buggy
[email protected]
sturgeongeneral is offline
post #28 of 45 (permalink) Old 02-13-2014, 03:58 AM
LHHFMF's Avatar
I know I'm late to this thread but I just came across my invoice as I prepare to sell the car.
Here are is what I was charged for my radiator swap:
Labor $685
Coolant $20.72
O-Ring $1.98
O-Ring $2.08
Total $709.78
LHHFMF is offline
post #29 of 45 (permalink) Old 03-02-2014, 08:53 AM
was this with the clam already off or did it include removal and replacement?
What is a reasonable time and cost for the a/c pack relocate?
bkbw is offline
post #30 of 45 (permalink) Old 03-27-2014, 09:01 PM
Anyone want to sell stock Radiator?
mrvwcastner is offline
post #31 of 45 (permalink) Old 03-27-2014, 09:46 PM
anglophile in exile
Aedo's Avatar
You don't want a stock radiator for anything unless you plan to replace the plastic end tanks with alloy ones (and do it yourself). It is cheaper and MUCH better to get an aftermarket radiator
Aedo is offline
post #32 of 45 (permalink) Old 03-28-2014, 06:00 AM
philethier's Avatar
$200 FOB Saint Paul Minnesota USA
about 12,000 miles on it. Worked perfectly when removed.
2005 Elise Radiator: un álbum de Flickr
Phil Ethier Minnesota USA
2004 Suburban 8.1, Sport Red
2017 Ford Fusion (wife had to stop driving manual due to shoulder problem), Oxford White.
2006 Gulf Stream Conquest Super C
http://www.mnautox.com
philethier is offline
post #33 of 45 (permalink) Old 03-29-2014, 08:07 AM
If you want a perfectly functional stock radiator, PM me, have one sitting in garage, ~18k miles on it, will unload cheap.
Sent from AutoGuide.com App
'05 Elise, LRG/biscuit, LSS, Touring, LSD/TC
'07 Toyota FJ, Voodoo Blue, 6spd manual, FT 4WD
jelgin is offline
post #34 of 45 (permalink) Old 03-30-2014, 10:38 PM
what would be realistic upcharge time for the a/c resistor upgrade kit if you had the radiator out too? What is the preferred radiator - there seems to be a big spread in price?
bkbw is offline
post #35 of 45 (permalink) Old 03-31-2014, 12:58 AM
anglophile in exile
Aedo's Avatar
I'd have thought 6 hours is not unreasonable for an experienced shop.
Everyone has an opinion on this but the bottom line is any of the all alloy radiators are better than the stock item... so if your car is road only go for the lowest cost one as it will be more than sufficient (I paid $500 for mine and bough from Elise Parts but that was three or four years ago).
Aedo is offline
post #36 of 45 (permalink) Old 04-01-2014, 10:25 PM
I am surprised at 6 hours with everything opened up (granted I have not been there...) does anyone have first hand experience???
bkbw is offline
post #37 of 45 (permalink) Old 04-02-2014, 08:17 AM
Supporting Vendor
GatorMS_Service's Avatar
we charge 3.5 hours to do a radiator during recall, and 5.5 hours to do a resistor pack during recall. getting that box out can be a PITA.
T.J.
GatorMS_Service is offline
post #38 of 45 (permalink) Old 04-02-2014, 09:19 AM
T.J.
Having done both of these things before. These seem about right for a shop.
Seriously, my car is small
07 Exige-S, "Landshark"
05 Saffron Yellow "bumbleBee", on to a new owner
Also:
84 930 turbo, 06 WRX Wagon
aschen is offline
post #39 of 45 (permalink) Old 04-03-2014, 10:05 PM
thanks, I am a new owner...do you do both of these while the clam is off or wait for a rad or resistor pack failure? Is it a question of when, not if they fail? What is the common life expectancy of a radiator and resistor pack (and "they last until you get the clam back on" is not a good answer ....even if it is the right one...
bkbw is offline
post #40 of 45 (permalink) Old 04-05-2014, 01:25 PM
jroberts86's Avatar
T.J.
Many might call me a hack, or even lazy, but why bother to remove the old resistor pack? unplug the wire connector, plug into the new one and nicely relocate. 10 minute job. The old one comes off later when the clam is removed for some other reason.
Jeff
jroberts86 is offline
