We should report the oil line failures to NHTSA - LotusTalk - The Lotus Cars Community
post #1 of 128 (permalink) Old 10-26-2010, 03:39 PM Thread Starter
bryanf650's Avatar
A couple weeks ago I had my passenger side rear oil line fitting blow out while driving. It soaked the rear tire and sprayed oil everywhere. When I started to look into this on Lotustalk, it became clear that this is a pretty common problem and is clearly a defect in the manufacturing or design of the car. I believe that this is also a safety hazard in that it could cause an engine fire or loss of traction or brake performance.
I think it would be a good idea for all owners that have had this failure to report these incidents to the NHTSA website. It just takes a couple minutes and it may force Lotus to be responsible for this obvious and unsafe defect.
Here is the website Home | Safercar -- National Highway Traffic Safety Administration (NHTSA).
Bryan
bryanf650 is offline
post #2 of 128 (permalink) Old 10-26-2010, 03:57 PM
Uncle Sam's Avatar
Did you report your failure?
Uncle Sam is offline
post #3 of 128 (permalink) Old 10-26-2010, 03:57 PM Thread Starter
bryanf650's Avatar
Yep.
post #4 of 128 (permalink) Old 10-26-2010, 04:07 PM
Uncle Sam's Avatar
I haven't had, and I hope I never have, the oil line failure. Most I have seen reported are the crimps at the coolers up front. Was your failure a crimped connection? I know of the U-joint jerry-rigged above the oil filter, but I haven't heard of the crimping failing at the rear junction, not that I doubt it.
post #5 of 128 (permalink) Old 10-26-2010, 04:20 PM Thread Starter
bryanf650's Avatar
I think it is the same issue. Rob at Deitschwerks said that he has seen them at both ends.
post #6 of 128 (permalink) Old 10-26-2010, 04:26 PM
loki007's Avatar
Is there any way you can post a pic of where it failed? I wonder if it is something we could look for, like the cooling u-tube wearing, or the toe link, or the poor ac, or the...
Sorry it happened, I'm sure the tire and road wasn't the only thing that was covered in brown.
If brute force doesn't work, you're not using enough.
loki007 is offline
post #7 of 128 (permalink) Old 10-26-2010, 04:28 PM
ACE51's Avatar
Apparently this happened to my first car after I sold it to the guy (in Cody, WY). He is not on the forums but since I communicated with him after the sale he said it was a real pain trying to find someone that could (or would) fix it properly.
Is this a problem with 05s only?
SRA Champion 2011 and 2012.
My first Lotus gave me a track disease. Now working with and racing Porsche's
Rennpart.com
ACE51 is offline
post #8 of 128 (permalink) Old 10-26-2010, 04:32 PM Thread Starter
bryanf650's Avatar
Certainly not only 05s. Mine is an 06, but I've seen two different designs of fittings, so it may be limited to a certain manufacturing period.
post #9 of 128 (permalink) Old 10-26-2010, 06:20 PM
lt0302's Avatar
FWIW
when mine blew on a 05, Lotus replaced the engine.........the car had 13k when it went and it was under warranty at the time
[B]05 Lotus Elise REV400, Stage II, BWR TB, OBX header, Moroso Oil Pan, RTD Brace, PRoAlloy Radiator, SS Break Lines, S111 Oil Catch Can, ACT HDC, Carbon Fiber Spliter, GRP Side Scoops, CF side skirts, , S111 front & rear tow hooks, tail lights-LED, Driving lights, Allitech, CF interior, 2010 Exige Spoiler, Lotus shop Seats, RA clam, Light Flywheel, ATI pulley, 2010 Exige Cup mirrors
lt0302 is offline
post #10 of 128 (permalink) Old 10-26-2010, 07:03 PM
discocubizm's Avatar
Just filed a complaint with NHTSA...took about 5 minutes. Had 2 oil line failures on 2 separate occasions. Last one almost caused me to skid off the highway at 75mph.... and the engine was ruined.
2005 Lotus Elise (Arctic Silver) Touring, LSS, Dual Oil Coolers, Stage II exhaust, Fujita Intake, Hardtop
2010 Ford Raptor SVT (Blue Flame Metallic) Stainless Works Exhaust, Roush intake
2005 Lotus Elise (Arctic Silver) Touring, LSS shocks, BWR sway bar, Cup Airbox, Stage II exhaust, QR steering rack - Sold
discocubizm is offline
post #11 of 128 (permalink) Old 10-26-2010, 07:08 PM
Failed at Self Control
Zen Dude's Avatar
I have a late '07 Elise and my blew out on the passenger side about a month ago. What an expensive mess.
- z
07 Lotus Elise Krypton Green Sport Pack, Touring Pack, Cilajet, Stage 2 Exhaust, Pagid Black RS14 brake pads and Motul Brake Fluid, Exige-style side scoops, Other Sector 111 / BWR Accessories
02 Mazda Miata MX-5 SE Blazing Yellow Mica Hard Top, Boss Frog Clearview Roll bar
05 Mazda3 Laser Blue, 2.3L
84 Mazda B2000 SE Pickup White 296,000 miles
Zen Dude is offline
post #12 of 128 (permalink) Old 10-26-2010, 07:58 PM
shay2nak
shay2nak's Avatar
my friend's 07 exige s also blew a line while we parted ways a few months back. Luckily, it happened right as he got on the freeway and pulled over immediately. Dealer was like 10min away and engine was not damaged.
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #13 of 128 (permalink) Old 10-26-2010, 09:49 PM
6i9
6i9's Avatar
Whats the proper preventative maintenance for this? Do we have to remove the front clams?
2005 Magnetic Blue Lotus Exige
Drivetrain: Honda K20A Type R | Innovative Kit | Arqray Ti | SCM Intake/Header | Hondata | proRAD | Setrab | KTuned | V2 Fuel Tank | BOE Swirl
Aero: Exige Clams | Reverie | TWRD GT | Craftsquare | IMRP | BSK | Voltex
Suspension: Penske SA | V2arms | RTDbrace | CE28N | R888 | BOE Floating | Pagid RS14
Interior: Recaro SPG | Willans | WorksBell | Sparco
6i9 is offline
post #14 of 128 (permalink) Old 10-26-2010, 10:14 PM
robains's Avatar
Go with a MoCal oil/water cooler and do away with the entire front oil cooler setup. Lotus Sport sell the oil/water cooler or you can contact these folks Bat Inc. They have everything you need including new sandwich plate.
Stock Lotus has 27 feet of oil cooler lines (yes I did measure the ones I removed, huge weight savings also).
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." - Carl Sagan
robains is offline
post #15 of 128 (permalink) Old 10-27-2010, 06:57 AM
MCdougieFresh's Avatar
So what were the common "symptoms" you guys had once the line failed to know what happened? I.e. What would one be wary of to prompt immediate pull-over to preempt engine failure if this happened?
MCdougieFresh is offline
post #16 of 128 (permalink) Old 10-27-2010, 07:28 AM
RENDERMAN's Avatar
I'm trying to have a local company make stainless steel braided front and rear ones to avoid this problem....
"I take life one pixel at a time"-RENDERMAN
Adobe Photoshop CC and Autodesk Maya Certified Instructor
WILL.I.AM
My work:
http://www.wilsart.com/
RENDERMAN is offline
post #17 of 128 (permalink) Old 10-27-2010, 07:44 AM
lapthis's Avatar
Just blew my oil line on the passenger side a couple weeks ago. The line came right out of the connector. Engine looks like it escaped damage but I'm glad it happened on the freeway when it did. I was on my way to the Big Track at Willow Springs.......
lapthis is offline
post #18 of 128 (permalink) Old 10-27-2010, 08:57 AM Thread Starter
bryanf650's Avatar
I can't believe Lotus hasn't had a recall on this. Be sure to register your complaint with NHTSA.
Only takes a minute...and it could prevent a nasty crash or fire if Lotus owns up to it and institutes a recall.
post #19 of 128 (permalink) Old 10-27-2010, 09:11 AM
Driver's Side Oil Cooler Line
My 2005 failure was in 2005--apparently the hose or connection failed at the oil cooler. Fortunately I was going slowly and only two minutes from being able to park it. No engine damage, oil everywhere, a mess. Lotus fixed in under warrantee.
The dealer (Westlake CA.) had never seen this type of failure.
I never reported it.
evoate is offline
post #20 of 128 (permalink) Old 10-27-2010, 09:33 AM
6i9
6i9's Avatar
Should we standardized a draft among LotusTalk members so that we are all on the same page in what to write in the complaint?
Although I want to file a complaint, luckily *knock on wood* this has yet to happen on my car. Can I still file?
6i9 is offline
