We should report the oil line failures to NHTSA - Page 2 - LotusTalk - The Lotus Cars Community
post #21 of 128 (permalink) Old 10-27-2010, 10:08 AM
shay2nak
shay2nak's Avatar
Originally Posted by robains View Post
Stock Lotus has 27 feet of oil cooler lines (yes I did measure the ones I removed, huge weight savings also).
wow
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #22 of 128 (permalink) Old 10-27-2010, 11:09 AM Thread Starter
bryanf650's Avatar
It is an incident report, so I don't think you can unless you had an incident. Good idea to standardize.
I called it an 'oil line failure.'
bryanf650 is offline
post #23 of 128 (permalink) Old 10-27-2010, 11:11 AM Thread Starter
bryanf650's Avatar
Originally Posted by evoate View Post
My 2005 failure was in 2005--apparently the hose or connection failed at the oil cooler. Fortunately I was going slowly and only two minutes from being able to park it. No engine damage, oil everywhere, a mess. Lotus fixed in under warrantee.
The dealer (Westlake CA.) had never seen this type of failure.
I never reported it.
I believe you can still report it. All that you need is a VIN and an approximate date. The more reports NHTSA gets the more likely they will initiate an investigation and recall. It only takes a couple minutes.
Home | Safercar -- National Highway Traffic Safety Administration (NHTSA)
post #24 of 128 (permalink) Old 10-27-2010, 11:15 AM
Can you tell if the lines are close to failure by inspecting them? I've looked mine over a few time and don't see any sign of leakage swelling etc, but now you guys have me worried. They've lasted 46K miles so far...
Mike
2005 Arctic Silver Elise (Ohlins, Factory SC)
Thousand Oaks, CA
m_beale1 is offline
post #25 of 128 (permalink) Old 10-27-2010, 11:20 AM
kaz
kaz's Avatar
wow never knew there were more than a couple isolated incidents....glad my lines carry water coolant now instead of oil!
2006 Elise : JFG | Nitrons | 2bular 8" Single | IMRP aero | TWRD carbon | K20/24 NA | DRS EFI/Cosworth dash and tuning
kaz is offline
post #26 of 128 (permalink) Old 10-27-2010, 11:23 AM
ZTEC's Avatar
I dread the day I have this failure especially on track because more than likely it will be a very painful and expensive repair. I am out of warranty but this is potentially a serious failure. I hope every owner sees this and takes it seriously.
ZTEC is offline
post #27 of 128 (permalink) Old 10-27-2010, 12:31 PM Thread Starter
bryanf650's Avatar
Originally Posted by MCdougieFresh View Post
So what were the common "symptoms" you guys had once the line failed to know what happened? I.e. What would one be wary of to prompt immediate pull-over to preempt engine failure if this happened?
I'm not sure there are any symptoms except the oil light going on. I didn't see any evidence of a failure when I changed the oil a few months ago (but then again I wasn't looking too hard). The car was running fine when I pulled over.
post #28 of 128 (permalink) Old 10-27-2010, 12:33 PM Thread Starter
bryanf650's Avatar
Originally Posted by lt0302 View Post
when mine blew on a 05, Lotus replaced the engine.........the car had 13k when it went and it was under warranty at the time
You should report this failure to NHTSA. This is a safety issue, not a warranty issue. I hate to think what would have happened if I was on a track or windy mountain road.
post #29 of 128 (permalink) Old 10-27-2010, 02:33 PM Thread Starter
bryanf650's Avatar
Mine blew at 40k miles with no warning...
My understanding is that it is a manufacturing or design defect at the crimp to the fittings. The crimp is ineffective and separates catastrophically...
post #30 of 128 (permalink) Old 10-27-2010, 03:20 PM
Such moderate
Doge's Avatar
someone post pics of the line/fitting, i wanna see
Doge is offline
post #31 of 128 (permalink) Old 10-27-2010, 04:00 PM
erubin's Avatar
Go with a MoCal oil/water cooler and do away with the entire front oil cooler setup. Lotus Sport sell the oil/water cooler or you can contact these folks Bat Inc. They have everything you need including new sandwich plate.
This looks like a excellent upgrade for the winter. Anyone else have any feedback or experience with the Lamina oil cooler?
2007 Lotus 255 Cup, AP BBK F&R, Innovative mounts, RLS CF Intercooler heat shield, Railer diffuser, Custom hood Pins, gPan, Saikou Michi oil cc, RLS AL Intercooler tubes, Radium FST, 2Bular GT3 8X24, RLS suplemental IC Scoops, APR canards, CF rear wing, CF Scoops, Radium Fuel Rail and AN fuel pump adapter, AN fuel lines, 2bular decat and headers.
erubin is offline
post #32 of 128 (permalink) Old 10-27-2010, 04:35 PM Thread Starter
bryanf650's Avatar
I will try to get pics when I pick up my car from the shop.
There are a few other threads that have dealt with oil line replacement and failures. I am sure there are a few pictures out there.
post #33 of 128 (permalink) Old 10-29-2010, 03:33 PM Thread Starter
bryanf650's Avatar
Finally got my car back, but I didn't get any pictures of the failure. Sorry.
I do encourage ANYONE that has had an oil line failure (fixed under warranty or not) to step forward and report this to NHTSA at Home | Safercar -- National Highway Traffic Safety Administration (NHTSA). This is a serious safety issue and and Lotus should step up.
post #34 of 128 (permalink) Old 10-29-2010, 04:34 PM
lt0302's Avatar
how did affect the oil temp/engine temp
My concern is that here in AZ I need all the cooling I can get.....wondering how did affect your temps after you changed it out...........I am thinking about removing mine and installing one with a fan in the passanger wheel well.....
[B]05 Lotus Elise REV400, Stage II, BWR TB, OBX header, Moroso Oil Pan, RTD Brace, PRoAlloy Radiator, SS Break Lines, S111 Oil Catch Can, ACT HDC, Carbon Fiber Spliter, GRP Side Scoops, CF side skirts, , S111 front & rear tow hooks, tail lights-LED, Driving lights, Allitech, CF interior, 2010 Exige Spoiler, Lotus shop Seats, RA clam, Light Flywheel, ATI pulley, 2010 Exige Cup mirrors
lt0302 is offline
post #35 of 128 (permalink) Old 10-30-2010, 07:18 AM
blackburn's Avatar
Would you pllease supply a few more details of this modification. It would be much appreciated.
Thanks
Blackburn
Storm-Titanium, Sport & Touring, Hardtop.
blackburn is offline
post #36 of 128 (permalink) Old 10-30-2010, 07:33 AM
Minnis's Avatar
Mine blew with no warning at night, oil all over windshield in the middle of 50mph traffic and concrete wall on my left. I cut away fitting and used two screw clamps to re-attach- it's not slipping off like that swell factory crimp and it didn't cost me a thing. You don't need to remove anything but the wheel on the effected side and the wheel arch liner to get at it. If it happens do not run your car.
Minnis is offline
post #37 of 128 (permalink) Old 10-30-2010, 11:03 AM
Probably Lurking
Keeper's Avatar
Has anyone contacted Hethel directly? They have been responsive to the Lotus community in the past.
Given what sounds like a potentially life threatening issue that could affect any Elige without warning, they might want to get on top of this now especially if a few quick cuts and some screw clamps mitigate the danger.
-Shawn (2005 Elise) || New England Members of Lotus Ltd. (NEMOLL) - PM me to join local info list or NEMOLL || UberPost - Elise/Exige info: common problems/fixes, etc.
Keeper is offline
post #38 of 128 (permalink) Old 11-01-2010, 10:41 AM Thread Starter
bryanf650's Avatar
This is a good example of how dangerous this defect is. Be sure to report this to NHTSA!
post #39 of 128 (permalink) Old 11-01-2010, 11:00 AM
Mike4USC99's Avatar
This happened to ZenDude. I just PM'd him now to check it out.
'05 Lotus Elise Chrome Orange, Touring, QuickSilver Exhaust, Dual Oil Coolers, Aluminium Triple Pass RACE Radiator, Exige ProBax Seats
'01 GMC Yukon SLE, Onyx Black, 4.8L V8
'00 C5 Corvette Convertible, Red, 5.7L V8
Mike4USC99 is offline
post #40 of 128 (permalink) Old 11-02-2010, 06:23 PM
Demonized's Avatar
Today at noon, no warning;
Took me 2 seconds from seeing a small streak of oil appear behind me, to me turning it off... Oil light did not come on, but I'm sure it would if I would have started it as it kept pouring.
Best part is... I was reading this thread the other day, and even had a dream about this happening.... Probably why I turned the car off so fast and just coasted to the side.
Edit; submitted complaint.
2005 Saffron Yellow Elise (Sold)
Demonized is offline
