We should report the oil line failures to NHTSA - Page 3 - LotusTalk - The Lotus Cars Community
post #41 of 128 (permalink) Old 11-03-2010, 05:47 AM
Probably Lurking
Keeper's Avatar
Anyone have any ideas for a simple way to hold the hose in place without a lot of effort? I'm thinking some insurance like a larger hose sleeve overlapping the hose and the crimp with a hose clamp at each end. At the very least something that keeps the line from popping off and having oil escaping so rapidly.
-Shawn (2005 Elise) || New England Members of Lotus Ltd. (NEMOLL) - PM me to join local info list or NEMOLL || UberPost - Elise/Exige info: common problems/fixes, etc.
Keeper is offline
post #42 of 128 (permalink) Old 11-03-2010, 09:33 AM
Iceman-'s Avatar
Originally Posted by erubin View Post
This looks like a excellent upgrade for the winter. Anyone else have any feedback or experience with the Lamina oil cooler?
Me.
Fitted the Lotus Laminova Kit.
It simply does not works for cooling oil, it warms water only.
This not avoid the risk to decrimp tubes of oil, you must always crip two tubes of oil to sandwich plate and to the supposed "Laminova oil cooler"
WWW.111R.ORG
2004 Lotus SY 111R Elise VF II
Iceman- is offline
post #43 of 128 (permalink) Old 11-03-2010, 10:48 AM
Originally Posted by Iceman- View Post
Me.
Did your kit include the upgraded radiator? As you probably know, the Laminova is a heat exchanger, so it will tend to equalize the oil and water temperatures (the warmer fluid gets cooler, the cooler fluid gets warmer). Do you have an oil temperature gauge? What temps are you seeing? If the water temperatures are running hotter than normal, it means your radiator isn't adequate.
I'm very interested in your experience, because I'm considering the same "upgrade".
Thanks,
-Ed
'08 Arctic Silver Exige S240
AustinP is offline
post #44 of 128 (permalink) Old 11-03-2010, 11:02 AM
Iceman-'s Avatar
I've installed same day the triple bypass Lotus full alu rad.
No oil temp gauge.
The water gauge shows (Euro values - 87° in cruising, some less than before, and a top of 116° during hot summer track day, worste than before.
In city traffic the water temp raises faster to 100°.
All the twin rad equipped cars that i know here shows better water temps...
I'm considering to install twin rad kit.
WWW.111R.ORG
Iceman- is offline
post #45 of 128 (permalink) Old 11-08-2010, 10:06 AM
erubin's Avatar
I am moving to the Laminova cooler this winter. I am going to purchase the larger 330 cooler from BAT industries along with a pro alloy triple pass rad or a larger custom rad since I do not have air conditioning. I ran the car this past weekend with air temps around 45 degrees F and had a hard time getting and keeping the oil at optimal running temperatures. Furthermore, I just don't like having 27 feet of oil lines with 6 connections, not counting the Accusump. It will also be nice getting all the oil replaced during an oil change. If I was running endurance events I would keep the front cooler configuration, but short of that I don't see any reason not to change over. Anyone else have a good argument for keeping the stock setup.
2007 Lotus 255 Cup, AP BBK F&R, Innovative mounts, RLS CF Intercooler heat shield, Railer diffuser, Custom hood Pins, gPan, Saikou Michi oil cc, RLS AL Intercooler tubes, Radium FST, 2Bular GT3 8X24, RLS suplemental IC Scoops, APR canards, CF rear wing, CF Scoops, Radium Fuel Rail and AN fuel pump adapter, AN fuel lines, 2bular decat and headers.
erubin is offline
post #46 of 128 (permalink) Old 11-08-2010, 12:56 PM
lapthis's Avatar
I'm going to pick my car up this week from the mechanic after my oil line failure a couple weeks ago. My mechanic (south bay autohaus) told me that they have seen this failure a few times. One of his customers, who regularly tracked his car, had this happen to him twice in a year. Needless to say, that is not acceptable. I was lucky I didn't hit the guardrail when my back end went out as I got off the freeway. I'm also very concerned about the possibility of this happening when I'm on track. I asked him about any possible way of making the lines super tight and he said with the stock lines there isn't a way. We discussed installing a setrab oil cooler with fans over the winter. That is the best way to get rid of all the oil lines and the offending connections. It is next on my list of upgrades to make as another failure like this could be catastrophic.
For any of you guys who see the engine oil light come on while driving, try to pull over ASAP and shut the engine off. The oil comes out only while the engine is under pressure. The quicker you get it shut down, the better the chance you have of saving the engine and preventing tons of oil underneath the car causing you to spin out. Luckily I was running new Motul V300 so that probably helped save my engine.....
lapthis is offline
post #47 of 128 (permalink) Old 11-08-2010, 01:08 PM Thread Starter
bryanf650's Avatar
I know I'm sounding like a broken record on this...but REPORT THIS TO NHTSA!! Lotus needs to recognize this as a serious SAFETY issue. There have been a couple reports of 'near misses' on this already. It only takes a couple minutes.
Home | Safercar -- National Highway Traffic Safety Administration (NHTSA)
bryanf650 is offline
post #48 of 128 (permalink) Old 11-13-2010, 09:26 PM
lotusfan2's Avatar
Originally Posted by Minnis View Post
Mine blew with no warning at night, oil all over windshield in the middle of 50mph traffic and concrete wall on my left. I cut away fitting and used two screw clamps to re-attach- it's not slipping off like that swell factory crimp and it didn't cost me a thing. You don't need to remove anything but the wheel on the effected side and the wheel arch liner to get at it. If it happens do not run your car.
Can you post a picture of what you did? That would be much appreciated!
'06 Elise, Canyon Red
lotusfan2 is offline
post #49 of 128 (permalink) Old 11-13-2010, 09:58 PM
6i9
6i9's Avatar
So the Laminova solution does not solve the problem, even with an upgaded radiator??
2005 Magnetic Blue Lotus Exige
Drivetrain: Honda K20A Type R | Innovative Kit | Arqray Ti | SCM Intake/Header | Hondata | proRAD | Setrab | KTuned | V2 Fuel Tank | BOE Swirl
Aero: Exige Clams | Reverie | TWRD GT | Craftsquare | IMRP | BSK | Voltex
Suspension: Penske SA | V2arms | RTDbrace | CE28N | R888 | BOE Floating | Pagid RS14
Interior: Recaro SPG | Willans | WorksBell | Sparco
6i9 is offline
post #50 of 128 (permalink) Old 11-14-2010, 01:38 AM
Iceman-'s Avatar
No, you must always crip the oil tubes...
WWW.111R.ORG
Iceman- is offline
post #51 of 128 (permalink) Old 11-14-2010, 01:54 AM
So have any aftermarket vendors created a way to fix this? Going to buy an Exige soon and this issue scares me especially since it would be out of warranty.
filipp2442 is offline
post #52 of 128 (permalink) Old 11-14-2010, 06:09 AM
SobeLotus's Avatar
Important Added Thread
I did this write up about two months ago. I am surprised no one has mentioned it. This should assist anyone who wishes to change the line.
https://www.lotustalk.com/forums/f293...alation-91341/
If this happens to you on a track event or during a fast curve on a highway you run a high chance of a serious incident. The oil will get all over one of your rear tires. Not to mention the damage your engine can sustain.
I was fortunate this happened to me during the day, in a staight line, and i smell the burning oil before it all emptied out onto the street. I have since corrected the problem and added some gauges for additional warnings.
I went ahead and reported the incident to NHTSA.
I was just all looks, but now will be a collectors item too.
SobeLotus is offline
post #53 of 128 (permalink) Old 11-14-2010, 06:57 AM
erubin's Avatar
The Laminova setup eliminates the dual oil coolers the factory tubing along with the connectors and the sandwich plate. I am going with a mocal sandwich plate w/o thermostat and AN type connectors. Not sure why you think this will not eliminate the oil line failure risk?
erubin is offline
post #54 of 128 (permalink) Old 11-14-2010, 10:39 PM
oil line issues
My right rear oil line came out of the crimp on Oct 19. Unfortunately my warranty ran out on July 21. No luck. I had lunch, on my way back and without warning the oil light came on, quickly followed by the engine light. I pulled over as soon as I could, but won't know about any damage until I fix the line (don't think I will use OEM parts). Oil all over the inside of the engine compartment and right rear tire. I will fill out a form, but any ideas who to talk to in Canada?
Here's what the pulled out oil line looks like. I did not move anything, this is how it looked when I removed the undertray (also a very messy job at that point). No signs of crimping. Only 34000km (about 20000 miles) on the 2007 elise.
Cheers,
speedycar is offline
post #55 of 128 (permalink) Old 11-15-2010, 02:39 AM
Elige's Avatar
man this is scary stuff, i think i might do sobe's line swap sooner than later.
05 graphite grey elige with zero mods.....sold
Elige is offline
post #56 of 128 (permalink) Old 11-15-2010, 08:48 AM
He's on fire!
jds62f's Avatar
does anyone *really* know if the crimps failed completely, all at once? Is it more likely that the hoses are backing out of the crimped connections over time and eventually they disconnect?
I think I'm going to take a silver sharpie to the hoses at the crimps so if it is the case they back out over time and eventually fail, I'll at least have a shot at knowing ahead of time.
jds62f is offline
post #57 of 128 (permalink) Old 11-15-2010, 08:56 AM
Demonized's Avatar
I can tell you with absolute certainty that mine had not backed out when I replaced my sandwich plate, about a year ago.
2005 Saffron Yellow Elise (Sold)
Demonized is offline
post #58 of 128 (permalink) Old 11-26-2010, 12:48 PM
jlj3394's Avatar
FWIW, NHTSA reports will get results. Usually they'll give the mfg a chance to issue a TSB or voluntary recall.
IN order to insure that NHTSA responds quickly, make sure you emphasize that this is a safety issue and that a blown oil line can lead to a serious or fatal car wreck.
07 ExigeS;05 Elise(RIP);06 V70R;12 JKUR
jlj3394 is offline
post #59 of 128 (permalink) Old 02-09-2011, 08:36 PM
Hey I just had the same problem, did Lotus fix it? My car is out of warranty
magicalshantaram is offline
post #60 of 128 (permalink) Old 02-09-2011, 10:23 PM
apexdc's Avatar
Are the failures occurring at both ends of the hose going from the cooler back to the engine compartment?
From the last picture, it looks like the hose is just pulling out of the fitting. Is that correct?
Bottom line, are the possible failures at each end of the same hose?
If the issue is that localized, I wonder if it might be possible to use some device to help take some of the load off the connections.
Some things that come to mind are fitting a small hose clamp down on the hose and then running safety wire or zip ties back to some point near the metal fitting to ease the load.
OR possibly wrapping the whole thing in some of that stretching repair tape with the super adhesives in it. Once that stuff sets up, it is remarkably strong. Again, I'm just looking at something to possibly ease the load on the weak spot a bit.
I'm fitting a gPAN in the next few weeks. I'll do some poking around and see what comes to mind.
Can't hurt (hopefully).
2006 Elise, Graphite Grey/Red leather, Sport Elise Suspension, Cup airbox, ECU ref lash, MonoBalls, etc. etc.
apexdc is offline
