We should report the oil line failures to NHTSA - Page 4 - LotusTalk - The Lotus Cars Community
post #61 of 128 (permalink) Old 02-10-2011, 01:43 AM
Flash G's Avatar
Had the oil lines on my car upgraded to braided stainless steel a few years ago. Probably a good way to avoid any potential future oil line blowouts.
My 2 cents.
Turn your flatscreen TV into a work of art.
Modern Art DVD | Plasma Aquarium DVD | Widescreen Fireplace DVD
07 Exige S - Ardent Red, Stage II Exhaust, LSD, Touring pack
06 Range Rover Supercharged - Java Black
06 Range Rover Sport - Java Black
05 Elise - Ardent Red, Stage II Exhaust, Touring pack
Flash G is offline
post #62 of 128 (permalink) Old 02-10-2011, 02:42 AM
6i9
6i9's Avatar
My 2 cents.
Do you remember where you got your stainless steel lines and what the specs/dimensions were? Also, where did you go to have the work done?
2005 Magnetic Blue Lotus Exige
Drivetrain: Honda K20A Type R | Innovative Kit | Arqray Ti | SCM Intake/Header | Hondata | proRAD | Setrab | KTuned | V2 Fuel Tank | BOE Swirl
Aero: Exige Clams | Reverie | TWRD GT | Craftsquare | IMRP | BSK | Voltex
Suspension: Penske SA | V2arms | RTDbrace | CE28N | R888 | BOE Floating | Pagid RS14
Interior: Recaro SPG | Willans | WorksBell | Sparco
6i9 is offline
post #63 of 128 (permalink) Old 02-10-2011, 07:23 PM
Flash G's Avatar
Had it done at Lotus of Beverly Hills in early 2008. (Before their untimely demise.)
Don't remember the cost.
Flash G is offline
post #64 of 128 (permalink) Old 02-10-2011, 08:03 PM
malakaone's Avatar
I had spoken to the gentleman at EliseUSA for braided lines, but wanted me to help him facilitate a solution. Unfortunately due to time and lack of knowledge of the length the oil cooler lines I stopped following through with this. I would love to buy something and have it installed for piece of mind.
My oil cooler line failed, enginer replaced, and reported.
malakaone is offline
post #65 of 128 (permalink) Old 02-10-2011, 08:43 PM
its just a matter of poor crimping on all the hose fittings.i saw some seeping on one of my oil cooler lines the other day.so i guess i will be swapping all my lines over to aeroquip here very soon.
kmt63 is offline
post #66 of 128 (permalink) Old 02-10-2011, 09:09 PM
I don't get why you need to replace the hose. Why not just replace the fitting then clamp over the outside?
Phantom Black 2007 Exige Kold Fire, Tesla double din dash.
Black 01' Mustang Cobra 'Vert ("some" modifications) daily driver
IamBatman is offline
post #67 of 128 (permalink) Old 02-10-2011, 10:46 PM
How many total failure do we have now? Seems like a large % given our production numbers and severity.
post #68 of 128 (permalink) Old 02-21-2011, 12:49 AM
Flyntgr's Avatar
I have an 08 Elise. Have any of this year failed?
Flyntgr is offline
post #69 of 128 (permalink) Old 02-21-2011, 01:14 AM
truespartan's Avatar
I have an 2005. Noticed oil seeping out of one of mine in the off season look over. Going to replace all the lines with Sobe's fix.
Add another to the list...
SpecRacerFord #189
2003 Suburban - 450 hpTow beast
2010 Camaro M/SS
2005 Elise Sold
truespartan is offline
post #70 of 128 (permalink) Old 02-21-2011, 04:06 AM
KochinoPride's Avatar
This is a scary (potential) issue. I'm at 50k and I bought a supercharger recently. I want to upgrade the oil lines ASAP - does anyone know of a solid product that I can have brought to my mechanic and have them changed over? Thanks
KochinoPride is offline
post #71 of 128 (permalink) Old 02-21-2011, 05:20 AM
jlj3394's Avatar
I think I posted about this issue awhile ago, but since this is four pages now, it bears repeating:
If you complain to NHTSA, something could actually be done. NHTSA is in charge of investigating auto manufacturer defects and they are especially keen on investigating car and truck defects which can lead to serious accidents, injuries, or deaths. Blown oil lines certainly fit this category.
NHTSA has an online form, I would suggest that anyone experiencing this complete the form. Lotus is not going to get hammered, they will simply be told to bring in the vehicles and check the fittings - the oil line issue is usually that simple.
Until then, everyone ought to keep an eye on these lines. If oil leaks and hits a tire, you're gonna lose control of the car, which is the vehicle's best crash prevention system. I sure as hell wouldn't want to lose control and slide into the path of an SUV or into a tree, a hospital trip (or worse) is the clear result of that.
07 ExigeS;05 Elise(RIP);06 V70R;12 JKUR
jlj3394 is offline
post #72 of 128 (permalink) Old 02-21-2011, 05:48 AM
Would putting some sort of Gorilla Glue & High Speed/Heat tape around the line bandage style prevent this from happening? I would think it couldn't hurt and then hose clamp the tape bandage onto the line and the fitting? Makeshift I know, but what are y'alls thoughts on doing this?
KirkScheidt is offline
post #73 of 128 (permalink) Old 02-21-2011, 06:12 AM
He's on fire!
jds62f's Avatar
someone with more knowhow should reply but I'm guessing tape is a bad idea that might actually mask a problem (if you had one) that would be ineffective in the event of a hose failure
jds62f is offline
post #74 of 128 (permalink) Old 02-21-2011, 06:21 AM
Gorilla Tape
I was thinking the thick one and the possibly adding some high heat glue to the adhesive underneath . . . Then possible adding a hose clamp to each side of the bandage to hold it in place. I know this wouldn't necessarily prevent a pipe burst, but I would think it would prevent the tube from "Popping Out" of the crimps no?
post #75 of 128 (permalink) Old 02-21-2011, 05:57 PM
RoadDad's Avatar
Direct link to reporting page:https://www-odi.nhtsa.dot.gov/ivoq/
RoadDad is offline
post #76 of 128 (permalink) Old 02-21-2011, 06:51 PM
I checked the fronts and they look okay to me. I did notice one hose seemed to be wearing against the wheel well and had made a slight flat spot on it towards the top of the front wheel well area. Should I tape this to prevent it rubbing through? It wasn't bad or anything, but I just want to be as preventative as possible . . . Will tape hurt the hose in anyway? Gorilla Tape BTW . . .
post #77 of 128 (permalink) Old 02-21-2011, 10:56 PM
saffron blur's Avatar
I looked on the NHTSA website and there have only been 7 complaints filed regarding the oil line failures. Seems to be a lot more than 7 occurrences out there! Please, if you have experienced a failure submit a complaint to the NHTSA. This is scary stuff! I want to enjoy my car. Not die behind the wheel for something as stupid as lame factory connections resulting in an oil-fed wipeout against a tree or an oncoming semi.
I would complain - but it hasn't happened to my Lotus - yet. I am worried though with 30K or so miles on the clock. Now it's going to be in the back of my mind nagging at me until I can get this preventively fixed.
I'm not even sure of the proper way to fix the problem. Sounds like some of the answers are to tie a rag around it or use some bailing wire and hope for the best. I would feel a lot better if a recall were introduced so we could all go in and get some proper safety measures taken care of for our oil hoses and clamps. In the big scheme of things it probably wouldn't cost Lotus all that much to refit with a better clamp design or something. And then it would be an official and SAFE fix.
saffron blur is offline
post #78 of 128 (permalink) Old 02-22-2011, 12:14 PM
CrusaderTBC's Avatar
My last checkup, the dealer reported that I had a leak in the passenger side oil coolant line. Unfortunately, the weren't able to perform the warranty work (Criswell, MD) at that time.
07 Arctic Silver Exige S
00 Raven Black Audi TT
CrusaderTBC is offline
post #79 of 128 (permalink) Old 02-22-2011, 01:20 PM
briphi's Avatar
Originally Posted by SobeLotus View Post
I did this write up about two months ago. I am surprised no one has mentioned it. This should assist anyone who wishes to change the line.
https://www.lotustalk.com/forums/f293...alation-91341/
This looks like a great idea for those who are concerned about it. I was thinking about buying these parts following the instructions as preventative maintenance. Only problem is that I have an 05 with dual oil coolers. Without actually looking into it, I'm not sure exactly what additional parts I will need, or how to replace the oil line that goes through the front clam. I really hope I'll be able to do it with the front clam on.
I agree that someone should come out with a kit and real instructions to make this easier.
Mods: BOE Clamhinge, BOE QS Exhaust, Powder Coated Black Rims, Difflow 7 Element Diffuser, Sector111 re-ENFORCER, APR Canards, CharlieX +8hp ECU reflash, Polk db401+db651, Kenwood KSC-SW10 Subwoofer
Installing Soon: 2010 Exige Wing, CF Side Scoops
briphi is offline
post #80 of 128 (permalink) Old 02-22-2011, 04:05 PM
Vantage's Avatar
If someone could just get Lotustalk user "carl" a spare line with the fitting still crimped on, then he will develop a cheap solution to permanently fix the problem without having to change the line. Or at least, this is what I understand.
Vantage is offline
