We should report the oil line failures to NHTSA - Page 6 - LotusTalk - The Lotus Cars Community
post #101 of 128 (permalink) Old 08-05-2011, 04:11 PM
discocubizm's Avatar
Does anyone have a contact number or email for the NHTSA people looking into this? I filed a report a long time ago but I'm pretty sure I used my Duke email account which has subsequently been shut down since I left. I would like to send them this little gem:
2005 Lotus Elise (Arctic Silver) Touring, LSS, Dual Oil Coolers, Stage II exhaust, Fujita Intake, Hardtop
2010 Ford Raptor SVT (Blue Flame Metallic) Stainless Works Exhaust, Roush intake
2005 Lotus Elise (Arctic Silver) Touring, LSS shocks, BWR sway bar, Cup Airbox, Stage II exhaust, QR steering rack - Sold
discocubizm is offline
post #102 of 128 (permalink) Old 08-05-2011, 06:43 PM
tmr
tmr's Avatar
NHTSA Contact Information | National Highway Traffic Safety Administration (NHTSA)
'05 Lotus Elise (Arctic Silver) Sport, HT, Stage II, Odyssey PC925, Cup 240r Wheels
'11 BMW 335i (Alpine White) M-Sport, Premium, Heated Seats, HK, Ipod adaptor, 6 MT, Performance Power Kit - Euro Delivery 5/11/2011 - daily driver
'87 Nissan Pickup (Burgandy) King Cab, used for hauling stuff
'17 Audi A4 Ultra (Monsoon Gray) Premium Plus - Wife's car - Delivery 2/17
tmr is offline
post #103 of 128 (permalink) Old 08-06-2011, 10:17 AM
wonder when mine are gonna go out
tecn9ne23 is offline
post #104 of 128 (permalink) Old 08-06-2011, 01:49 PM
glb
glb's Avatar
I don't recall seeing the actual hoses fail. So, I took Kevinp's lead and bought the BSP hose ends.
The mechanic at Sports & Specialist Cars, Hopewell, NJ has not seen a single line failure.
Mostly, he sees oil coolers leak.
While clam is off, am replacing the radiator, also prone to failure. The Wizard Cooling radiator that 407driver recommended is an impressive unit, $430 + frt.
Prorad, via Sector 111 was ng for me, with failures already reported.
I drive all over eastern half of country. didn't want to get stranded or lose an engine. Soon expect to be driving farther west. Pretty hard to remove clam on the side of the road....
glb is offline
post #105 of 128 (permalink) Old 08-06-2011, 02:35 PM
ERP
ERP's Avatar
Not sure if this has been posted already, but there is a 2004 service bulletin from Lotus regarding these oil leaks. Anyone who downloaded the PDF manual has a copy. I've attached a pic of it below.
2006 Chrome Orange Elise - 6.3 lbs/hp - MP-62 Supercharger, 3.2" Pulley, BOE Fast-Works Tune, Ported Head, MWR Stage 3 Cams, Penske Suspension, Cup Air Box, PPE Header with Catless Custom Twin Tip Exhaust, Fidanza Flywheel, ACT Clutch, MWR Water Pump + Alternator Pulley, 1900 lbs
Saab Turbo X, 415hp, 532 tq
Tesla S P85D - Wife's daily driver
ERP is offline
post #106 of 128 (permalink) Old 08-06-2011, 04:23 PM
Probably Lurking
Keeper's Avatar
That's a different issue and was resolved. Also failures didn't result in the massive oil loss that is typical for the oil line separation issue that NHTSA is investigating.
-Shawn (2005 Elise) || New England Members of Lotus Ltd. (NEMOLL) - PM me to join local info list or NEMOLL || UberPost - Elise/Exige info: common problems/fixes, etc.
Keeper is offline
post #107 of 128 (permalink) Old 08-06-2011, 04:30 PM
Probably Lurking
Keeper's Avatar
Here you go; actual line failure.
https://www.lotustalk.com/forums/f312...-repair-90292/
Cooler leaks and line failure make me nervous too but I imagine the volume of oil expelled to be so much less that the risk of major incident is probably much smaller. Nonetheless, I'll be replacing lines before I put the oil coolers back into service.
Keeper is offline
post #108 of 128 (permalink) Old 08-06-2011, 09:24 PM
chili07's Avatar
when draining coolant to remove head for broken valve, i was looking around and found what looks like the oil line pulling out crimp at oil filter. should i report it to NTHSA. car is an 07
chili07 is offline
post #109 of 128 (permalink) Old 08-07-2011, 10:31 AM
tmr
tmr's Avatar
I would report it anyway. Is it leaking yet?
tmr is offline
post #111 of 128 (permalink) Old 08-07-2011, 08:25 PM
add_lightness's Avatar
Leak at the oil cooler
After reading the reports, I dug under the car and saw oil seeping from the front driver side oil cooler. I pulled the fender lining out and saw it was a bit messy, but the crimped OEM hose coming from the cooler was clean.
I suspect the leak is from the hose in front between the front two coolers...the one, of course, that requires me to take the whole front clam off. Grr.
I tried to inspect it through the front small grill...it's difficult to see, but it looks like the "sleeve" over the hose has some oil seeping out from under it.
Is there an easy way to tell if this is from the hose/fitting or if the cooler itself is damaged?
Cheers all,
-Erik
'06 Cartoon Orange Lotus Elise - Few racy bits
add_lightness is offline
post #112 of 128 (permalink) Old 08-07-2011, 08:56 PM
erubin's Avatar
I believe you can get to the center hose by removing the front under tray.
2007 Lotus 255 Cup, AP BBK F&R, Innovative mounts, RLS CF Intercooler heat shield, Railer diffuser, Custom hood Pins, gPan, Saikou Michi oil cc, RLS AL Intercooler tubes, Radium FST, 2Bular GT3 8X24, RLS suplemental IC Scoops, APR canards, CF rear wing, CF Scoops, Radium Fuel Rail and AN fuel pump adapter, AN fuel lines, 2bular decat and headers.
erubin is offline
post #113 of 128 (permalink) Old 08-08-2011, 10:37 AM
It is a shame to still see so many of these incidents and Lotus has no response. My story is here, includes pictures.
  • Year: 2005
  • Model: Elise
  • Date failed: April 2008
  • Location of failure: I-95 between Baltimore and DC
  • Mileage: 19K
  • Daily driver: Yes or No
  • Track use: Never
  • Other description or info: Pretty sure my engine was damaged, Lotus said engine was fine, however now at 35K, and my drivetrain is fairly noisy. My guess is it wore the camshafts when the sump went dry.
2005 Laser Blue Elise
http://www.z-car.com/blog/
gjsmith66 is offline
post #114 of 128 (permalink) Old 08-08-2011, 05:04 PM
That hose is on its way out. Yes, you should report it. Also should think about fixing this before the car is driven much.
kmt63 is offline
post #115 of 128 (permalink) Old 08-09-2011, 09:46 PM
ChrisH's Avatar
I had a leak at the same connector, and fixed it. The following thread has a detailed description of how to replace the connector yourself, and a dissection of the the stock connector.
https://www.lotustalk.com/forums/f312...ictures-99266/
ChrisH is offline
post #116 of 128 (permalink) Old 08-17-2011, 05:17 PM
Front one gone now
Repaired the rear crimp failure, will post pictures of how later, but it was easy and seems to be working quite well. Unfortunately something blew up front now. Reported the rear failure, looks like I'll have to report the front now. Engine still works, good thing it a Toyota.
Found out from a local British Car repair shop that they just fixed another one last week. Likely the owner doesn't even know its an issue. Will be trying to contact them to have them report as well.
speedycar is offline
post #117 of 128 (permalink) Old 08-19-2011, 01:05 PM
Got a call from NHTSA today. They want pictures and service records from my two oil line failures. The investigation appears to be in full swing...
post #118 of 128 (permalink) Old 08-19-2011, 01:17 PM
someone mentioned to me that the valves get really loud when the oil pressure start to drop....did you guys notice that when your oil line blew? this could be an added audio warning because we are not always staring at our instrument gauge when we are driving..
Phantom Black 2007 Exige Kold Fire, Tesla double din dash.
Black 01' Mustang Cobra 'Vert ("some" modifications) daily driver
IamBatman is offline
post #119 of 128 (permalink) Old 08-19-2011, 01:32 PM
apexdc's Avatar
I used to run a 2" diameter trailer brake light as an oil pressure warning light in a Camaro I used to race. You could see it pretty well....
2006 Elise, Graphite Grey/Red leather, Sport Elise Suspension, Cup airbox, ECU ref lash, MonoBalls, etc. etc.
apexdc is offline
post #120 of 128 (permalink) Old 08-19-2011, 08:17 PM
I did notice the valves making a lot more noise. Good time to shut the engine down.
