Evora Weight Savings - LotusTalk - The Lotus Cars Community
 14Likes
post #1 of 123 (permalink) Old 02-09-2013, 07:56 AM Thread Starter
Julian73's Avatar
Evora Weights
2013 Factory figures:
Base 6-sp NA Base: 1383 kg … 3049 lbs
Fully optioned 6-sp NA: 1431 kg … 3155 lbs
IPS NA: 1436 kg … 3166 lbs
6-sp S: 1437 kg … 3168 lbs
IPS S: 1442 kg … 3179 lbs
Thus:
Option Packs add ~ 106 lbs
IPS transmission adds ~ 11 lbs this includes additions do to oil Cooler
S adds ~ 13 lbs this includes additions due to SC and Oil Cooler and reductions due to flywheel
Most of S weight comes from the option packs not the supercharger itself.
My fully optioned S just scaled in at 3130 lbs with headers, cat replacement, CAI, w/oil (extra 2 qts, 3.2 lbs) and 10 gals fuel 5/8 tank (35 lbs under), OEM battery; full tank would give 3165 lbs or 3162 lbs with standard capacity oil pan. Figuring 5 lbs saved with headers & CAI & 1 lb with Oil Cooler mods puts it back to 3168 ~ orginal pre-mod weight (same as Lotus claim). So while it is a fat pig, at least Lotus gives honest weights. Final PWR: 8.1 lbs/Hp
My corner weights for 3130 case: LF 592, RF 625, LR 964, RR 949
--- Front ratio 38.9%, Rear ratio 61.1%, LF-RR ratio 49.2%, RF-LR ratio 50.8%
nintense likes this.
'12 Evora S GP (No. 1 of 14) BOE Prototype S 430 **SOLD**
Last edited by Julian73; 02-15-2013 at 08:02 PM. Reason: Edited weight savings from header & CAI mods
Julian73 is offline
post #2 of 123 (permalink) Old 02-09-2013, 08:01 AM Thread Starter
Julian73's Avatar
Component weights:
Komo-Tec headers: 15.4# (Julian73)
- OEM Ex Manifold & Heatsheilds: 17.8# (Julian73)
( savings 2.4#) (no downpipe change)
Komo-Tec 200 cell Cat: 6.9# (Julian73)
- OEM 3rd Cat: 6.4# (Julian73)
( penalty 0.5#)
2ubular Exhaust delta: stock manifold- downpipe- 3rd Cat changed to header- downpipe- 200 cell cat.
( savings 6.2#)(Bobsy Racer)
Lotus MS Oil Sump ALS5E0147J: 5.9#, + 2 qts oil 3.2# (Julian73)
- OEM Pan & pick-up: 3.6# (Julian73)
( penalty 5.5#) (gain, oil control and extra oil)
OEM Intake & all ducting (exc. mount bracket, MAF sensor, resonator (NA model only), discharge tube to T-Body): 6.4# (Julian73)
BOE CAI (inc. mount, MAF Tube & sensor, discharge tube to T-Body, heat foil): 3.2# (Julian73)
( savings 3.2#)
Other weights for reference (source):
OEM Supercharger: 32.6# (Ramtin1000)
OEM NA Flywheel: 16# (VSAMotorsport)
OEM S Flywheel: 12.2# (Ramtin1000)
GTE flywheel: 10.5# (Jaws)
Flywheel option: 8# (VSAMotorsport)
OEM S Clutch disc: 25.8# (Ramtin1000)
OEM S Cover plate: 22.4# (Ramtin1000)
OEM Engine Cover 5.0# (Julian73)
Chimera CBS battery 8.3# (Julian73)
Last edited by Julian73; 02-16-2013 at 01:33 PM. Reason: Input measured OEM weights
Julian73 is offline
post #3 of 123 (permalink) Old 02-09-2013, 09:06 AM Thread Starter
Julian73's Avatar
Evora Rear Silencer weights (wt in lbs) (published data):
Quicksilver, L0147S ... 17.2
Larini Oval ... 18.4
Larini Twin Tip ... 18.5
Komo-Tec ... 19.8
Evora Motorsport, ALS5E0146J ... 24.3
Supersprit Racing ... 24.7
Evora Sport Stage I, LOTAC05504 ... 24.7
Blue Flame ... 26.5
Supersprint Street ... 30.0
Kressing 2 x 80 mm ... 33.1
2ubular Dual ... ?
2ubular Dual w/ Cats ... ?
OEM NA '09-'11, C132S00003F ... 38.4
Valved options:
Larini Oval - Valved ... 26.5
OEM S '11, A132S0154F ... 41.9
OEM '12+ S (i/IPS), A132S0180F ... ?
OEM '12+ NA (i/IPS), A132S0185F ... ?
Last edited by Julian73; 02-16-2013 at 01:26 PM. Reason: error in MY12 OEM Silencers, I had PN's switched
Julian73 is offline
post #4 of 123 (permalink) Old 02-09-2013, 03:17 PM
invictusmaneo's Avatar
at some point I'll get my custom Varex valved one off to measure weight, but I'd guess about 25 pounds but that includes the decat pipe (1 piece) just for people's curiosity.
I'm surprised the SC adds so little. I had my elise corner weighed at one point, need to get the Evora done.
2016 AMG GT-S
2012 Caterham R400 (sold)
2010 Chrome Orange Evora (Sold )
2005 ST Elise (sold)
2002 MB G500 lifted etc.
2003 Cooper S (track)
we'll see what Lotus comes up with next...
invictusmaneo is offline
post #5 of 123 (permalink) Old 02-09-2013, 04:13 PM Thread Starter
Julian73's Avatar
The SC adds net little with the lightened flywheel, is all the other stuff that they typically come with that adds the weight.
Julian73 is offline
post #6 of 123 (permalink) Old 02-09-2013, 06:48 PM Thread Starter
Julian73's Avatar
Added some more weight info. Its time for me to install that Chimera battery sittting on my bench and get 25 lbs out from the LR. The Boeing 787 issue has given me the hebegebees; a fire back in the boot would get big before being noticed.
Estimate: 3105 lbs: LF 592, RF 628, LR 940, RR 945
--- Front ratio 39.3%, Rear ratio 60.7%, LF-RR ratio 49.5%, RF-LR ratio 50.5%
Then another 15lbs with a valved muffler solution ...
Julian73 is offline
post #7 of 123 (permalink) Old 02-09-2013, 08:12 PM
The chimera is lithium ion. I would look at shorai, cheaper, lighter, and lithium iron.
Welcome - Shorai LFX Batteries
Asulil is offline
post #8 of 123 (permalink) Old 02-09-2013, 11:14 PM Thread Starter
Julian73's Avatar
I already posess the Chimera, they are both lithium iron based; Shorai is lighter due to smaller capacitty.
Julian73 is offline
post #9 of 123 (permalink) Old 02-10-2013, 12:25 AM
tbd_Evora's Avatar
I think you missed the weight difference between the 2+0 and the 2+2.
tbd_Evora is offline
post #10 of 123 (permalink) Old 02-10-2013, 09:12 AM Thread Starter
Julian73's Avatar
I didnt miss anything, this is not all inclusive but is open for others to add weights. I don't have both versions to compare; but it is in the total options figure.
That said, I have taken out the foam seat before, it is only a few pounds while the +0 has two metal bars probably weighting about the same plus carpeting.
Julian73 is offline
post #11 of 123 (permalink) Old 02-10-2013, 11:22 AM Thread Starter
Julian73's Avatar
Note I just corrected PN's for MY12 NA and S Silencers listed above, I had numbers reversed.
Also while I don't have a weight on these, I note that the silencer can is about 6 inches shorter than the '11
Julian73 is offline
post #12 of 123 (permalink) Old 02-15-2013, 08:03 PM Thread Starter
Julian73's Avatar
Updated component weights with OEM take-off weights inserted in prior tables.
Julian73 is offline
post #13 of 123 (permalink) Old 02-16-2013, 04:43 PM
Bobsy Racer's Avatar
Julian,
Note, your RF corner weight is heavier than your LF, while in the rear the LR is heavier than the RR. So, your car is diagonally heavy on the RF-LR. I suggest that you check your ride heights at each corner, and raise or lower one corner so that the weight distribution percentage of LF-RF is the same as LR-RR. I'm sure you know this from your track experience, but thought I would point it out for others.
Bobsy Racer is offline
post #14 of 123 (permalink) Old 02-17-2013, 05:30 PM Thread Starter
Julian73's Avatar
Good points; although this was not enough of a rigorous weigh-in for any cross weight finalizing with weigh-in was with fluids but no driver, I should measure the ride heights to get a base line to go with these corner weights. Besides it may be too esoteric to consider cross balancing a for street car. While corner weights should be at 50/50 with a tolerance near zero this car is showing under 1%, where-as the acclaimed Honda S2000 is out over 3%.
I will be changing out battery, pulling some 25 lbs weight of LR but driver weight (me) probably loads that same diagonal the most, so more in wrong direction. As to jacking a car with stock suspension no easy task as it offers no official capability to adjust corner or adjust ARB links to take out any preload torque. Spring spacers could be put in the coils and or just add adjustable ARB links, which would be needed anyways, and tweak the preload (not kosher except to very fine tuning) to jack the load. Anyone more interested in the techniques should read “How to Make Your Car Handle” by Fred Puhn, plus review a few spread sheet examples posted on the net. Remember add corner height to increase weight/reduce to reduce and do things in small increments.
Last edited by Julian73; 02-17-2013 at 07:09 PM. Reason: A rewrite for clarity and reference
Julian73 is offline
post #15 of 123 (permalink) Old 02-17-2013, 07:33 PM
squidward's Avatar
Re: Evora Weights
Plus, strange as it sounds, the 2+2 actually offers more room for cargo space than the 2+0 shelf.
squidward is offline
post #16 of 123 (permalink) Old 02-17-2013, 08:01 PM
Originally Posted by squidward View Post
Plus, strange as it sounds, the 2+2 actually offers more room for cargo space than the 2+0 shelf...
I eliminated the entire cargo net, strap, and aluminum base strip in my 2+0, to increase the cargo space, and lost 6 pounds of the parts. The strap mounting tabs, on the left and right sides of the roll bar, can still be used to tie down cargo as necessary.
See Post # 7 here:
https://www.lotustalk.com/forums/f170...version-95539/
post #17 of 123 (permalink) Old 04-14-2013, 08:16 AM
brgelise's Avatar
Thumbs up Evora Weight Savings
OK I have dug up all the info except stock cast wheels and "S" fitments.
Feel free to add as we get the info. Time for an Evora section on weight reduction. I'll start with wheels and exhaust. If this gets detailed enough we should make it a sticky for reference. I know I loved these posts in Elise section
1. WHEELS
Stock cast wheels
F (18x8)
R (19x9.5)
Forged wheels
F 20.8lbs (18x8) Total weight of set 95.20lbs
R 26.8lbs (19x9.5) (??)
Monzas (Sector 111)
F 19.3 lbs (18x8) Total weight of set 83.40lbs
R 22.4lbs (19x9.5) ($3950)
Team Dynamics1.3
F 21.3lbs (18x8.5) Total weight of set 90.20lbs
R 23.8lbs (18x10) ($1200)
2. TIRES
Stock Pirelli PZeros 225/40R18 23lbs
255/35R19 26lbs set weighs 98lbs
Toro R888's 235/40R18 24.9lbs set weighs 105.6lbs
275/35R18 27.9lbs
3. EXHAUST
a.STOCK exhaust (NA) 38.4lbs
Larini Sport 18.4lbs save 20lbs
Lotus Sport
Plackslayer
b.3rd CAT pipe stock 6.20lbs
test pipe 2.5lbs save 3.7lbs
4. Intake
Stock weight 8.7lbs Measured by another member)
Radium ~5.7 save 3lbs
BOE
5. Batteries
Varta 36.8lbs
Interstate 34.4lbs
Chimers CBS 8.3lbwbracket $950
Chimera RBS ? $ 597
Shorai(LFX24A3-BS12 4.8lbs $284 shipped
Odyssey 625 13.2lbs (obsolete)
Odyssey 680 15.6lbs??(obsolete)
Braille Intensity $480R 10.1lbs $1899
Feel free to excel this or pretty it up
brgelise is offline
post #18 of 123 (permalink) Old 04-14-2013, 09:22 AM Thread Starter
Julian73's Avatar
This needs linking with my older site .... https://www.lotustalk.com/forums/f170...eights-124131/
Julian73 is offline
post #19 of 123 (permalink) Old 04-14-2013, 01:16 PM
brgelise's Avatar
THANKS JULIAN!! NOT SURE WHY MY SEARCH DIDN'T YIELD THIS
How can we best link these?
brgelise is offline
post #20 of 123 (permalink) Old 04-14-2013, 01:17 PM
Lckitty's Avatar
Are they merge-able to one list?
https://www.instagram.com/evoralightness/
2012 Lotus Evora - IPS, Nightfall Blue
2011 Jaguar XF-R - 550hp
2007 Jeep Grand Cherokee - Overland, Hemi (The Anti-Lotus)
Totalled: 2011 Lotus Evora 2+2 - Canyon Red Metallic
Sold: Saab 9-3C, MGB, Miata, Merc 560SEL, F-150, Civic, Saab 9-5SE, '05 Ford-GT, '69 Cad Sedan DeVille, Triumph Daytona 955i
Lckitty is offline
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Lotus Evora > Evora How-to's
