-   Suspension (including wheels, tires, brakes) (https://www.lotustalk.com/forums/f91/)
-   -   BMW Wheel Bolts = Perfect Fit! And they are Black! (https://www.lotustalk.com/forums/f91/bmw-wheel-bolts-perfect-fit-they-black-6109/)
Stan 09-22-2004 02:10 PM
Most BMWs use 12 x 1.5 moderate length wheels bolts with a 17 mm hex head. They have some nice black one for roughly 4 bucks apiece at full tilt retail. They are much less via mail order.
I don't think the Elise wheels are much of a theft target and don't like the spline and wheel lock set up. For staying stock, maybe an all-spline approach would work well. Some of the spline bolts have a crummy fit with the supplied tool. The tool can be tough to remove.
It turns out that E30/E36 and other BMW wheel bolts are a perfect match. Same underhead shape and angle, same thread, same grade of metal, same length, better finish.
Here is a black one compared to a stock spline drive bolt.
http://www.pbase.com/image/34132615/original.jpg
http://www.pbase.com/sjmarcy/image/3...2/original.jpg
They fit fine and a standard 17 mm socket clears everything no problem.
Stan 09-22-2004 02:22 PM
For reference the black bolts are BMW PN:
36-13-1-095-390 "213E Wheel Bolt"
shay2nak 09-22-2004 02:33 PM
cool! all we need now are the black rims these bolts are going to hold in place!
MattG 09-22-2004 02:38 PM
Just curious, how do you know they're the same grade of metal?
Bolts that may look identical may vary a lot in their strength (there is a grading system specifically for this). One could assume that Lotus and BMW would both use high grade bolts for a critical application like this, but remember, it'd be an assumption.
While I think the risk of any failure is low, it's important that people recognize that the risk exists.
EDIT - maybe I see how you recognized the bolt grades. The Lotus one clearly states it's a grade 10.9 bolt; I assume the BMW one has a similar marking?
perryeyges 09-22-2004 02:50 PM
I'm pretty sure the BMW bolts that are designed for a
4 to 5 thousand pound car are going to be plenty strong
for a 1,900lb car...
Can you weigh each lug bolt and give us figures?
atyclb 09-22-2004 03:03 PM
BMW bolt = 66g
perryeyges 09-22-2004 03:05 PM
And the Elise bolt weighs_____________?
atyclb 09-22-2004 03:12 PM
I wish I had one :(
(actually I wish I had 16)
Ground Loop 09-22-2004 03:17 PM
Originally posted by atyclb
I wish I had one :(
You get 12 free with each Elise!
And four lock bolts. :)
Stan 09-22-2004 03:27 PM
The BMW and Lotus wheel bolts are of the same grade, 10.9. The BMW bolts are not marked as they are not a generic, they were made for their particular application. Properly torqued, either is fine on their own cars. If you track your car a lot you can replace your bolts yearly for some peace of mind. Or convert to studs, even better.
The BMW bolts appears to be a hair lighter, using my calibrated fingers....but a scale would be a better source!
Stan 09-22-2004 03:30 PM
Oh BTW, if you want to keep the black finish perfect, you need to use lined sockets. They have a thin nylon inner surface so that metal to metal contact is prevented.
NMRJock 09-22-2004 04:17 PM
Oh, THAT kind of splined lugnuts...
In another thread I mentioned splined lugnuts as an alternative to the stock Elise lugnuts. The type I was talking about had splines on the outside that you fit a special tool over to remove. The nice thing is that the tool is about 6" long and so you just use it instead of an adapter on the breaker bar. You get a really nice positive bite on the lugnut to torque them too. Now I see that the Elise uses lug bolts, so none of that ends up mattering...
Stan 09-22-2004 05:12 PM
BTW you can't quite see it in my PIC above, but the manufacturer of our spline bolts is Bimecc. Here is their web site: http://www.bimecc.it/
Stan 09-22-2004 05:39 PM
Okay, using a postal scale that only goes down to 0.1 ounces:
BMW: 2.2 ounces per bolt
Lotus: 2.6 ounces per bolt
I think that the large spline head adds some extra mass. Also, the finish and certain characteristics of the threads appears to be a bit better on the BMW items to this set of eyes. You can see some of what I mean in the posted pics...look at the finish of the head ODs, and look into the threads themselves.
James A 09-22-2004 07:39 PM
Bavarian Autosport has the lug bolts in both silver and black for $2.95 each, part numbers 36 13 1 126 191 for silver and 36 13 1 126 014 for black. www.bavauto.com
Also locking bolts are availabe from BMW that use a small key and are around $45 for four, also Bavarian Auto haas some other locking ones shown that look much better than the stock Elise, they are $45 for the set of four.
shinoo 09-22-2004 08:08 PM
Thx! Excellent info guys. I'll make the switch on my car. Here's a couple of pix of the key we broke when testing the SSRs+Hoosiers.
http://www.elisetalk.com/photopost/d...brokenkey2.JPG
http://www.elisetalk.com/photopost/d...7brokenkey.JPG
ConeFusion 09-22-2004 09:48 PM
No wonder, that doesn't look like something that would survive many wheel changes. Excellent info on the BMW bolts, Stan!
Lotus Fury 09-23-2004 01:25 AM
So I'm assuming that my wheel pins from my M Roadster would work. Awesome, those things are nice for putting on the wheels. Guess I won't be selling those.
I have a co-worker that makes wheel pins. Not sure of the price but if you guys want them I'll ask him.
Stan 09-23-2004 02:23 AM
>>>So I'm assuming that my wheel pins from my M Roadster would work. Awesome, those things are nice for putting on the wheels. Guess I won't be selling those. <<<
Sure, they will fit just fine. Along with aftermarket wheel stud kits. BBS makes nice ones in various lengths. TC Kline has a nice set with a bullet tip that is useful besides looking nice. There is ample room on our wheels for 17 mm socket clearance.
Alloy studs:
http://tcklineracing.com/TCKStudsStd.gif
Bullet / Rounded tip steel:
http://tcklineracing.com/tckrprostud-modified.jpg
Alloy nuts for studs, black anodized too. For those items noted here see: http://tcklineracing.com/wheelstud.htm
Stan 09-23-2004 02:28 AM
>>>Bavarian Autosport has the lug bolts in both silver and black for $2.95 each, part numbers 36 13 1 126 191 for silver and 36 13 1 126 014 for black. www.bavauto.com Also locking bolts are availabe from BMW that use a small key and are around $45 for four, also Bavarian Auto haas some other locking ones shown that look much better than the stock Elise, they are $45 for the set of four.<<<
Chrome and bronze are also available for fashion conscious types... As are natural and black anodized aluminum nuts for stud conversions.
Some BMW folks like these particular wheel locks because when you screw on the protective cap, they look stock. The caps come in silver or black. Good ole McGard is available anywhere for BMW and is endorsed by Tire Rack.
http://www.pbase.com/image/34152121/original.jpg
