BMW Wheel Bolts = Perfect Fit! And they are Black! - Page 10 - LotusTalk - The Lotus Cars Community
 1Likes
post #181 of 199 (permalink) Old 07-26-2017, 08:39 AM
Originally Posted by zender View Post
I actually have both the key you could borrow and the BMW bolts (somewhere) if you'd like to just have them assuming I can find them. I previously ran the BMW bolts before switching over to studs there is nothing wrong with them other than they could use a fresh coat of paint. I'm located in Columbus Ohio so let me know where you are and if you still need to borrow the tool.
Sweet! I will gladly buy them off of you! I am in Lewis Center, so I can come to you anytime. If you PM me, can i reply even though I haven't had 5 posts yet?
edit: p.s. Buy the BMW bolts, borrow the 10-point Lotus wheel bolt tool. Thx!
W.
Wallace is offline
post #182 of 199 (permalink) Old 07-26-2017, 09:20 AM
zender's Avatar
W.
Can't pm you as you havent posted enough....Maybe it's time for an introduction thread and some pics from you that would help your numbers. Can't remember if it's 5 or 10 posts.
zender is offline
post #183 of 199 (permalink) Old 07-26-2017, 02:28 PM
If you need BMW lugs bolts PM me. I have quite a few new car take off. I work at BMW dealer.
bofusric is offline
post #184 of 199 (permalink) Old 07-27-2017, 11:54 AM
Ok! Time to spam the forum... (j/k) Will PM after I reach the quota. =)
Wallace is offline
post #185 of 199 (permalink) Old 08-11-2017, 03:31 PM
zender's Avatar
@Wallace finally found the bolts...If you want them they are all yours ..... I'm going to this tomorrow and can bring them along if you want to meet up. Let me know.
Columbus (OH) Cars and Coffee August 12 10am-12pm (Nationwide Arena)
https://r.tapatalk.com/shareLink?sha...3&share_type=t
zender is offline
post #186 of 199 (permalink) Old 08-14-2017, 09:13 PM
Oh snap I saw this a couple days too late... we were in the middle of moving to a new office, so I was swamped (and will likely be swamped) this whole month. I need to pay more attention to the next meet up!!
Cheers,
Wallace
Wallace is offline
post #187 of 199 (permalink) Old 08-15-2017, 03:46 AM
zender's Avatar
Cheers,
Wallace
Maybe you can make this one??
"Must be this tall to ride" drive thru Hocking Hills (Sept 17th 2017)
https://r.tapatalk.com/shareLink?sha...6&share_type=t
zender is offline
post #188 of 199 (permalink) Old 08-18-2017, 06:03 AM
Hum, sounds like fun! I have to check my schedule but that's a distinct possibility. :-D
Wallace is offline
post #189 of 199 (permalink) Old 07-20-2018, 11:03 AM
just verifying, since part #s and such have changed over the years.. are you guys using 36-13-6-781-150 ?
Beemerb0y is offline
post #190 of 199 (permalink) Old 07-26-2018, 06:09 AM
Ttt for quick answer
post #191 of 199 (permalink) Old 07-30-2018, 09:36 AM
can anyone confirm part #?
also are these any longer bolts by chance? will be fitting 5mm spacers more than likely, and would prefer a longer bolt to go with it
post #192 of 199 (permalink) Old 07-30-2018, 01:10 PM
He's on fire!
jds62f's Avatar
also are these any longer bolts by chance? will be fitting 5mm spacers more than likely, and would prefer require a longer bolt to go with it
fixed that for you
jds62f is offline
post #193 of 199 (permalink) Old 07-31-2018, 08:47 AM
Part number is correct. Good pricing and service at FCP Euro:
https://www.fcpeuro.com/products?keywords=36136781150
Same length as stock and not enough thread engagement if a spacer is fitted.
Turner Motorsport has black ones in several lengths for use with spacers:
https://www.turnermotorsport.com/p-3...-2012-bmw-mini
Beemerb0y likes this.
andreas2 is offline
post #194 of 199 (permalink) Old 09-05-2018, 10:49 PM
Thanks for the info
The normal set is listed as a 28mm bolt
The “compatible with 5-8mm” spacer set is listed as a 32mm bolt
If the lotus bolts are 19mm, would 28mm pose a problem (ie: too long, interfere with brakes, hit something, etc?)
Also, if 28–>32 is only 4mm longer bolt, why does it list it being compatible with a 5-8mm spacer? Just want to make sure it doesnt come short
post #195 of 199 (permalink) Old 09-07-2018, 10:23 AM
The Elise/Exige bolts are 25mm, not 19mm. I used to run the 28mm bolts from Turner Motorsports in the rear without spacers, no issue. The Lotus bolts are barely long enough to begin with.
I had the 35mm bolts in the front with 6mm spacers, but would go with the 32mm option for 5mm spacers.
andreas2 is offline
post #196 of 199 (permalink) Old 09-07-2018, 11:56 AM
Mad MaTTer's Avatar
Thanks for the info
For a 12x1.5 bolt you need at least (1X)Dia. or 12mm of thread engagement equating to 8 full turns. This is why some bolt lengths work both with and without the use of spacers.
So if you're using aftermarket wheels and/or wheel spacers make sure your current bolts are engaged at a minimum of 12mm (8 turns).
That said, I work with aircraft and rule of thumb for aviation is 1.5(dia).
Mad MaTTer is offline
post #197 of 199 (permalink) Old 09-11-2018, 02:27 PM
hmm ok, that makes more sense. I could have sworn i read on LT the stock bolts were 19mm
I went ahead and ordered 28mm bolts for my non-spacer wheels, and 32mm bolts for my 7.5mm spacer wheels
from my experience with e46 M3, in the rear the E-brake would pose issue with a longer bolt- front you might be able to get away with it, but there is a hub ring and speed sensor you have to be mindful of
post #198 of 199 (permalink) Old 10-13-2018, 09:21 PM
chiarov's Avatar
Thanks for the tip on these! I've been running my OEM ones since 2005 with probably 15+ trackdays, probably long past time to swap them out. Just ordered the BMW ones from FCPeuro.com.
I notice eliseparts.com also carries the OEM ones, but the shipping to the US is as much as the bolts!
2012 Porsche 991.1S white
2014 Audi Q5 3.0T scuba blue
chiarov is offline
post #199 of 199 (permalink) Old 10-14-2018, 04:32 AM
CrimPhoenix's Avatar
I just recently had the wheels off my 2008 for the first time and all of the stock bolts were seized. Each one was a fight and it took 5 spline adapter/tools to remove all the lugs, so we replaced them with the black BMW ones noted in this thread with no issues.
I do like that the Evora lugs separated the cone portion of the collar from the actual lug, instead of it being one piece so even if it seized you could still remove the wheel.
CrimPhoenix is offline
