BWR Extended Ball Joints - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By jdawson
post #1 of 13 (permalink) Old 09-03-2016, 06:36 PM Thread Starter
jdawson's Avatar
I purchased these because I wanted to lower the front end of my Elise without having to reduce the length of the damper bodies. At stock ride height, they were already at the lower end of the spectrum for compression stroke. Lowering the car ~20mm would put them well into the bump stops over reasonable bumps.
In the box, 2X of these sets:
If you've worked on the suspension previously, tear down is straight forward. A ball joint separator like this one from Harbor Freight will be your friend when separating the lower ball joints. I also installed machined steering arms at the same time, so I separated upper, lower and steering ball joints.
With the lower arms accessible, remove them and use a press or keep them installed in the car and use a bolt-together-style removal tool... like this one. Installation is just the reverse of the process.
Installed:
Boot install is easy:
Inner view of the spindle assembly:
Lower view of the ball joint:
While the ball joints lower the front end about 25mm, I installed stiffer springs at the same time... so I was guessing at the ride height.
Here's a shot of the coilover assembly and remaining compression stroke remaining with a ride height of 100mm:
I'll likely raise it about 10mm for a final ride height of 110mm.
exigeams likes this.
2006 Lotus Elise
jdawson is offline
post #2 of 13 (permalink) Old 09-03-2016, 08:38 PM
Elise Guru
fzust's Avatar
Lookin' good, JDawson!
Winning Suspension
6UL wheels
fzust is offline
post #3 of 13 (permalink) Old 01-06-2017, 12:56 PM
Are there more people who installed these and can share some experiences?
I'm running a European VX220/Speedster and the front wishbone kinematics are even worse than the S2. (Elise S1 wishbones with S2 uprights + taller front wheels...)
Speedytec is offline
post #4 of 13 (permalink) Old 01-13-2017, 03:41 PM
ERDoc74's Avatar
I just had these installed at BOE... Haven't really had a chance to drive the car on some fun roads yet due to weather however... I'll post impressions after I get a chance to evaluate.
2006 Graphite Grey Lotus Elise: BOE Fully built Long Rod Race motor with Solid Ferrea rockers, REV400 SC, Custom mounted BOE Front HEX.. Penske SA's , BOE CF Rear clam, Exige front clam + LOTS of other mods
ERDoc74 is offline
post #5 of 13 (permalink) Old 02-27-2017, 10:06 AM Thread Starter
jdawson's Avatar
Update: several hundred miles of driving and a sopping wet Laguna Seca track day on these joints. Everything feels great - no slop, low friction, & accomplished what I wanted.
2006 Lotus Elise
jdawson is offline
post #6 of 13 (permalink) Old 03-02-2017, 02:45 PM
So... besides the low friction etc., how did these exactly improve your track day driving??
I see the advantage with the straigther lower wishbone, but I'm hesitating with these because the top wishbone is still in the original position...
post #7 of 13 (permalink) Old 03-02-2017, 03:16 PM Thread Starter
jdawson's Avatar
From the first post: I purchased these because I wanted to lower the front end of my Elise without having to reduce the length of the damper bodies. At stock ride height, they were already at the lower end of the spectrum for compression stroke. Lowering the car ~20mm would put them well into the bump stops over reasonable bumps.
Regarding the upper control arm comment:
The roll center is determined by the intersection of multiple lines of action (upper control arm, lower control arm, and contact patch through the point of intersection of the arms). By lowering the position of the outer lower control arm joint, you raise the roll center.
2006 Lotus Elise
jdawson is offline
post #8 of 13 (permalink) Old 03-02-2017, 07:25 PM
Elise Guru
fzust's Avatar
Jdawson is correct. The reason we did this is that when you lower the car too much(not much in the front) the roll center goes below ground which causes a reverse weight transfer. In technical terms, it handles like crap. Raising the front roll-center makes the car handle properly. The upper only affects camber gain and short of stupid levels it isn't an issue. Our XP car handles pretty well and it is pretty low....
Winning Suspension
6UL wheels
fzust is offline
post #9 of 13 (permalink) Old 05-07-2019, 04:31 AM
BWR extended ball joint dimensions
I never received a reply to my inquiry at BWR. I'm looking for dimensions to find out if fitment of the extended ball joints is possible on the Esprit.
Any help is greatly appreciated.
Lee
Esprit Aviation is offline
post #10 of 13 (permalink) Old 05-08-2019, 05:32 AM
Elise Guru
fzust's Avatar
Lee
Sorry Lee, I will get back to you today.
Winning Suspension
6UL wheels
fzust is offline
post #11 of 13 (permalink) Old 05-08-2019, 07:00 AM
how many are in the set? - Compared to the stock ones they are really pricey if it is a single price :O
Do they replace all 8 balljoints ?
ManuelG1986 is offline
post #12 of 13 (permalink) Old 05-08-2019, 08:25 AM
eldonz's Avatar
You just replace the lower two front ball joints.
Later,
Eldon
eldonz is offline
post #13 of 13 (permalink) Old 05-09-2019, 05:15 AM
Elise Guru
fzust's Avatar
These are custom machined both the cup and ball stud for the Lotus. The studs are made out of 4340. A proper race part for a proper car with low build numbers to go racing. Want dirt-cheap(in terms of price, quality, and service) bolt ons ? Get a civic.
Bump! For great guy, JDawson!
Winning Suspension
6UL wheels
fzust is offline
