Cup car wheel sizes - Page 2 - LotusTalk - The Lotus Cars Community
 9Likes
post #21 of 39 (permalink) Old 08-01-2018, 05:32 PM
VisualEchos's Avatar
Originally Posted by shinoo View Post
I don't believe any tires have been developed that strike the same raod/track balance as r-compounds.
I didn't see anyone mention a track.
2006 Exige
VisualEchos is offline
post #22 of 39 (permalink) Old 08-01-2018, 05:36 PM
DannyGT's Avatar
I might be new HERE, but these endless tire discussions run rampant on every forum. I'll make a couple of points and the op can make his decision, but first...
Lets get real people...
These oem tires (the R rated Advans) are a complete waste. NO, they weren't put on the car(s) because it was the only tire. These, JUST LIKE the Cup2's and Trofeo R's are designed so manufactures can run certain lap-times, around certain tracks and brag that they did it on a street legal/dot tire that can be purchased with the car. Its also why they are WAY over priced. Its a very specific niche. That's it...nothing more, nothing less. Its a street legal dot R...Bam, done! (for the most part, you get it, I hope)
Moving on. You've essentially got two options. R888R's or a few different nearly-as-good extreme street tires. My current favorites are the RE series. I had both RE11's and RE71R's and they are as good or better than R888's, 8 out of 10 laps. This is a FACT! Not opinion. FACT! R888R's however are a new block tech with stiffer sidewalls and give warnings MUCH earlier than its predecessor and also don't fall off nearly as quick. They are really good.
So which to get? You have the cup wheels so you're in the acceptable range of a 205/45/16 and 245/40/17 in the RE71R's...Get those and don't look back. If you aren't tracking it, getting the 8R's to temp might be a problem. Canyon carving and still having double the tread life + better wet is reason enough to stick to those. I know plenty of people who run 888R's all the time, and its fine, but the margin on the track is so close between these two in HPDE events, that on the street, it should be easy to see why the 71R is the better choice. I don't think people realize how sticky these 71Rs get, they are an incredible tire.
Just run slightly lower psi levels and you're golden.
jlj3394 likes this.
2007 Lotus Exige S - Aspen White
DannyGT is offline
post #23 of 39 (permalink) Old 08-06-2018, 08:47 AM Thread Starter
lotuscupcar's Avatar
Thank you kindly
I don’t drive at all in the rain
Originally Posted by TedR View Post
There are a lot of people running larger sizes than stock on LSS wheels. I would recommend upsizing from stock on cup wheels. If I were to be shopping for southern california canyon carving tires for cup wheels I would likely get Hankook RS-4 in 205/45/16 and 235/45/17 sizes. Bridgestone RE-71R would also be high on the list.
These newer generation 200TW tires are almost as grippy as R compound tires but they do not suffer from heat cycling as bad as the R comps do.
I would not buy Toyo R1R tires unless you are shopping for rain tires. They are an old technology and will wear out a lot faster than the newer 200TW tires without providing as much dry grip.
2007 Chili Red Elise
2009 Chrome Orange Exige S260
lotuscupcar is offline
post #24 of 39 (permalink) Old 08-06-2018, 08:53 AM Thread Starter
So in the RE71R, will have to go wider to 245 then
Thank you for the recommendation
Lot to sort through for me
post #25 of 39 (permalink) Old 08-06-2018, 11:19 AM
DannyGT's Avatar
The minimum rim spec for the 245/40 is 8" if I remember correctly, and I think thats what you're using. Just double check. Otherwise, I believe your wheels fits the 205/45 and 245/40 great.
DannyGT is offline
post #26 of 39 (permalink) Old 08-06-2018, 12:41 PM
Originally Posted by VisualEchos View Post
There you go again, thinking my Lotus is driven like my TL. But I wouldn't know anything about driving because I don't have canyons near my house, right?
Think again bro.
The thing is, the A048 is really a competition tire. Yes, you can drive it on the street back and forth to competition, but it's not a good street tire at all. Not nearly as good as say an RS4, AD08R, or RE71R. What do I mean by that? Well, it doesn't last nearly as long, it doesn't handle rain as well, and gets hard much quicker.
Now, if the average Elise/Exige buyer spent 80% of their miles on the track and 20% on the street, I'd side with Lotus here too. Unfortunately, it's the other way around.
Lotus chose the A048 because they had little else to choose from, PERIOD. And the same rings true today...because of the 16" front wheel choice.
But you go ahead and live your canyon life in 2004 Shinoo, I know you like it there .
@shinoo @VisualEchos We don't like it when Mom and Dad fight.
addliteness is offline
post #27 of 39 (permalink) Old 08-06-2018, 01:18 PM
I'm NOT fighting with Shinoo! Just a difference of opinion.
addliteness likes this.
2006 Exige
post #28 of 39 (permalink) Old 08-07-2018, 02:03 PM Thread Starter
So my local guy said will match tire rack price
Went to his store to install
All the tires had a 04/16 date code
Didn’t want two year old tires
Will tirerack have newer manufactured tires ?
post #29 of 39 (permalink) Old 08-07-2018, 04:26 PM
TireRack has been known to sell some older tires, but by all accounts they are stored properly, so it's usually fine if you're not running a comp tire. Does your local place store them properly as well?
You can request new date-code tires from TR, just call when you make the order.
2006 Exige
post #30 of 39 (permalink) Old 08-07-2018, 04:43 PM
Formulabob's Avatar
Didnít want two year old tires
Going through something similar with Discount Tire Direct. Fronts and rears came from different warehouses ó fronts date code 0616 from Georgia and rears 4917 from Ohio. Had a very good discussion with Customer Care rep and they are replacing the fronts with more current date code tires. Customer Care was great; hopefully, the Ohio warehouse will follow through ó will know when UPS delivers on Thursday.
Talk to a human at Tire Rack or Discount Tire Direct, donít just order via the web sites. Without direction to the contrary, a warehouse most likely will FIFO tires which for RE71s can be early 2016 production.
Bob L
2008 Solar Yellow Exige S240 (Torque 300)
1991 Elan M100
2015 Cayman GTS
2016 Ford Flex--Tow Vehicle
Formulabob is offline
post #31 of 39 (permalink) Old 08-07-2018, 05:36 PM Thread Starter
Didn’t realize I can request new date codes
I will then order on the phone
Tire installer said since I get little miles on the car, that my tires expire with time before mileage, so he returned the ones to the warehouse
Appreciate the help as always
post #32 of 39 (permalink) Old 08-07-2018, 05:38 PM Thread Starter
Thank you Bob
I have bought through discount tire before for my other vehicles
Sometimes their deals are great
What did you order through them if you don’t mind me asking ?
Did you do the 205/245 re71? Locally someone told me they trim the inner plastic liner for the 245. My 235s haven’t had any issues
Thanks
Going through something similar with Discount Tire Direct. Fronts and rears came from different warehouses — fronts date code 0616 from Georgia and rears 4917 from Ohio. Had a very good discussion with Customer Care rep and they are replacing the fronts with more current date code tires. Customer Care was great; hopefully, the Ohio warehouse will follow through — will know when UPS delivers on Thursday.
Talk to a human at Tire Rack or Discount Tire Direct, don’t just order via the web sites. Without direction to the contrary, a warehouse most likely will FIFO tires which for RE71s can be early 2016 production.
Bob L
post #33 of 39 (permalink) Old 08-08-2018, 08:24 AM
Formulabob's Avatar
Thank you Bob
What did you order through them if you donít mind me asking ?
Did you do the 205/245 re71? Locally someone told me they trim the inner plastic liner for the 245. My 235s havenít had any issues
Thanks
My RE71 order was for the Cayman. On my Exige, I run Hoosier A7s 205-45x16 and 225-45x17. Published specs show the 205 A7 to be wider section and tread than RE71 205. Using my S260 rims (same as you?), only change at the front is headlights removed ó probably not necessary but I did it for peace of mind.
At the rear, the 225 Hoosier and 245 RE71 are essentially the same section width and again more tread width for the Hoosier. I have to run a 5 mm spacer to get the Hoosier away from the Penske shocks and the carís frame rail then remove the side marker light assembly (cover the hole with reflector tape) for outside clearance. This is with monoball suspension bushings. With stock rubber bushings, rubbing the inner fender liner and or frame could be an issue ó not sure for your use but for mine (turn 17 Sebring) it was.
Bob L
1991 Elan M100
2015 Cayman GTS
post #34 of 39 (permalink) Old 08-08-2018, 09:01 AM
Bob L
You might state your F&R camber and ride height specs, as both make a big difference to fitment.
2006 Exige
post #35 of 39 (permalink) Old 08-08-2018, 09:45 AM
Formulabob's Avatar
True,
Front 110 mm, -2.3*
Rear 115 mm, -2.3*
Canít find toe numbers ó front slight toe out, rear slight toe in. Car has Elise Parts GT uprights (16 mm drop) so suspension arms are where a standard car would be at 126/131 mm ride heights. Not sure what is the track difference (and therefore tire clearance effect) associated with use of the EP uprights. It is not a problem for me so Iím not going bother measuring or calculating it. Not difficult to do if you want to.
Bob L
1991 Elan M100
2015 Cayman GTS
post #36 of 39 (permalink) Old 08-08-2018, 10:57 AM
True,
Front 110 mm, -2.3*
Rear 115 mm, -2.3*
Nice.
And quite far from stock
2006 Exige
post #37 of 39 (permalink) Old 08-09-2018, 10:55 AM
Formulabob's Avatar
RE71 Date Codes
Replacement tires for the 0616 date code fronts I rejected (politely, firmly) just arrived. 2118 date codes from their Ohio warehouse ó big attaboy for Discount Tire Direct and their Customer Care agent Tomas.
Bob L
jlj3394 and VisualEchos like this.
1991 Elan M100
2015 Cayman GTS
post #38 of 39 (permalink) Old 08-09-2018, 11:10 AM
Formulabob's Avatar
Nice.
Borrowing from Bill Clinton ó ďI did not have sex with that woman.Ē
VisualEchos likes this.
1991 Elan M100
2015 Cayman GTS
post #39 of 39 (permalink) Old 08-20-2018, 03:12 PM Thread Starter
Tire Rack can’t seem to find any tires newer than 2016.
I don’t want 2 year old tires.
Gotta start again I suppose
