Finally settled on a new wheel/tire combo... - Page 9 - LotusTalk - The Lotus Cars Community
 119Likes
post #161 of 165 (permalink) Old 01-24-2019, 05:31 AM
Originally Posted by Ls1Rx7 View Post
Originally Posted by VisualEchos View Post
17 x 8.25 +25 with a 215 works perfect with -2.5, but that's a bit on the far end.
Better would be 17 x 8 +25 with a 205 and -1.9 IMO.
16 x 7.5 +25 with a wide 195 is probably the best of all worlds.
I don't bother with 15's and 225's, but you can calculate it from the OD of the 215 on the 17 I mentioned first.
The 15s would be for the track, so getting as much front tire is important in that scenario
If you want track wheels, the XXRs shouldnt be the ones. Get something lighter that bolts right up without all these modificiations (spacers, hub rings) plus these low offsets will likely rub
Beemerb0y is offline
post #162 of 165 (permalink) Old 01-24-2019, 09:14 AM
Not to get too far off topic here but per my last post I was asking about general fitment for the front in relation to a different set of wheels, the Advanti storms which are 11lbs up front:
How about up front?
I'm looking at these wheels with 235s out back and the 215s up front per your suggestion, and I'm at stock ride height and have camber maxxed out all the way around with V2 arms so it should fit,
but I'm considering a second set of rims for racing (Likely the advanti Storms in 15/17 sizes with 225/45/15 up front and 255/40/17 out back) which supposedly fit, but I'm not sure they're the perfect offset.
Front is 15x8 +25 and Rear is 17X9 +45
I was asking @VisualEchos because he had mentioned what the pefect rear fitment is, and I figured it would help the thread if I ask what the perfect front fitment is as well, and he probably has more experience fitting different wheels than anyone else on the board.
Ls1Rx7 is offline
post #163 of 165 (permalink) Old 04-16-2019, 06:13 PM Thread Starter
VisualEchos's Avatar
Just saw this.
First, the XXR's aren't much heavier than the OEM Y-Type wheels that came on the Cup cars...so the weight isn't really an issue. Secondly, they do not require spacers, nor do hub-rings make any difference because most after-market wheels require them (they are all made larger to accommodate many different hubs). Lastly, if a person is willing to run the proper sizes, tires, and camber, there will be no rubbing.
Front: 17 x 8.25 +25 with 215/40/17 @ -2.5 camber
Rear: 17 x 8.25 +25 with 235/40/17 @ -2.7 camber
All cars are a little different, but many guys have run this set-up without rubbing.
Also, if there was any rub it'd be in the front, so a 205/40 could be used without issue and correct it easily.
The -2.5 & -2.7 camber settings aren't required, more like -2.2 front and rear, but the 2.5/2.7 is a very good street set-up.
2006 Exige
VisualEchos is offline
post #164 of 165 (permalink) Old 04-17-2019, 10:50 AM
Butters's Avatar
Just saw this.
Hold on a goddamn second while I get you a microphone so that you may drop it.
2007 SUZUKI SV650 Track bike.
Butters is offline
post #165 of 165 (permalink) Old 04-17-2019, 01:54 PM Thread Starter
Just a little clarification for those future readers.
2006 Exige
