Front End Grip Question - Page 2 - LotusTalk - The Lotus Cars Community
 1Likes
post #21 of 30 (permalink) Old 10-20-2018, 04:52 PM
Addict
LostPawn's Avatar
Originally Posted by boxerman View Post
I would suggest trying a little more tire pressure up front, sometimes its the simple things.
Before the OP even tries this, he needs to know his hot tire pressures. I reread the first post, I think the cold rear pressure is too high, but you need to know hot pressures to make worthwhile adjustments.
I am also unsure of the OP’s track experience. Someone in the right sear can be helpful to not only instruct but to also feel the car to confirm if adjustments need to be made to driving style or setup.
LostPawn is offline
post #22 of 30 (permalink) Old 10-20-2018, 09:40 PM
Alex Ventura 2's Avatar
Just as others stated, more camber, V2 arms and machined arms. Also, the 15/17 setup seemed to help turn in significantly.
Alex Ventura 2 is offline
post #23 of 30 (permalink) Old 10-21-2018, 03:55 AM Thread Starter
My expereience is pretty limited but I've done several HPDEs and AutoX's over the years.
My thought would be lower tire pressure, like I mentioned only about 10 laps in the car starts sliding more, and it's not hot enough for the tires to get greasy, and I'm driving cleanly, so to me that indicates I'm getting too much pressure.
But yeah at this point I need to start tracking warm pressures at least.
Ls1Rx7 is offline
post #24 of 30 (permalink) Old 10-22-2018, 06:37 AM Thread Starter
Originally Posted by kfennell View Post
I ran RC8 rear and 6 front. I have some new RC8 here I can sell, and will include all the used pads that I have if you want to try some combos.
Thanks for this, I might be looking at this for next season. I've got to make a decision on if I should do the radially mounted calipers.
I might just spend the money and get the smaller (I think it's 38MM) AP caliper out back and do it right.
Ls1Rx7 is offline
post #25 of 30 (permalink) Old 10-22-2018, 07:19 AM
glagola1's Avatar
A surefire way to change dynamics is to adjust rear toe. If you feel the car is stable on entry (trail braking) then adjust to zero or even 1/16 out. Sounds crazy but I've found rear toe to be one of the most powerful tools in the chassis balancing tool box. Also, rake is real important as somebody already mentioned.
How old are your tires? I'm not a fan of the R888.
glagola1 is offline
post #26 of 30 (permalink) Old 10-22-2018, 07:45 AM
kfennell's Avatar
Im not sure about 1/16 out on a track car, if I get below 1/8 in I have a lot of trouble.
No matter how many times you tell people that R888 are not the best and all of the 200TW autocross tires are better they still buy the R888 v0v
kfennell is online now
post #27 of 30 (permalink) Old 10-22-2018, 09:51 AM
glagola1's Avatar
I hear you. I don't run less than 1/4" in (total) on my auto-x car and when I do, it moves around a lot. It's not bad but I can't beat on it like a gorilla, aka: my normal drive mode.
glagola1 is offline
post #28 of 30 (permalink) Old 10-22-2018, 10:50 AM Thread Starter
R888Rs have 6,000 street miles on them and 1 autox and 3 HPDEs on them so far.
2 Full seasons, still showing plenty of tread (For rcompounds). Stored over the winter in 60 degree storage.
Which is why I was curious about if they might be getting close to being heat cycled out just from driving around.
I don't trail brake the car at all, if I did, the back end might start to slide, or the car may still push.
I am open to buying the RE71s next time around. I've heard good things about them, but it seems like (at least on heavier cars) they're easier to get greasy than most of the RCompounds and heavier cars are getting fewer heat cycles than a similar R-Comp.
It seems like all of these tires whether they're new 200 TW street tires or older R-Comps they seem to heat cycle out before wearing out, so the TW rating almost becomes a non factor.
But if guys have run both of them on this platform and like the Re71s more I'll prob pick those up next time.
R888Rs in the rain now are a bit sketchy. I may get 1 more season out of the R888Rs at most, so I'll be looking.
And while I'm looking, also thinking about just going to a 15/17 setup so I can get a 225 up front, and 245 or 255 (whatever I can fit out back). I don't particularly like the look of the Miata wheels or else that would be an easy choice.
Ls1Rx7 is offline
post #29 of 30 (permalink) Old 10-22-2018, 10:56 AM
glagola1's Avatar
Man! No trail braking? How does the car even turn?
glagola1 is offline
post #30 of 30 (permalink) Old 10-22-2018, 12:25 PM
kfennell's Avatar
You are measuring your tire life in SEASONS? RE-71R now last me less then 10 hours now and I am on 50+WHP less then you. I would expect both of those tires to cord before they were unusable from heat cycling. There is a time difference between old and new, but they still drive the same through their life. Not like hoosiers which are like Fast - Fast - OK -OK - 4 more slow - DRIFTCAR.
Again not saying this to be mean, but I suspect that until you get your tire life down to say 15 hours or so you should just be working on using all the tire all the time and ignore the other stuff. I used to ask a lot of the same questions. Have you ever had a coach (not the free/cheap instructors). I was asking one the same stuff and he would never really answer. It's because I was so far from the limits that making changes would have been silly.
jds62f likes this.
