jprockjr - 2009 Lotus Exige S240 (wheel/tire/suspension/brakes) - LotusTalk - The Lotus Cars Community
 3Likes
  • 1 Post By jprockjr
post #1 of 18 (permalink) Old 10-04-2016, 11:11 AM Thread Starter
jprockjr's Avatar
All - The purpose of this thread is to document my different setups on the car. I will cover wheel, tire, suspension, and brakes that I have purchased and experimented with. Hoping this saves folks time and money. A lot of my experimentation came from not finding answers on the internet. I will continue to add information to the thread as I continue to find answers to my questions. I also want a location where I can store my pictures.
Vehicle: 2009 Lotus Exige S240 (4 of 14)
Wheels: OEM/Toybox/TE37SL
Tires: Yokohoma AO48, Toyo R888 (several sizes)
Brakes: OEM S240 BBK, AP Racing 4-wheel BBK
Suspension: OEM Bilstein Track Pack, Fred's Penske 2-way, 500F/700R (stock aero)
I will post pictures and try to be as specific as I can with with the setup. I have not tracked the car with any of these setups. I plan to track the car sooner than later. I weigh ~200 lb and usually have a passenger who weights ~200 lb.
jprockjr is offline
post #2 of 18 (permalink) Old 10-04-2016, 11:30 AM Thread Starter
jprockjr's Avatar
Setup
Wheels: OEM Wheels 16x6 ET+31 Front, 17x7.5 ET+38 Rear
Tires: OEM Yokohoma AO48 195/50/16 Front, 225/45/17 Rear
Note: Vehicle was equipped with Tire Pressure Monitoring Sensor (TPMS).
Picture before purchasing the car
Picture of Delivery
Some of my fav pictures
jprockjr is offline
post #3 of 18 (permalink) Old 10-04-2016, 11:35 AM Thread Starter
jprockjr's Avatar
Setup
Wheels: Outer Plus Toybox Hethel Wheels 16x7 ET+22 Front, 17x8 ET+35 Rear
Tires: OEM Yokohoma AO48 195/50/16 Front, 245/40/17 Rear
Note: Wheels not compatible Tire Pressure Monitoring Sensors.
A friend's photoshoot
Some dyno action:
shay2nak likes this.
jprockjr is offline
post #4 of 18 (permalink) Old 10-04-2016, 11:42 AM
CruzrMM's Avatar
Thank you for taking the time to share this information.
Having a known set of specifications will allow for further extrapolation if slightly different wheels/offset/tire size are considered.
Finally, a reliable reference!
CruzrMM is offline
post #5 of 18 (permalink) Old 10-04-2016, 11:53 AM Thread Starter
jprockjr's Avatar
Setup
Tires: Toyo R888 195/50/16 Front, 255/40/17 Rear
Suspension: Fred's Penske 2-way shocks , 500F/700R (stock aero)
Thought the rear tire sidewall looked small compared to front. So I went to a 255/40. Folks on the forums said it didn't fit. It worked for me. No spacers. Sidewall on R888 also bulged less.
jprockjr is offline
post #6 of 18 (permalink) Old 10-04-2016, 12:03 PM Thread Starter
jprockjr's Avatar
Setup
Tires: Toyo R888 195/50/16 Front, 235/45/17 Rear
Suspension: Fred's Penske 2-way shocks, 500F/700R (stock aero)
Brakes: AP Racing 4-wheel BBK
Rear Toybox wheels do not clear brakes. They required a ~10.8 mm spacer and this leaves about 2 mm of brake clearance. I was forced to downsize tires from 255/40 to 235/45. Wanted a meatier tire. Prob my favorite setup. No rubbing but clearance is tight.
jprockjr is offline
post #7 of 18 (permalink) Old 10-04-2016, 01:06 PM
EricH's Avatar
Thumbs up
Jprockjr,
1) Thanks - if this thread has 1/2 the data as it does beautiful pictures it will be great! Seriously thanks for documenting your experiences.
2) Please Please Please do track your car to verify what works or not. That is the only way to safely test and verify the set up works. Some things might work 99% on the street -then that one bump or that one evasive maneuver will take out your fender/clam or cut the sidewall of the tire.
Click links to see my 2008 Lotus Exige-S 240 , '99 M3, 505rwhp '89 Mustang ( sold) , '05 WRX STI ( sold) homepages or here for my spin compilations (ispunuwin & ispinuwin2!)!
EricH is offline
post #8 of 18 (permalink) Old 10-04-2016, 01:12 PM Thread Starter
jprockjr's Avatar
Setup
Wheels: Volk Racing TE37 SL Wheels 16x7.5 ET+35 Front, 17x8.5 ET+33 Rear
Tires: Toyo R888 225/45/16 Front, 255/40/17 Rear
Note: Did not use Tire Pressure Monitoring Sensors, used Rays stem valves.
Shoutout to member VoiceOfReason for the wheels. Wheels were new unmounted. They were part of this group-buy. The wheels clear the AP Racing 4-wheel BBK. Plenty of brake clearance. No spacers needed front/rear. Volk had specified it would not clear the BBK on the group-buy thread.
jprockjr is offline
post #9 of 18 (permalink) Old 10-04-2016, 01:26 PM Thread Starter
jprockjr's Avatar
Thanks CruzMM. I'm tempted to try 235/45 on the Volk Rear next.
Originally Posted by EricH View Post
Jprockjr,
Thanks. I agree. Hoping to start tracking soon (this year). I have lots of pics so bare with me.
All - Just to be clear, these setups have been tested on the street only. The car drops an additional ~1/2 inch with a passenger and myself. I don't baby the car or slow down for bumps. I like the peace of mind of driving and enjoying the car on the street. So far no issues with the clam on street use only.
jprockjr is offline
post #10 of 18 (permalink) Old 10-04-2016, 02:00 PM
rb26dett's Avatar
Damn it. I regret not buying those volks
rb26dett is offline
post #11 of 18 (permalink) Old 10-04-2016, 07:23 PM
Sig
machine.gun.kelly's Avatar
One of the most import bits of information you have not shared with us is the wheel's offset. Can you update your posts with each wheel's offset? TIA
Whoever said that island life is great was never committed to Alcatraz...
machine.gun.kelly is offline
post #12 of 18 (permalink) Old 10-05-2016, 04:55 AM Thread Starter
jprockjr's Avatar
Added offsets and TPMS info. I also took pictures of parts on a scale to document weight, I need to go thru camera roll.
machine.gun.kelly likes this.
jprockjr is offline
post #13 of 18 (permalink) Old 10-05-2016, 07:12 AM
not your dad's puns
Turbopun's Avatar
Your. Pix. Are. Gorgeous.
Also, awesome shop, yours?
because racecar
Turbopun is offline
post #14 of 18 (permalink) Old 10-05-2016, 11:37 AM
shay2nak
shay2nak's Avatar
dayum, son.
I like the fitment of the Volks.
Do you know the weights?
'07 Lotus Exige S310
WTC 2
shay2nak is offline
post #15 of 18 (permalink) Old 10-05-2016, 11:54 AM
Supporting Vendor
shinoo's Avatar
Excellent pix!
The AP brakes are awesome as we first ran them on our '06 Exige. They stop - RIGHT NOW! It is worth noting that the handbrake is lost when you go with this upgrade.
On track you will rub with your set-up. The wheel well liners (especially fronts) are consumables on a track driven Lotus with lower ride height. Be prepared to raise the ride height a bit at the track.
shinoo is offline
post #16 of 18 (permalink) Old 10-06-2016, 07:24 AM Thread Starter
jprockjr's Avatar
Thanks! It's my home garage.
Originally Posted by shay2nak View Post
dayum, son.
Good question. Thought it was on the GroupBuy thread, but going thru it, I only found an approximate of 11lbs/15lbs. I'll weigh them next time I change tires.
Originally Posted by shinoo View Post
Excellent pix!
http://www.sector111.com/images/prod...poster_SM2.jpg
Thanks Shinoo! Good to know. The Sector111 car in that pic inspired my build. Brakes are awesome despite losing the e-brake like you mentioned. Wish we had a solution. Been thinking of several ideas but haven't had time to test yet.
jprockjr is offline
post #17 of 18 (permalink) Old 10-10-2016, 07:48 AM
JDsales's Avatar
I'm in the hunt for an optimum e-brake solution too, as I have the awesome BBK set up too. Should anyone have an ebrake setup they are happy with, would you be willing to share?
Thanks much!
JDsales is offline
post #18 of 18 (permalink) Old 05-23-2018, 12:43 PM
shay2nak
shay2nak's Avatar
What are your alignment specs on the rear to get the 255s to fit? I couldn't get the right setup with 17x8 +32 Monolites.
WTC 2
shay2nak is offline
