Need tires 205/50/16 front 235/45/17 rear LSS - Page 2 - LotusTalk - The Lotus Cars Community
post #21 of 34 (permalink) Old 05-29-2013, 09:14 AM
Originally Posted by strategery View Post
For R1R's
205/45-16
245/40-17 or 235/45-17
So....the 245/40-17 fit on the rear no problem? Is there any reason I would want to go with the 235's instead of the 245's for Autocrossing? I'm usually all about getting the most tire you can fit, then balancing the car around that.
Thanks!!
Washburn is offline
post #22 of 34 (permalink) Old 06-02-2013, 09:48 AM
Shoof's Avatar
Even though I just replaced my tires with 205/50 front and 235/45 rear (ExtremeContact DW), decided to switch them to 205/45 and back to OEM spec 225/45. At the ride height/damping I am set at, I don't want to worry about rubbing (and a rubbing it was, all around!), even if it's "a little bit" for the streets. Decided to go with Bridgestone Potenza RE11's. If I stayed with OEM sizing for the front/rear, the only tire I would have considered would have been the DWS, but I really don't need the A/S designation. Had them on a set of wheels for my Elise and was fairly satisfied with them, but wanted just a little more...
PS - I already have another set of wheels with R888's on it for track duty (OEM size tires).
'07 Exige S - Graphite Gray
'14 Scion iQ (to park damn near anywhere)
'17 Lexus NX200
'17 BMW M3 6MT
Shoof is offline
post #23 of 34 (permalink) Old 06-02-2013, 10:14 AM
He's on fire!
jds62f's Avatar
you must have purchases the new re-11a tires? the regular re-11 never had a 225/45/17, at least not in the US AFAIK.
jds62f is offline
post #24 of 34 (permalink) Old 06-02-2013, 11:46 AM
Shoof's Avatar
Now you had me wondering! Just checked my order...I have a wholesale account with Tire Rack. They actually are the RE-11's, not the 11a. I bought them on "closeout". They don't show 225/45 listed anymore, might be because I took the last pair, who knows. I did receive the 205/45's already, but haven't mounted them yet because I didn't have time late last week to do it. The 225/45 is coming from a different location, so I should get them this week. I'll confirm, as well as let you know how they fit soon!
'17 Lexus NX200
'17 BMW M3 6MT
Shoof is offline
post #25 of 34 (permalink) Old 06-02-2013, 01:04 PM
He's on fire!
jds62f's Avatar
I was mistaken, I don't remember seeing them but I looked on bridgestone's site and sure enough, 225/45/17 is there.
jds62f is offline
post #26 of 34 (permalink) Old 06-06-2013, 08:35 PM
Shoof's Avatar
All 4 tires received. They are in-fact the RE-11. I will try to mount them (myself) tomorrow, will let you know how it goes!
'17 Lexus NX200
'17 BMW M3 6MT
Shoof is offline
post #27 of 34 (permalink) Old 06-25-2013, 02:38 PM
strategery's Avatar
Thanks!!
I went with 245's because I have a VF2 kit. You don't need 245's if you are normally aspirated.
strategery is offline
post #28 of 34 (permalink) Old 09-11-2013, 08:20 AM
Pat,
Too late now, but supposedly the 235s are the single compound construction... That would make them better than the 245s in my mind...
CDR, USN Submariner
2003 Mazda Rev-it-up 10th Overall
2005 Magnetic Blue Elise LSS/Touring/HT/SS/VF Stage II
1988 Honda CRX Si Bubba!! Serious Autox Car 184 STS
2005 Subaru WRX STi Beater. Fast Beater. Heh.
2007 Mazdaspeed 3
scapamouche is offline
post #29 of 34 (permalink) Old 09-13-2013, 07:49 AM
Originally Posted by scapamouche View Post
Pat,
I ended up using the 245-40 R1R's on the back. Single compound construction does not make the 235's "better"....they will simply last longer. Better, in my book, is more rubber on the ground. (At least for autocrossing, which is all they are used for in my case.) I've heard about the 235's, but have yet to see firm evidence of this....just talk from what I know.
To the original poster, I would also comment that while R1R's are indeed a fantastic tire (among the grippiest available in our sizes) they do wear fairly quickly, which was something you mentioned you didn't want. I know you already decided how to go, just mentioning it.
Washburn is offline
post #30 of 34 (permalink) Old 09-13-2013, 08:27 AM
Older but getting faster
Man of Steel's Avatar
For R1R's
205/45-16
+1
Very happy with them.
2006 Ardent Red Elise
Touring, Star Shield, hard top, remote V1 display and bracket, sun visor delete, micro mirror, shifter fix, Stage II exhaust, de-snorkeled, ITG air filter, Nautilus horn, black LSS wheels, ARP wheel studs, upgraded oil line fittings, ProAlloy radiator, s.s.brake lines, BOE Race Links, Innovative rear motor mount, plastic grills out, all aluminum mesh, Total Oil Control Wet Sump V1.1, s.s. caliper pistons, BWR sway bar, Penske NA coilovers.
Man of Steel is offline
post #31 of 34 (permalink) Old 08-26-2018, 03:50 AM
Stealthy Blackmobile
freshyip's Avatar
Originally Posted by Me! View Post
If you go for 205's get 205/45/16's. If you go with the 50mm sidewall the tire will be too tall and your steering will feel floaty and unresponsive. Trust me!
best advice i got from here
i went with RE71R in:
Fronts 205/45R16
Rears 245/40R17
my car has never felt better; makes me wanna drive all da time !
thanks LT!
"...Make Every Road Your Own....."
2007 Lotus Exige S
freshyip is offline
post #32 of 34 (permalink) Old 08-26-2018, 06:33 AM
VisualEchos's Avatar
Fronts 205/45R16
Rears 245/40R17
thanks LT!
And your wheels are wide enough to support those sizes perfectly.
2006 Exige
VisualEchos is offline
post #33 of 34 (permalink) Old 08-28-2018, 04:59 PM
Me!
6.94915254 lbs/hp
Me!'s Avatar
Fronts 205/45R16
Rears 245/40R17
thanks LT!
Glad my advice helped!
2007 Storm Titanium Exige S w/ sunvisor delete
Me! is offline
post #34 of 34 (permalink) Old 08-28-2018, 08:04 PM
freshyip's Avatar
there appears to be more grip too; you think maybe its becox the front of the car is now lower and the weight is leaning more towards da front????????
2007 Lotus Exige S
freshyip is offline
