Noisy front brakes - LotusTalk - The Lotus Cars Community
post #1 of 5 (permalink) Old 06-11-2019, 11:09 PM Thread Starter
danpalooza's Avatar
Noisy front brakes
Brakes have plenty of life left in them, but after about 10 min of driving and I've had a chance to hit the brakes a few times, they start to make a grinding sound only in the front. This also only happens at low speeds. I've also have heard a few times when I'm coasting slowly, not applying the brakes at all, it sounds like the pads are rubbing against the rotors still (not making a grinding sound but I can hear contact). Maybe the piston needs a little silicone lube? Any thoughts?
danpalooza is offline
post #2 of 5 (permalink) Old 06-15-2019, 11:03 AM Thread Starter
danpalooza's Avatar
Pads have a lot of life left, looks like the outside pad is wearing unevenly. Outside pad looks ok
post #3 of 5 (permalink) Old 06-15-2019, 06:26 PM Thread Starter
danpalooza's Avatar
cleaned out the calipers and put some lubricant on them. They seemed a little more sticky than they should be. They sound is a lot less than it was but is still prevalent. I'm curious if it is just a sticky caliper still. I might need to do a rebuild on the calipers or something.
post #4 of 5 (permalink) Old 06-16-2019, 08:06 AM
`08 Elise-SC-220
3carmonte's Avatar
I had this symptom along with the left front caliper hanging up intermittently. I cleaned thoroughly the piston and boot area's inboard and outboard on both left and right calipers then compressed the pistons with the bleeder screws open. I then bled as you normally would, flushing even more fluid through them than usual to clean-em out. Re-assembled with a little copper-slip on the piston contact surfaces and now it's all in the rear view mirror. Good luck.
3carmonte is offline
post #5 of 5 (permalink) Old 06-16-2019, 10:41 AM Thread Starter
danpalooza's Avatar
I just ordered a rebuild kit. I’ll try flushing the brake fluid thoroughly as well and hopefully that will solve the issue.
