Penske DA Adjustments in the field? - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 05-04-2018, 06:10 PM Thread Starter
Considering getting some Penskes DAs. How much of a PIA are these to adjust in the field? I have Ohlins DA now and can adjust them pretty easily with the car on the ground. I usually only adjust the compression dampening on them and it is super easy but they have a remote reservoir mounted to the lower A arm. How big of a deal is the hand adjuster knob on the Penske? On the Ohlins I have only changed the rebound a couple of times. Anyone have a video of the adjustment process with the car on the ground?
Thanks
Paul
'06 Exige Chrome Orange | NA | Touring | Traction Control | Cup Air Box | FastWorks Torque 200 | PPE Headers | PPE Cat Delete | LBH Racing Raptor Exhaust | Engine Mount Inserts | Penske DA with 600/800 springs | BOE Toe-links | Shaved Steering Arms | Sector 111 Harness Bar | Schroth Harnesses | Shifter Reinforced | DBW Pedals | DIY Clutch Stop | Team Dynamics 1.2's | Sector 111 Ultradisks | BOE TOC Oil Pan | ProRad | Radium Coolant Expansion Tank
lotusninja is offline
post #2 of 4 (permalink) Old 05-05-2018, 06:54 AM
2006 Exige
AZelise's Avatar
While they can be adjusted in the field, it is not 'easy'.
Front and rear rebound knobs can both be reached, but you'll get dirty as you'll be on the ground reaching back behind the wheels.
You can do the front compression by turning the wheels to make it possible to get in there. The rear compression requires jacking up the car a bit.
If you are jacking up the car anyway, it only takes 30 seconds more to take the wheel off and then it is super simple to adjust everything.
BTW, I bought my current '06 Chrome Orange Exige from a guy in Flower Mound Texas in 2011. Do you remember seeing another one there?
AZelise is offline
post #3 of 4 (permalink) Old 05-05-2018, 06:06 PM Thread Starter
Cool thanks, AZelise. So you have the hand adjuster for the rebound? or using the adjuster tool?
I have never seen another Chrome Orange Exige in Flower Mound! Seems odd that I wouldnt have seen it, this town isnt that big.
Paul
post #4 of 4 (permalink) Old 05-05-2018, 07:36 PM
2006 Exige
AZelise's Avatar
Paul
Yes, I have the hand adjusters on front and back for rebound.
I asked because I figured you would have seen my car sometime between '06 and mid '11.
AZelise is offline
