Roll centers - LotusTalk - The Lotus Cars Community
post #1 of 49 (permalink) Old 07-16-2009, 10:23 AM Thread Starter
trompazo's Avatar
Roll centers
Does anyone have the data required to calculate the exact front and rear roll centers?
I'd like to build a spreadsheet that could give the roll center at varying ride heights.
2007 Exige S Krypton Green: 2ubular/FF RaceHeader/Penskes/Hypercoils/Gotham/H20 injection
2006 Corvette Z06: Road Course
2007 Porsche 997 TT: Daily
2004 Lambo Gallardo: Daily #2
1994 Supra Turbo: work in progress
trompazo is offline
post #2 of 49 (permalink) Old 07-16-2009, 10:25 AM
fpitas's Avatar
You guys should talk...
https://www.lotustalk.com/forums/f3/s...ay-bars-73703/
Francis
2006 Chrome Orange Elise: LSD/TC, Nitron SAs with 425/650 springs, BWR 7/8" ("Hardcore") Front Bar, Eliseparts bumpsteer kit, VF Stage 2, 2bular Header + Sport Cat + 8x24 GT3 Muffler, ECU Tune by Jermaine, Smaay's fuel rail, ACT XT clutch, Saikou Michi dual catch can, Moroso pan, Manly's mount inserts & FF Engine Damper
2000 Black Integra Type R - DD: 231,000 miles!
fpitas is offline
post #3 of 49 (permalink) Old 07-16-2009, 10:27 AM
Bender Rodríguez's Avatar
Really you need the slope of the upper and lower control arm and perpendicular distance from there pivot point to there corresponding ball joint.
Bender Rodríguez is offline
post #4 of 49 (permalink) Old 07-16-2009, 11:17 AM
Hey try this
It work as long as all units are consistant
post #5 of 49 (permalink) Old 07-16-2009, 11:20 AM
screen
post #6 of 49 (permalink) Old 07-16-2009, 11:23 AM
For lowering/ raising the vehicle just add/ subtract that amount to the two body points and the sheet should do the rest
post #7 of 49 (permalink) Old 07-16-2009, 01:07 PM Thread Starter
trompazo's Avatar
This is great.
What exactly are we measuring with the M line 1/M line 2/ and y2?
I don't really understand the position result. The position should be in the centerline and not change (assuming the car is flat and ride height are equal on both sides)
trompazo is offline
post #8 of 49 (permalink) Old 07-16-2009, 01:25 PM
I cleaned up the sheet a little more
post #9 of 49 (permalink) Old 07-16-2009, 01:35 PM Thread Starter
trompazo's Avatar
To calculate the roll center, don't we need to measure the point where the "virtual" control arms meet, and then draw a line from that point to the center of the tire contact patch?
The roll center height where that line is in the center axis of the car.
I don't see how you can calculate it without knowing the hub measurements, rim width and rim offset.
Maybe I am missing something here.
trompazo is offline
post #10 of 49 (permalink) Old 07-16-2009, 01:40 PM
This is great.
M1, M2 slopes of the lines
y2 is y intercept of the UCA, I made y1 go thru the origin. You really don’t’ need them there just an interim to get to the final answer.
Position is just the distance from underneath the ball joint to the intersection of the UCA LCA arm vectors. Tells you if its converges away from or towards the center of the car.
post #11 of 49 (permalink) Old 07-16-2009, 01:42 PM Thread Starter
trompazo's Avatar
THe roll center would be the purple dot
The point in the middle of the car where the line from the center line of the tire converges with the line you calculated.
trompazo is offline
post #12 of 49 (permalink) Old 07-16-2009, 01:44 PM Thread Starter
trompazo's Avatar
forgot the pic
trompazo is offline
post #13 of 49 (permalink) Old 07-16-2009, 01:52 PM Thread Starter
trompazo's Avatar
actually, I don't think we need to know the wheel measurements and hub measurements, we just need to calculate it based on the track.
The front track is 1457 mm / 57.4 in and the rear track is 1503 mm / 59.2 in. This may change with different wheel setups but would be easy to calculate.
trompazo is offline
post #14 of 49 (permalink) Old 07-16-2009, 02:11 PM
You just need the ball joint locations and the arm mounting points to the body to get the slope. For the centers height and location from the joint and add in half the tire width and you can get the radius (yellow line). There are some other methods but this will work for instantaneous centers.
post #15 of 49 (permalink) Old 07-16-2009, 02:12 PM
bryanf's Avatar
It's nice to be able to see what the roll center does as the car moves up and down and rolls side to side on its suspension.
Bryan – www.bryanf.com | www.greatwallforum.com
Speed-Wiz Automotive analysis, design, and simulation software
bryanf is offline
post #16 of 49 (permalink) Old 07-16-2009, 04:09 PM
FWIW, this is a very simple exercise to do in a 3D modeling program such as Solidworks. No need for expensive suspension modeling software if all you want to find is roll center migration.
Just draw a 2D sketch and make the control arm, track, and hub geometry constant. Then change the ride height or the roll angle. All of the proper constraints are pretty intuitive once you get down to thinking about it.
If you have a kinematics toolbox like CATIA does, generating graphs of RC migration or camber are just one more step away.
Of course knowing the RC migration isn't very helpful without a fairly good guess at the CG location. That is the key to most of the usefulness :P From there you can even start solving for loads in any suspension member or bushing with almost no more work.
bentheswift is offline
post #17 of 49 (permalink) Old 07-16-2009, 06:11 PM
Just fixed it, now it will give you the roll center your looking for
post #18 of 49 (permalink) Old 07-16-2009, 08:13 PM Thread Starter
trompazo's Avatar
Thanks! That is great.
I will try to get the measurements and positions of the control arms next week when I get the car on a hoist.
One thing though, if one control arm is completely horizontal, the M line is 0 and then it cant calulate anything. I'm not sure why, but it must be possible in some cases to have a completely horizontal control arm.
trompazo is offline
post #19 of 49 (permalink) Old 07-17-2009, 04:39 AM
Yes in that case the height is zero because those lines never intersect. So if the spreadsheet ever comes up with an error than it's zero. I'd have to put in a descent amount of logic for that
Also be careful measuring on a hoist if the wheels move poistion would change some values
post #20 of 49 (permalink) Old 07-17-2009, 09:46 AM Thread Starter
trompazo's Avatar
No, if one control arm in completely horizontal the lines should still cross. They would only not cross if both control arms are horizontal which would not happen.
IN this formula, if either control arm is horizontal it gives an error, so something seems wrong.
In your diagram, the lower arm is completely horizontal and all the lines cross and the roll center is not zero.
trompazo is offline
