Roll centers - Page 3 - LotusTalk - The Lotus Cars Community
post #41 of 49 (permalink) Old 07-28-2009, 09:27 PM Thread Starter
trompazo's Avatar
I need to recheck my measurements. Maybe there is problem. To get accurate measurements I had to add multiple measurements together since things are in the way that prevents direct measurements.
I have found data on another forums that states the front roll center is 40mm off the ground and the rear is 70. I don't know how accurate that info is, buts its not even close to these results.
2007 Exige S Krypton Green: 2ubular/FF RaceHeader/Penskes/Hypercoils/Gotham/H20 injection
2006 Corvette Z06: Road Course
2007 Porsche 997 TT: Daily
2004 Lambo Gallardo: Daily #2
1994 Supra Turbo: work in progress
trompazo is offline
post #42 of 49 (permalink) Old 07-29-2009, 08:57 AM Thread Starter
trompazo's Avatar
These meaurements in the spreadsheet were wrong. I forgot to add something.
These are correct:
Height to upper ball joint 398
Height to lower ball joint 167
However, now the calculated roll center is negative?? I still think something is wrong.
I found this data from another source (I don't know the accuracy):
Lotus Elise
Front suspension
roll centre height 30mm
travel 50mm bump / 60 mm rebound
camber gain in bump 0.31 degrees per inch
frequency 90cpm
KPI 12.0 degrees
Castor 4.25 degrees
Trail 4mm
Scrub radius 10.5mm
Rear suspension
roll centre height 75mm
travel 50mm bump / 70 mm rebound
camber gain in bump 0.45 degrees per inch
frequency 98cpm
Using the spreadsheet, I am getting -3.9mm front an +8.4mm rear. Thats pretty far off from the data above (30/75mm).
trompazo is offline
post #43 of 49 (permalink) Old 07-29-2009, 09:05 AM
Bender Rodríguez's Avatar
These are correct:
Lotus Elise
Front suspension
frequency 90cpm
KPI 12.0 degrees
Castor 4.25 degrees
Trail 4mm
Scrub radius 10.5mm
Rear suspension
frequency 98cpm
Yea I don't know the answer to if the control arm lines intersect on the outside of the on the same side as them then that would automatically give you a negative or below ground roll center, Is that right?
Bender Rodríguez is offline
post #44 of 49 (permalink) Old 07-29-2009, 09:51 AM
fpitas's Avatar
These are correct:
Lotus Elise
Front suspension
frequency 90cpm
KPI 12.0 degrees
Castor 4.25 degrees
Trail 4mm
Scrub radius 10.5mm
Rear suspension
frequency 98cpm
Sure that's not S1 data?
Francis
2006 Chrome Orange Elise: LSD/TC, Nitron SAs with 425/650 springs, BWR 7/8" ("Hardcore") Front Bar, Eliseparts bumpsteer kit, VF Stage 2, 2bular Header + Sport Cat + 8x24 GT3 Muffler, ECU Tune by Jermaine, Smaay's fuel rail, ACT XT clutch, Saikou Michi dual catch can, Moroso pan, Manly's mount inserts & FF Engine Damper
2000 Black Integra Type R - DD: 231,000 miles!
fpitas is offline
post #45 of 49 (permalink) Old 07-29-2009, 11:47 AM Thread Starter
trompazo's Avatar
It could be S1 data.
However, it appears that many preformance cars have roll centers in the 30 to 70mm range.
Based on my data from the control arm positions, even at stock ride height of 130mm, the formula is giving me a roll center below the ground. I still think there is either a problem with some of my measurements, or the forumula is in error.
I do find it odd that the lower control arms are pointed up, even at stock ride heights. That typically is not good geometry, but thats what my ruler said when I took the measurements.
trompazo is offline
post #46 of 49 (permalink) Old 07-29-2009, 12:38 PM
fpitas's Avatar
I remember reading an article somewhere about Lotus having trouble with the Elise oversteering in the design phase, and their solution was to put the instantaneous centers outside the front wheels. That was a while ago I saw that (years) and I wondered if it was true, but it's sounding like it is.
Edit: It would be a relatively easy thing to modify, by making a redesigned steering arm (piece 4) that moves the upper ball joint and outer tie-rod upwards.
Francis
fpitas is offline
post #47 of 49 (permalink) Old 08-05-2009, 07:00 AM
Here we go latest and greatest, let me know how it works.
post #48 of 49 (permalink) Old 02-11-2015, 09:58 AM
Don't know if you still need it Buy I have tried to get the front roll centre from solidworks with the geometry data I have and I think your problem is the upright pickup points position!!..I have estimated them from a CAD file of the upright found in grabCAD, and I get around 30 mm..
G_Carbon is offline
post #49 of 49 (permalink) Old 05-14-2019, 12:49 PM
update
i know this is an old post, but anyone here still working on this subject and has accurate data for the S2 ?
terryob is offline
