Tires after autocross - LotusTalk - The Lotus Cars Community
 2Likes
  • 1 Post By glagola1
  • 1 Post By RoHo
post #1 of 9 (permalink) Old 04-21-2019, 04:33 PM Thread Starter
Spartacus's Avatar
Autocrossed my daily driver 05 mini cooper s and I noticed a build up on my rear RE71R. Anyone have any idea what's going on? It was warm day, I'd say about 65 at the most. Front tires looked normal. Rear tires are older than the front if it matters? I didn't race my lotus because I need to get an alignment done and that's scheduled in two weeks!
Spartacus is offline
post #2 of 9 (permalink) Old 04-21-2019, 05:36 PM
CRG53's Avatar
That looks like you picked up “marbles” on the track. If you don’t know, marbles are chunks of rubber that is shed off the tires as you corner and then left on the track, in most cases off the racing line. If you go off the racing line with hot tires, the tires can look like yours.
Boe REV 300 Supercharger.
Boe DMC Ultimate header.
Boe Clam Hinge.
Boe Pro Alloy Radiator.
Boe TOC wet sump oil pan.
Boe Fuel surge tank.
Boe Oil catch can.
Boe HP fixed rotors with Ferodo DS 2500 pads.
BWR Larini Group B Muffler.
BWR Street/Track Anti roll bar.
Mocal rear mounted oil cooler.
V2 steering arms,
Nitron Singles 425/550.
InoKinetic DS rear toe links.
CRG53 is offline
post #3 of 9 (permalink) Old 04-21-2019, 05:55 PM
Scott M
Molez93's Avatar
OPR... other people's rubber.
Usually a problem on concrete or other grippy surface.
'14 Evora S
'13 Subaru BRZ
'11 BMW X5M
'06 BMW Z4M
Molez93 is offline
post #4 of 9 (permalink) Old 04-21-2019, 06:16 PM
XHILR8N!'s Avatar
Are there black streaks of rubber on the car? Or does that only happen when following a car with race tires that are throwing off marbles?
2005 Elise LRG, track prepped ,
2016 370Z Nismo
2013 Bentley Continental GT Speed 2019 Lexus LC500
XHILR8N! is offline
post #5 of 9 (permalink) Old 04-21-2019, 06:50 PM Thread Starter
Spartacus's Avatar
No black streaks. They do peel off, so it must be rubber debris.
post #6 of 9 (permalink) Old 04-22-2019, 05:50 AM
glagola1's Avatar
Normal. That's what modern "street" tires do. It's just a result of a really sticky tire. I've been auto-xing for about 17 years and you used to see this only on race tires. Since the RE71R and the new BFGs, you see it pretty often.
6TVRs+ likes this.
glagola1 is offline
post #7 of 9 (permalink) Old 04-22-2019, 08:57 PM
Autocrossing 14 years. OPR is right diagnosis. You will also occasionally see the Bridgestones get feathered edges on a hot day where the course setup has lots of turning, forcing the tires to really work hard. Don't worry about it.
SS Lotus Elise likes this.
RoHo is offline
post #8 of 9 (permalink) Old 04-23-2019, 02:27 AM
forkmeupscotty's Avatar
It'll go away on its own if you street drive it.
Or if it annoys you that much, get a heat gun + one of those stainless steel scrapers from home improvement stores and go to town with it.
2001 2JZ-GE
2008 N54B30
2008 2ZZ-GZE
2015 N63B44O1
http://www.youtube.com/forkmeupscotty
forkmeupscotty is offline
post #9 of 9 (permalink) Old 08-28-2019, 07:12 AM
Faster way to clean
If you have it available, there is a faster way to clean those tires and you will never do it the old way again!!
If you have a buddy with a truck or the like. Fill two large coolers with water, go to a flat vacant parking lot and try to pour into a large puddle. then drive said car with sticky tires in a circle through the water, round and round. Usually 6-8 circles at moderate speeds each direction will do the trick. You are essentially wet sanding your tires clean! EASY
Even easier if it rained and you can carefully drive the car to same vacant area by yourself.
6TVRs+ is online now
Similar Threads
Grease streak on my paint after autocross... Chris Mackey Maintenance and Repairs. 6 11-01-2007 09:39 AM
Going After Diminished Value after Auto Accident? cpforyou Other 1 09-27-2007 01:43 PM
7.5K oil change before or after autocross? Tintin Lubricating System 4 06-09-2005 10:22 AM
autocross tires/pressures for S1 Elise dwkoski Suspension (including wheels, tires, brakes) 2 05-23-2005 08:07 PM
Tires and Autocross cantwaitforelise Solo timed events 14 05-04-2004 01:03 PM
