Type of Wishbone/A-arm bushings????? - Page 2 - LotusTalk - The Lotus Cars Community
post #21 of 27 (permalink) Old 09-10-2018, 01:32 PM
acslater's Avatar
Originally Posted by addliteness View Post
What are the thoughts on the Nitron ones? They seem very pricey.
Nitron Racing Shocks,Store,Bearing kits,Nitron Lotus Elise/ Exige Inner Wishbone Bearing Full Kit
GBP359 including 20% VAT seems pretty reasonable to me... and actually cheaper than BWRs set https://www.blackwatchracing.com/product-p/1270.htm
To Canada, no VAT but 50 pounds for shipping
acslater is offline
post #22 of 27 (permalink) Old 09-10-2018, 02:05 PM
He's on fire!
jds62f's Avatar
Originally Posted by yorkadam View Post
I'd like to revive this thread with a question for future me:
I have the later version of the gPan (gPan+ ?)...
Can you just remove the arm by taking off the bracket instead of having to hack at the bolt? I recall when removing my sheer panel that this bracket had four fasteners on it... and seemed like it could just be removed w/ the arm still attached...
I have a gpan 1 and i was able to swap bushings without much effort. I used a small screw jack to push the engine toward the drivers side enough to pull the bolt freely.
jds62f is offline
post #23 of 27 (permalink) Old 09-10-2018, 03:13 PM
kfennell's Avatar
To get that bolt out, just cut it off, then tap in the new one with a hammer.
kfennell is offline
post #24 of 27 (permalink) Old 09-10-2018, 06:18 PM
Me!
6.94915254 lbs/hp
Me!'s Avatar
Crazy idea and it might not work because I can't see what is on the other side, but can you put the bolt in via the other direction so the nut is by the gPan?
2007 Storm Titanium Exige S w/ sunvisor delete
Me! is offline
post #25 of 27 (permalink) Old 09-11-2018, 05:16 AM
Pretty sure the back side is a blind hole. You'd need to remove the gas tank to do anything meaningful - very likely you're already at an interference height. Also since I recently removed with the sheer panel I'd say that route is far less appealing over removing the oil pan.... OR the bracket itself which is held in by four fasteners.... ?
Also FYI they sell gaskets for the oil pan now - so less of a nightmare w/ gray RTV and waiting...
https://www.boefab.com/collections/e...-gasket-2zz-ge
yorkadam is offline
post #26 of 27 (permalink) Old 09-11-2018, 12:16 PM
He's on fire!
jds62f's Avatar
I must not be making any sense. I have a gpan, it was in the way of the bolt in question. I did not remove the pan, i did not remove an engine mount, i did not have to cut anything. With a small screw jack, in 10 minutes was able to remove the bolt easily. Im not sure why you'd approach this problem any other way.
jds62f is offline
post #27 of 27 (permalink) Old 09-11-2018, 04:01 PM
Me!
6.94915254 lbs/hp
Me!'s Avatar
Figured there was a reason it couldn't be done that way, otherwise other people probably would have done it by now!
Me! is offline
