Who's running 2 pot calipers front and rear? - Page 2 - LotusTalk - The Lotus Cars Community
 16Likes
post #21 of 178 (permalink) Old 12-01-2017, 06:27 PM
gstomp06's Avatar
Originally Posted by kfennell View Post
If you don't mind the weight you can just leave the old e brakes attached only by the cable. In that case it is 100% easy.
Otherwise there are some lightweight e brakes you can buy that work with the existing cables easily.
Any idea, what kind of lightweight e-brakes will work with this setup?? I'm going to be doing this as well...and would really rather prefer removing the old rear caliper.
Otherwise I might just re-attach for inspection.
2007 Chrome Orange Lotus Elise
gstomp06 is offline
post #22 of 178 (permalink) Old 12-05-2017, 07:12 PM
LionZoo's Avatar
I plan to do this modification in 2018, but with a hydraulic e-brake setup to avoid mounting two calipers on the rear.
Has anyone actually tested this setup using the same pads front and rear with this setup? Seems to be a lot of conversation that the similar pads add too much rear brake bias, but not sure anyone has ever admitted to actually running such a setup.
2011 Lotus Elise SC Final Edition 15 of 15 - Ardent Red
LionZoo is offline
post #23 of 178 (permalink) Old 12-06-2017, 04:28 AM Thread Starter
He's on fire!
jds62f's Avatar
I've not seen anyone saying same pads front and rear were a good idea, i did not plan to test it out either. I'm running carbotech/gloc pads, so planned on 10/8 or maybe 12/10, and on the street putting the autocross pad on the front and the street pad on the rear.
jds62f is offline
post #24 of 178 (permalink) Old 12-06-2017, 04:41 AM
kfennell's Avatar
I did, it was not good. Way too much rear bias for my liking. I am running the BOE manual brakes now with the bias adjuster and using cobalt XP2 now all around and it's great. My brake sensors failed (thanks ****ty aim) so I don't know what my bias is right now, but I can report back later.
kfennell is offline
post #25 of 178 (permalink) Old 12-06-2017, 07:44 AM
LionZoo's Avatar
Okay thanks. It's just for the longest time everyone repeated that you should have one compound higher in front than rear for the stock calipers, but obviously we now know that's not optimal. I was wondering if the same was happening again.
Do you still think the unpowered brakes are "barely streetable?"
LionZoo is offline
post #26 of 178 (permalink) Old 12-06-2017, 07:49 AM
eldonz's Avatar
If you are referring to "unpowered brakes" as having the option of a balance bar and no brake booster, these cars really do not need a brake booster. I drive my car on the street and it is just fine. You just have to get use to a firmer pedal and a little more pedal effort.
Later,
Eldon
eldonz is offline
post #27 of 178 (permalink) Old 12-06-2017, 09:41 AM
titaniumdave's Avatar
I am made larger diameter rotors(304mm) on the front to help with balance and will try the same compound pads this spring...the set up still fits under the stock wheels, saves about 12 lb. and the increased mass of the front/floating rotors should help with thermal capacity.
2006 Elise with BOE 400 supercharger and some aero mods, CRF floating oversized rotors, MCS single adjust coil overs, CRF exhaust, CRF sway bar w/adjustable link, mono-ball pivots, machined steer arms, baffled oil pan, CRF titanium toe link brace, hardened motor mounts, Ethos wheels w/Yoko slicks
titaniumdave is offline
post #28 of 178 (permalink) Old 12-06-2017, 09:57 AM
glagola1's Avatar
Later,
Eldon
Did you keep ABS with this balancing bar set up? I'm probably going to install one for next season but I'm curious about ABS. I've auto-xed a car without ABS for a few years and accidental lock up was about as common as I'm getting accidental ice-mode now... I'm wondering if I should keep ABS or not.
glagola1 is offline
post #29 of 178 (permalink) Old 12-06-2017, 10:21 AM
sarenar's Avatar
Does anyone know if this setup will fit with 15/16 wheels (Rota Slipstreams)?
sarenar is offline
post #30 of 178 (permalink) Old 12-06-2017, 10:36 AM
eldonz's Avatar
No, I ditched the ABS because of the "ice-mode". The feedback and force required to produce lockup is much better because you don't have a brake booster. The biggest benefit that you are going to see for autoXing is that you will be able really dial-in rear brake bias. When the rear brakes are controlling how the rear tires slow down vs the engine controlling it, you will get addicted to it. When start using the rear brakes to slow down, you don't overload the fronts.
You cannot beat a motorsports ABS system that is dialed-in. Where I find a excellent ABS system is advantageous is when it is taking care of the one tire that wants to lockup but the other three are just fine.
Later,
Eldon
eldonz is offline
post #31 of 178 (permalink) Old 12-06-2017, 10:37 AM
eldonz's Avatar
I believe standard two pot calipers will clear the 15" wheels in the front. The rear is no problem.
Later,
Eldon
eldonz is offline
post #32 of 178 (permalink) Old 12-06-2017, 10:42 AM
glagola1's Avatar
Thanks for the feedback.
glagola1 is offline
post #33 of 178 (permalink) Old 12-06-2017, 10:46 AM
LionZoo's Avatar
Later,
Eldon
What if we're skipping leg day?
I like firmer pedals (stock Elise pedal is too soft for my tastes), but I don't want to feel like I'm going to the gym everytime there's congestion...
LionZoo is offline
post #34 of 178 (permalink) Old 12-06-2017, 10:47 AM
LionZoo's Avatar
P.S. I'm actually thinking of using the Wilwood mech spot caliper as a handbrake. It should still result in some weight savings over keeping the standard iron caliper and allows for me to retain a mechanical brake.
LionZoo is offline
post #35 of 178 (permalink) Old 12-06-2017, 11:12 AM
eldonz's Avatar
The actual pedal pressure required is based on the size of the master cylinders used. You can either go with Phil's recommendation or try a smaller size which would require less effort but create more travel.
I would have to say that it actually requires more effort to push the clutch pedal than the brake pedal.
Later,
Eldon
eldonz is offline
post #36 of 178 (permalink) Old 12-06-2017, 11:44 AM
LionZoo's Avatar
Later,
Eldon
Thanks that's great info.
LionZoo is offline
post #37 of 178 (permalink) Old 12-06-2017, 12:03 PM
Got Parts?
GatorMS_Parts's Avatar
Later,
Eldon
I can verify that Eldon has one of the most insane braking cars I have ever driven in. Once you get the feel for the pedal it is becomes extremely easy to control.
-Dino
eldonz likes this.
GATOR MOTORSPORT
'The Lotus Evora - A Rose of a Different Color'
Authorized Lotus, Rossion, Magnum, and Zenos dealership.
Specializing in Lotus service, parts, and performance upgrades.
"Unrivaled Excellence"
3353 West 96th Street. Indianapolis, IN 46268
(855)-428-6767
www.GatorMotorsport.com
www.LotusParts.com
Click here to take a virtual tour of our facilities!
GatorMS_Parts is offline
post #38 of 178 (permalink) Old 12-06-2017, 01:56 PM
kfennell's Avatar
You get used to the unpowered brakes and it just becomes the norm apparently. I also like it much better with XP2 pads all around, while the first stop is not great they are fine after that and like Eldon said, having the right amount of rear brakes is magical. If you don't have any downforce and street tires the XP3 pads might be enough, but I much prefer the XP2 which make it feel like a formula car does in iRacing.
One thing that noone is talking about here is that you will save $ in the long run with the full setup as well. My pad use has gone down by roughly half at least, though its early to say, it might even be more then that. And if I am using less pad I must be using less rotors?
kfennell is offline
post #39 of 178 (permalink) Old 12-06-2017, 04:09 PM
LionZoo's Avatar
Thanks! The one variable in this equation for me is I might pair them with a set of Frenos...
LionZoo is offline
post #40 of 178 (permalink) Old 12-06-2017, 05:01 PM
sarenar's Avatar
Thanks! It is now on my to do list!
sarenar is offline
