AC blower mod...WAY improving air flow (could be coming) - LotusTalk - The Lotus Cars Community
post #1 of 137 (permalink) Old 08-24-2006, 04:27 PM Thread Starter
Žob's Avatar
So...I'm working on getting details, but it looks like SPAL can supply me with a a different unit to replace the factory setup. It'll push 600CFM vs 400. That should make a NICE improvement. Only issue...it'll draw about 33amps vs 12 amps of the stock setup. Soooo....need some help for some wiring experts. I looked at the diagram.... What is the minimum gauge wire needed for a 40amp run? Could we use the existing harness and just up the fuse rating?
Žob is offline
post #2 of 137 (permalink) Old 08-24-2006, 05:04 PM
Forum Founder
Randy Chase's Avatar
33amps could probably use 14ga, but 40amps will need 12ga. I think some of the primary wiring looks to be around 14ga, but that should be checked.
#somethingwickedthiswaycomes... the new Origin Noble M and the Origin 7
Zenos E10S for Sale! www.zenosforsale.com
There are some very shady dealers in the Lotus business.
2005 Lotus Elise, 1993 MR2, 1995 MR2, 125cc Shifter Kart, Toniq (in build), 2018 Origin 7 (waiting), 2018 Origin Noble M (waiting)
Randy Chase is offline
post #3 of 137 (permalink) Old 08-24-2006, 05:10 PM
If the stock system doesn't use a relay, a relay might be something that might be good to include. This is just a thought and I may be way off base..... http://www.1728.com/project3.htm
Elise #2393 Bordeaux/Biscuit Interior/Touring and Sport Packs/HT/Sport ECU/GPan3/DSBrace/Quantum Black SA Dampers/Lowered, Corner Weighted/Radium Catch Can/HKS Special Edition Exhaust/New "3M" Starshield/WindowTinting. Purchased new 06/01/05.
First in Class 2008 Speed Ventures Lotus Challenge Series, my son as Driver.
Prolene is offline
post #4 of 137 (permalink) Old 08-24-2006, 06:30 PM Thread Starter
Žob's Avatar
Originally Posted by Stan
That's a lotta current...maybe try getting more voltage to the fan first. Check voltage under load, bone stock. Sometimes a better ground or more wire gage really help. If need be give it a power supply voltage boost is what I'd try first. A bit more voltage goes a long way....it's a squared relationship.
How are you gonna get more than about 14 volts though? Most car systems only crank about 14-15 volts....
Žob is offline
post #5 of 137 (permalink) Old 08-24-2006, 06:41 PM
foosh's Avatar
I don't get it. I have a SPAL fan in another custom car that pulls well over 1000 CFM and draws 7.5 amps. What the heck kinda fan is that?
foosh is offline
post #6 of 137 (permalink) Old 08-24-2006, 07:55 PM
habendanio's Avatar
So how do you plan to step 12 v to 16 v. The alternator makes up to 16 v but usually there some kind of regulator inline. If you get around 12.2 v by the fan, you can step it up with dc to ac stepup-transormer back to dc. But that would not be efficiant and draw about the same wattage. The original 12 v still needs to supply enough current to make it work. Would be better to have the right guage wire to supply the max current.
habendanio is offline
post #7 of 137 (permalink) Old 08-24-2006, 08:26 PM
insert clever title here
MattG's Avatar
There's one critical bit of data missing here about these two fans, and that's the pressure they produce. Typically, max CFM ratings are in free air, assuming no restriction. Stick the fan in a high impedance system - like the HVAC system - and you will NOT get the max CFM. When sizing fans, there's always a 'fan curve' provided, that plots airflow versus air pressure. Depending on the design of the fans, that 600CFM fan may move more air in a particular system than the 1000 CFM fan.
'05 Elise, Magnetic Blue / Biscuit / Hardtop
MattG is offline
post #8 of 137 (permalink) Old 08-25-2006, 04:14 AM
pinmagic's Avatar
Amazing -- doesn't matter what the topic, there are experts on this board. Gotta love it!
My other car is an MR2 Spyder.
My other other car is a Segway.
pinmagic is offline
post #9 of 137 (permalink) Old 08-25-2006, 05:06 AM
Chococar's Avatar
Is there any evidence that the limitation is on airflow vs. heat exchanger area/effectiveness?
Chococar is offline
post #10 of 137 (permalink) Old 08-25-2006, 05:33 AM Thread Starter
Žob's Avatar
It's both. Bottom line...some people like myself would LOVE a crap load more air coming out of the vents. So either you look at things you could actually change, or pipe dream about crap that no one would be able to.
Here's what I am thinking. Keeping the stock wiring in place to the AC control unit and going to the fan area. But instead, have a relay system in between (3 relays, 1 for each speed setting), and wire that up with the appropriate gauge wire. There is a battery post in the front portion of the car you could tap off.
Žob is offline
post #11 of 137 (permalink) Old 08-25-2006, 06:36 AM
GregD's Avatar
33 amps! That's a lot of current for a fan. With a constant 33 amps running through it, 14GA wire will get very hot (it better have some good insulation and be routed where there is cooling air around it), 12GA wire will get fairly warm, and 10GA wire will be just slightly warmer than ambient.
Is the 33 amps a continuous draw, or just a momentary spike when the fan starts up? If it's just a momentary spike, what's the continuous current?
Racing Green, Sports, Touring, Hardtop, and Starshield.
GregD is offline
post #12 of 137 (permalink) Old 08-25-2006, 06:56 AM Thread Starter
Žob's Avatar
Waiting on spec sheet. I poked around the web and found some good sizing calculators. 9awg wire would be an appropriate size for that.
Žob is offline
post #13 of 137 (permalink) Old 08-25-2006, 07:07 AM Thread Starter
Žob's Avatar
Spec sheet is getting faxed over to me. Price of new blower is 76$ !! Sweet!
Here it is
Žob is offline
post #14 of 137 (permalink) Old 08-25-2006, 07:54 AM Thread Starter
Žob's Avatar
Did some debating with a very knowledgeable tech. Here is what we've come up with. Running a new power wire from battery to front of crash structure is going to be the best bet. Getting to the positive binding under the dash royally sucks.
What I think might be easiest is to run a new wire (with loom around it) through the driver side chassis. Has anyone tried fishing something through there? I believe there is plenty of gap to fit wiring through there, but I've never tried....
Installing 3 relays. Use the power leads from the stock wiring harness for the 3 fan speeds to power the 3 relays. Connect those relays to the new resistor pack that comes with the new blower.
Žob is offline
post #15 of 137 (permalink) Old 08-25-2006, 08:01 AM
ZTEC's Avatar
I smell group buy Right now I would rather have this than a supercharger!
ZTEC is offline
post #16 of 137 (permalink) Old 08-25-2006, 08:04 AM
purveyor of lightness
darkSol's Avatar
I have one of these from my previous delSol project car:
http://www.pegasusautoracing.com/pro...asp?RecId=2771
It's cheap, provides a VERY nice stream of air, weighs almost nothing and only draws 2.6 amps.
Couldn't I just inline this somewhere for that extra oomph?
d.a..v...i....d
David Thomas Stewart - [email protected]
2005 Midnight Silver Lotus Elise (www.darksol.com)
388hp (342whp) BOE RevX 1736lbs.
darkSol is offline
post #17 of 137 (permalink) Old 08-25-2006, 08:16 AM
Moderator Extraordinaire!
tesprit's Avatar
This was my thought exactly. Anyone try something like this this yet?
tesprit is offline
post #18 of 137 (permalink) Old 08-25-2006, 08:18 AM Thread Starter
Žob's Avatar
I did some more sizing. A 4 awg wire from the battery to the front of the car will cover the amperage. 8awg from the relays to the fan will cover the other. Next stop on my list...find relays and I want to find a project box I can mount these relays in and make water tight.
Žob is offline
post #19 of 137 (permalink) Old 08-25-2006, 08:21 AM Thread Starter
Žob's Avatar
When you put in front of fan what happens? It doesn't move more air...
Žob is offline
post #20 of 137 (permalink) Old 08-25-2006, 09:15 AM
Jim-C's Avatar
I measured the stock fan ( on high) at 20 amps. I was going to add a step-up power supply / transformer. Something around 16v but couldn't find one that would handle the 20 amps.
33 amps for a fan sounds real high.
Jim-C is offline
