Anyone paint the engine cover grills? - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 11-23-2018, 10:13 AM Thread Starter
PeteB37's Avatar
I hate the dull plastic look of the grills, so I tried to plastidip them, but the plastidip won't stick to them. I'm a bit nervous about trying to paint them now, because that'll be a real mess if paint won't stick to them either.
So, anyone successfully paint them? What did you use?
PeteB37 is offline
post #2 of 4 (permalink) Old 11-23-2018, 12:11 PM
O LEE O's Avatar
check out this thread, you'll see plenty of samples
https://www.lotustalk.com/forums/f25...ne-bay-109198/
2011 Persian Blue Elise RS
O LEE O is offline
post #3 of 4 (permalink) Old 11-23-2018, 01:51 PM
Saffron Yellow is Lighter
XtinctElise's Avatar
The only right way to refinish those plastic grilles.
SEM 39103 Flexible Bumper Coater
XtinctElise is offline
post #4 of 4 (permalink) Old 11-23-2018, 03:13 PM
Nein Kinder
Glen's Avatar
@PeteB37 - Paint will stick to the plastic just fine. Prep before painting should include degreasing, then remove any flashing, fill defects with spot putty* and give everything a light sanding with 400 - 600 grit wet-or-dry sandpaper.
Most paint lines include an “adhesion promoter” specifically designed for plastics - it does just what it sounds like. Consumer lines include Rustoleum and Duplicolor. A body shop might use Dow or 3M products. Adhesion promoters are usually clear and should be the first coating on bare plastic. From there you can use a typical primer to fill any tiny imperfections and establish whatever base color you want.
A body shop would normally follow the adhesion promoter and primer with a color coat and a clear top coat. The clear coat adds resistance to abrasion and ultraviolet light. If you’re using a rattle can, you can apply a color coat that already has the sheen you want (flat, satin or gloss). You could go a step further and also apply a clear top coat (with the sheen you want) for a little more resistance to weather.
The catalyzed paint applied by a body shop (color plus clear coat) will be the most durable and last the longest in engine heat and sunlight. If you set up a job just for your part, it would probably cost $250 or so. You might find a body shop willing to work with you at a lower cost if you want a common color like black. I’d ask if you can do the prep then let them spray your part the next time they mix up some black.
Glen
* If the spot putty won’t stick to the particular type of plastic, adhesion promoter should be applied first. Then continue with filling, sanding and finally apply a second coat of adhesion promoter.
2011 Lotus Elise SC
Last edited by Glen; 11-23-2018 at 03:21 PM. Reason: add note about spot putty adhesion
Glen is offline
