Billet aluminum air vents - LotusTalk - The Lotus Cars Community
 2Likes
  • 1 Post By Varun916
  • 1 Post By David Craig
post #1 of 15 (permalink) Old 03-09-2019, 01:40 PM Thread Starter
Varun916's Avatar
I've been overhauling my interior & thought I'd give these a try!
ERDoc74 likes this.
Varun916 is offline
post #2 of 15 (permalink) Old 03-09-2019, 02:48 PM
rb26dett's Avatar
Interesting. Can u adjust the direction of air flow? And is it lighter than OEM?
rb26dett is offline
post #3 of 15 (permalink) Old 03-09-2019, 02:55 PM Thread Starter
Varun916's Avatar
Direction's adjustable, the inner ring is a vent ball that moves around. You can't quite close it off though. I didn't weigh the factory vent - that's plastic so it has the weight advantage there, but it also has more parts and is overall bigger...probably a wash.
Varun916 is offline
post #4 of 15 (permalink) Old 03-09-2019, 02:56 PM Thread Starter
Varun916's Avatar
This is the site I got it from - really high quality stuff, though with a price to match. I expect this won't be a worthwhile mod for most, but I'm a little obsessed about my interior... https://www.restomodair.com/product-...rket-ac-vents/
Varun916 is offline
post #5 of 15 (permalink) Old 03-09-2019, 03:03 PM Thread Starter
Varun916's Avatar
Another shot with a different vent design I was considering, showing how it angles: https://1drv.ms/u/s!AnQVs9VmTOTawTcCKhQAywxfa0Eh
Varun916 is offline
post #6 of 15 (permalink) Old 03-09-2019, 05:01 PM
rb26dett's Avatar
What size fits our cars?
rb26dett is offline
post #7 of 15 (permalink) Old 03-09-2019, 06:00 PM Thread Starter
Varun916's Avatar
https://www.restomodair.com/shopprod...inum-a-c-vent/ this is the one I'm using in my car - 2.5'' inner hole & 2.75'' outer. 3'' works too, it's just a matter of aesthetics. The second pic I posted was a 3'' outer. I did have to dremel a little bit off the inner ring to get these to fit though. I suspect going back to stock may not yield great results if you do expand them, unless you shim.
Varun916 is offline
post #8 of 15 (permalink) Old 03-10-2019, 06:41 AM
rb26dett's Avatar
So the 2.75 fits without dremel work? And what are the two options 1. Part only and 2. With system purchase?
rb26dett is offline
post #9 of 15 (permalink) Old 03-10-2019, 09:46 AM
Those look very nice. For my information, how do you remove the stock vents?
Thanks -
Mark
MarkB is offline
post #10 of 15 (permalink) Old 03-10-2019, 10:51 AM Thread Starter
Varun916's Avatar
They Sell AC systems and give you a discount if you buy their system - you don't want that. You want the "Part only" option.
Both the 2.75'' and 3'' require a bit of dremeling - the inner hose diameter is fine, it's just that these mount via universal compression fit, and our factory vents have four slits in the plastic - so you'll have to remove a bit to get these to fit. My carbon dash had smaller/less circular openings than the stock dash though, so you might be able to get away with a little less grinding. I feel like it'd be pretty easy to go back to stock with some shims, even if the hole became too big :-)
Varun916 is offline
post #11 of 15 (permalink) Old 03-10-2019, 10:53 AM Thread Starter
Varun916's Avatar
Thanks -
Mark
You could try pulling on them, but that's liable to rip the front vent piece from the hose piece off(ask me how I know). The best way to do it is to remove the dash trim piece(a few screws), and push it out from behind. They sit via a compression fit mechanism, similar to these ones(but not exactly the same, stock uses a four-slit compression whereas these alum vents use a universal fit).
Varun916 is offline
post #12 of 15 (permalink) Old 03-10-2019, 03:40 PM
rb26dett's Avatar
I have a carbon dash too. But Im just debating on forking out such serious cash for some vents. Thanks for all your info though.
rb26dett is offline
post #13 of 15 (permalink) Old 03-10-2019, 05:09 PM Thread Starter
Varun916's Avatar
Sure! Yeah I had second thoughts for sure, given the price but now that I have them I think they're worth it. They're really gorgeous in person, perfectly complement the carbon interior. They're also made in the USA, which I'm a sucker for.
Varun916 is offline
post #14 of 15 (permalink) Old 03-11-2019, 09:36 AM
Thanks for the information. I'll probably have the dash apart to install the garw LCD dash soon, so I can
do the vent replacement then. I've got a couple of the stock vents that are broken.
Mark
MarkB is offline
post #15 of 15 (permalink) Old 03-11-2019, 10:51 AM
David Craig's Avatar
Wow. Very nice! They look like a perfect match for the OEM aluminum look of the interior.
Varun916 likes this.
David Craig is offline
Similar Threads
Chrome finish billet aluminum engine caps rstone72 Parts For Sale 7 05-29-2014 09:01 PM
Exige/Elise Billet Aluminum Engine Cap rstone72 Parts For Sale 2 05-09-2014 03:26 PM
FS: Carbon Fiber Cowling, Center Air Vents & Side Vents Covers HKFEVER Parts For Sale 4 01-28-2014 02:21 AM
WTB: aluminum billet microMirror andy7777 Parts Wanted 0 05-26-2010 03:16 PM
