Diffuser Tuft Testing - Page 2 - LotusTalk - The Lotus Cars Community
 5Likes
post #21 of 34 (permalink) Old 01-16-2018, 10:47 AM
popcorn's Avatar
I wonder if Difflow can make and sell this one inch 90º degree bend for folks who owns his diffuser. This would be like a add on mod for existing diflow owners.
Yes you, Peewee.
popcorn is offline
post #22 of 34 (permalink) Old 01-16-2018, 11:24 AM
cyow5's Avatar
Mine cost less than $10 for the raw material, of which I had enough left over to also make vertical supports for my side skirts that extended slightly downward to improve those, too.
cyow5 is offline
post #23 of 34 (permalink) Old 01-16-2018, 04:26 PM
popcorn's Avatar
Pictures pls. Thanks.
Yes you, Peewee.
popcorn is offline
post #24 of 34 (permalink) Old 01-16-2018, 05:10 PM
kfennell's Avatar
I haven't done it yet, but lowes angle aluminum + some rivets is my plan
forkmeupscotty likes this.
kfennell is offline
post #25 of 34 (permalink) Old 01-16-2018, 05:15 PM
The Enforcer
oldmansan's Avatar
No offense to anyone, but I like parts that are actually tested in a wind tunnel. Reverie is pricey, but lately due to the exchange rate, I wouldn't hesitate to purchase from them. Unfortunately, they make little that I don't already own.
San
shay2nak and glb like this.
oldmansan is offline
post #26 of 34 (permalink) Old 01-16-2018, 05:23 PM
kfennell's Avatar
San
Since I actually use the car on the track I and many others can't really use Reverie. The cost of hitting a high curb now goes from $100-400 to well over $1k.
Plus they gave away their secret which is the block off plates anyways. Copy that and you get 90% of the effect! (not really but it is a lot)
kfennell is offline
post #27 of 34 (permalink) Old 01-16-2018, 05:49 PM
The Enforcer
oldmansan's Avatar
I can't disagree with you. My front splitter or rear diffuser being destroyed would hurt my feelings and would be pricey to replace. Both of those I bought used and they were still expensive.
There are other parts not susceptible I've picked up (all used). Even used Reverie is expensive. Kind of like Penske. I really need to find a replacement for Photobucket.
San
post #28 of 34 (permalink) Old 01-16-2018, 05:52 PM
kfennell's Avatar
San
I was going to ask what else they make that is important, then I remembered that I have their wing that I bought through BOE. Which is tested etc. God I hope I don't ever hit that on something on the track!
Since all the Aero people are in here, Could I make side extensions to my splitter and have a big end plate that goes up to a 1' piece of aerofoil/wing that connects back to my fender? Would that be productive? Would it be better if the blade was boxed off on both sides?
kfennell is offline
post #29 of 34 (permalink) Old 01-16-2018, 06:47 PM
titaniumdave's Avatar
Nice work, cool to see real world effect of changes.
2006 Elise with BOE 400 supercharger and some aero mods, CRF floating oversized rotors, MCS single adjust coil overs, CRF exhaust, CRF sway bar w/adjustable link, mono-ball pivots, machined steer arms, baffled oil pan, CRF titanium toe link brace, hardened motor mounts, Ethos wheels w/Yoko slicks
titaniumdave is offline
post #30 of 34 (permalink) Old 01-16-2018, 08:24 PM Thread Starter
jdawson's Avatar
Should we break out splitter, diffuser and wing topics into separate threads? Not trying to discourage discussion, but might be better to keep things organized by major aero feature.
2006 Lotus Elise
jdawson is offline
post #31 of 34 (permalink) Old 01-17-2018, 02:54 AM
cyow5's Avatar
See post #8 in this thread
cyow5 is offline
post #32 of 34 (permalink) Old 01-17-2018, 02:56 AM
cyow5's Avatar
San
I do it almost entirely for warm fuzzies. Judging by how unstable the car got when the side skirt came loose one time or when the splitter shifted a half an inch when I hit something at 100mph, these devices absolutely do something though
cyow5 is offline
post #33 of 34 (permalink) Old 01-17-2018, 05:17 AM
eldonz's Avatar
Reverie stuff is about the closest we are going to get to tested aero pieces. Unfortunately, testing aero pieces that are below the axle line is not very effective in a static floor wind tunnel. You can generate some numbers but the data may or may not be relevant. To actually perform real world testing, you need a moving ground plane under the vehicle. For those of you who do not know what that is, check out this web site: Windshear, Inc. Wind Tunnel - 180-MPH Rolling-Road Wind Tunnel. I've given Cyow5 a tour of the facility that I do consulting at so he knows what I have access to. We have all kinds of cars come through our tunnel from open wheel Indy cars to IMSA prototypes and GTs to NASCAR to production cars. Testing at the tunnel is very expensive, around $4000/hr, and also has a very steep learning curve.
So, the best way for mortals to test is what you saw at the beginning of this thread. Now a couple of improvements to this type of testing is to use cloth style fly fishing line instead of yarn. Yarn works but has the draw back that it is heavy and large thus not as sensitive as it could be. One good thing about yarn is that it will fray which helps show turbulent air flow. Make sure that your recording device is well down stream from what you are recording.
Other than that, if we could ever get enough of us to pool our resources, we could always put a car in the tunnel and do some real testing!
Later,
Eldon
eldonz is offline
post #34 of 34 (permalink) Old 01-17-2018, 01:13 PM
eldonz's Avatar
Kevin,
Did a little checking on side plates for wings. You want to run the plates about 2" above the highest point on the wing, usually the trailing edge. Not much more than 1" in front of the leading edge so you don't disrupt the air flow. Don't need to go much more than 2" behind the trailing edge. Now, going down is where you can gain the most. If you can, run it all the way to the body work. The only caution here is to watch the air flow from the body. You might have to open the leading edge as it approaches the body of the car. Take a look at the side plates Lotus did for the 2010+ Exiges and that should give you an idea of what I'm referring to.
Later,
Eldon
eldonz is offline
