Engine cover alignment question - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By kfennell
post #1 of 5 (permalink) Old 04-11-2019, 07:16 AM Thread Starter
Smoky's Avatar
I am about to attempt to reshim my engine cover at the hinges in order to make it more even, and level. You can see in the pic that it seems to sag on the right side while alignment is perfect on the left.
Before I go unbolting things and making it worse is there anything else I can try to correct this? Or is it all about the shims?
Thanks
-Smoky
Smoky is offline
post #2 of 5 (permalink) Old 04-11-2019, 07:53 AM
kfennell's Avatar
There are two adjustments possible. At the shims and at the screws with the rubber bumpers. Might see what you can accomplish by shortening the drivers side screw a little.
Smoky likes this.
kfennell is offline
post #3 of 5 (permalink) Old 04-11-2019, 10:28 AM Thread Starter
Smoky's Avatar
Thanks!
Well it turned out to be easier than I thought. "After" pic attached.
What I did was to shorten both screws in the rear corners to pull them out of the "shut" equation. Then I shortened the main catch to the point where it no longer latches and then went a tad longer until I got a strong latching and clean releasing action (involves some centering of the main latch).
At this point nothing had changed. So I moved to the right-side hinge.
When you loosen the two bolts on this hinge, the engine cover will want to slide toward the clam. It won't make contact but to avoid stressing the other hinge connection and just to be safe you should fold and stuff a wash sponge between the cover and clam so the sponge is fully supporting the clam when it comes loose. Also, in my case, "centered" on this hinge meant "all the way rear", so it was easy for me to keep track of the original position. YMMV
I loosened, but didn't remove, the two bolts then slid the shim into place, keeping everything straight and even as I tighten the two bolts back down. I ended up needing two shims (P/N A122B0199F). It is now symmetrical, which is what I was after. "Flush" may not be possible, or I think one might need longer screws for the hinge... and maybe I'll tackle that one day but right now I am totally happy with "even", "level" and "symmetrical".
Then I went back and lengthened the rear corner screws (the ones with the rubber cap) until tapping on each corner when shut not longer caused any kind of rattle.
Only thing I wish now is to get a more "shut" engine cover. The rear of the cover feels like it sits a tad bit high. But I if I compress the spring any more than it is then for some reason it does not latch. I guess it's not a huge deal but I know I've seen cleaner shut lines on these engine covers on other cars.
-Smoky
Smoky is offline
post #4 of 5 (permalink) Old 04-11-2019, 11:33 AM
kfennell's Avatar
Originally Posted by Smoky View Post
Thanks!
There is probably some play in where the latch assembly bolts to the clam. I think it is all through bolted to the trunk IIRC, maybe you can pull it down.
kfennell is offline
post #5 of 5 (permalink) Old 04-11-2019, 11:46 AM Thread Starter
Smoky's Avatar
Thanks!
That was also my first thought but right now the spring is tightened down such that if I compress it any more then it will no longer latch. I don't know why, though. Seems like it should still have enough compression to latch.
-Smoky
Smoky is offline
Similar Threads
Exige acrylic engine lid cover - suggestions for new engine cover iranitehrani Lotus Exige 2 08-14-2017 06:59 PM
CF: Engine Spark Plug Cover & Injector Cover HKFEVER General Discussion (Lotus related) 15 08-14-2012 11:31 AM
05 CO elise rear clam, roll bar cover, engine cover Travis Chaney Parts For Sale 7 02-13-2012 09:31 PM
WTB: Spark plug cover, Intake cover, battery cover mikepal Parts Wanted 13 03-17-2011 08:11 PM
Reverie engine cover (intake cover) Stale_Hotdog Parts For Sale 7 08-29-2009 05:13 PM
