How To: Exige V6 Side Mirrors - Page 6 - LotusTalk - The Lotus Cars Community
 1Likes
post #101 of 126 (permalink) Old 05-19-2015, 01:36 PM
here is the updated mirrors in body color, just did the passenger side today
bofusric is offline
post #102 of 126 (permalink) Old 05-19-2015, 06:46 PM
LotusCC's Avatar
Nice. How do you like the look?
05 Arctic Silver UK:
12 Wrangler JKU
LotusCC is offline
post #103 of 126 (permalink) Old 05-20-2015, 05:25 AM
Love it! Another reason to look back as I walk away after parking. The new style mirrors sit higher, stick out slightly, and more forward than old style. Does help more with blind spots but not perfect.
bofusric is offline
post #104 of 126 (permalink) Old 05-20-2015, 08:41 AM
ACE51's Avatar
Nice elephant ears folks, to each their own.
SRA Champion 2011 and 2012.
My first Lotus gave me a track disease. Now working with and racing Porsche's
Rennpart.com
ACE51 is offline
post #105 of 126 (permalink) Old 08-07-2018, 11:08 AM
Doesn't look like you can get these part numbers any more. Did they update the part numbers maybe?
Ls1Rx7 is offline
post #106 of 126 (permalink) Old 08-07-2018, 11:43 AM
lt1_fd3s's Avatar
I have kept the link to this listing handy:
https://www.deroure.com/diagrams.asp...ercharger&SC=0
WNC Tour Guide - WNC Drives (click me!)
'93 Vintage Red RX-7 - NA 20B
'06 Chili Red Exige - RIP 2017.12.01
'06 Ardent Red Exige Katana2 - try this again
lt1_fd3s is offline
post #107 of 126 (permalink) Old 08-07-2018, 12:50 PM
senna's daddy's Avatar
So I was feeling exceptionally OCD, and decided to see how much weight I can take out of a set of V6 mirror mounts to compensate for the added weight of CF + resin that I'll have my friend cover them later.
Picture 1: Stock Picture 2: Removal of internal cast spruces Picture 3: Colin Chapman weight diet
senna's daddy is offline
post #108 of 126 (permalink) Old 11-04-2018, 01:36 PM
Read through the whole thread..and need to ask if there is a step by step pictoral demonstration to removing the factory mirrors? I removed the 3 stickers, i see some of the screws, but im afraid they wont come out from the tiny holes. Is there a better method? And if the screws do fall in, how do you get them out? Not understanding the magnet thing either
Beemerb0y is offline
post #109 of 126 (permalink) Old 11-04-2018, 01:57 PM
If the screws fall in you can pull the interior door panel off and reach inside to get them, it's just a bit of a pain in the ass so try not to drop one.
CloudySkys is offline
post #110 of 126 (permalink) Old 11-05-2018, 07:41 PM
what size are the three hex screws holding the mirror to the door? i can confirm the top one is a 3mm, but cant get the bottom two out with a 3, 4, or 5mm hex key
post #111 of 126 (permalink) Old 11-05-2018, 08:12 PM
Crazy05's Avatar
They should all be the same size. At least in my experience.
Currently:
2005 Lotus Elise
2015 Audi A3 Wife's car
2012 Toyota Prius C Daily Commuter
Sold:
2006 Pontiac Solstice
2003 350z Touring
2006 Eclipse GT
Crazy05 is offline
post #112 of 126 (permalink) Old 02-01-2019, 11:56 AM
kapps's Avatar
Did the design change recently? DeRoure is showing new PN's for the Exige V6 mirror parts:
A138U4013F: LH Plinth Assembly
A138U4014F: RH Plinth Assembly
There are no caps and the mirror housing is a different part number as well.
1970 Europa S2 Carnival Red
2005 Elise Krypton Green
kapps is offline
post #113 of 126 (permalink) Old 02-01-2019, 12:18 PM
TedR's Avatar
Yes, Lotus made a change to both the mirror body and the "stalk". You can still order the older v6 style that mates up to the even older mirror body. One of the internal stems on my drivers side mirror body broke. I have been going back and forth on just replacing the body or upgrading. Haven't decided yet.
TedR is offline
post #114 of 126 (permalink) Old 02-01-2019, 12:19 PM
TedR's Avatar
Oh, and I would really like to see a picture of the new style and how they attach. There is no hardware shown between the mirror body and the stalk. Looks like they may snap together?
TedR is offline
post #115 of 126 (permalink) Old 02-01-2019, 03:09 PM
kapps's Avatar
Ah good to hear. The new parts are quite a bit more $$$ especially considering the fact that you can't re-use your old mirror housings.
kapps is offline
post #116 of 126 (permalink) Old 02-04-2019, 07:44 AM
TedR's Avatar
I think you can re-use the existing mirror housings. I went ahead and ordered the new style Exige V6 stalks.
I pulled one of my existing mirror housings apart. The outer painted portion of the housing (the main piece) looks identical to what is in the parts diagram. The adjustment portion between the housing and the stalk appears to be built into the new V6 stalk. I will update this thread when I receive the new stalks.
Besides being heavy, the Elise stalks do not provide a robust mount to support the mirrors. Only one of the two plastic pins on the mirror have a screw securing it where both pins are secured in the OEM mirror application. I also notices the OEM mirror application has much longer plastic pins, and they are cut shorter when installed in the Elige applications.
TedR is offline
post #117 of 126 (permalink) Old 02-04-2019, 08:12 AM
Can someone put together a DIY step by step instructions with pics on removal and install of side view mirrors? Cant find the pdf to the old sector111 instructions as the link no longer works, and all these explanations using magnets is not making sense to me lol. Thanks i advance👍
post #118 of 126 (permalink) Old 02-14-2019, 08:25 AM
TedR's Avatar
Confirmed, the existing mirror housings can be reused. Here is the new V6 Exige mirror plinth. It comes from Lotus with both halves bonded together and with the ajustement and bellows attached.
Part numbers are A138U4013F for the left side and A138U4014F for the right side. Total, including shipping from Deroure was about £75.
Separating the mirror from the housing was a bit of a pain. It took a lot of patience, but I was able to get them apart without scratching the paint.
I included a picture of the existing mirror housing after disassembly. Once the push on star washer is pried off, the whole adjustment assembly comes apart.
The outer mirror housing is held onto the new plinth with the spring. Once I determine paint/coating on the plinth, they will just slide together and be held in place with the spring.
TedR is offline
post #119 of 126 (permalink) Old 02-15-2019, 05:18 AM
kapps's Avatar
Are the adjustment and bellows removable for painting or do they have to be masked?
kapps is offline
post #120 of 126 (permalink) Old 02-15-2019, 06:45 AM
Crazy05's Avatar
Thought I would share some pics. I am running the stock plinths again, but I may install them again in the future.
Note: The V6 Plinths do project forward so from a front 3/4 view the mirrors stick out quite a bit, but that may also be due to the mirrors still in orange...
What do you guys think?
shay2nak likes this.
Currently:
2005 Lotus Elise
Sold:
2003 350z Touring
2006 Eclipse GT
Crazy05 is offline
