New Exige Interior Retrofit into Older Elise? - Page 2 - LotusTalk - The Lotus Cars Community
 1Likes
post #21 of 26 (permalink) Old 12-16-2016, 02:52 PM
Is the price just the console or does it actually replace the shifter assembly as well? Ie. can you just by the console and directly retrofit it into an S2 Elise/Exige? If so, that's not a bad price at all!
Cheers,
Zoomby_U
Originally Posted by BritishRacingGroup View Post
For Leather/ Alcantara
Center Console with rear upper and all gaiter boots, fasteners, etc (complete): $1,136.97
Door Panel Set with inserts, fasteners etc (complete): $1,050
Optional: Matching leather door pulls: $116.46
Delivery in 6-8 weeks from order. I have one last order going in for 2016 on Monday. After that, next order is January 3rd. Please email us at [email protected] to submit an order.
Zoomby_U is offline
post #22 of 26 (permalink) Old 12-16-2016, 03:01 PM
Cheers,
Zoomby_U
This is the replacement console (cover) but it has no mechanicals. It replaces #1 and #16 with all the trim and boots as shown in the diagram below with the newer design from the Sport Elise and Exige As shown in the second picture.
BritishRacingGroup is offline
post #23 of 26 (permalink) Old 12-17-2016, 07:11 AM
Thanks, so you don't need to replace any mechanical components for the console to fit? Does it have holes for the hazard, door lock and traction control buttons? All I really want to know is if you have actually tried retro fitting in a Elise/Exige before? If so and it works, then sign me up!
Cheers,
Zoomby_U
Zoomby_U is offline
post #24 of 26 (permalink) Old 05-28-2017, 06:03 PM Thread Starter
SLKado's Avatar
Ok, so I finally got around to working on this. Photos to come later.
Door Cards:
Not a direct fit. The window switch surround is different and I think the mounting points are a bit different. Still working through that.
Center Console:
This is three pieces, the ebrake cover, the bottom shifter cover and the top shifter cover.
The ebrake cover fits perfect, but it sits high which prevents the back piece with the cigarette lighter from sitting in the correct spot
The bottom shifter cover is a bit of a disaster right now. It is cut out for the main loom to pass through the middle of the unit, but on the 05, it passes to the right side. Easy modification. The harder part is that the box around the shift mechanism prevents the piece from sitting flush on the ground (photos to follow soon)
The top shifter cover looks great, but the door lock switch connector does not match OEM. Also, I still need to source a hazard light switch, as the 05 one will not fit.
Still working on getting this all together, but I may have to switch up to one of the fancy InoKinetic shifters just to get the center console to sit flush.
2005 LRG Lotus Elise
SLKado is offline
post #25 of 26 (permalink) Old 06-03-2017, 01:47 AM
Spartacus's Avatar
Can't wait to see the update!
Spartacus is offline
post #26 of 26 (permalink) Old 07-18-2017, 02:23 AM
what about the dash? Im looking into putting a 2010 exige dash into my 2004 exige.
MIK33B is offline
