Suggestions on removing rearview mirror "nub" from windshield? - LotusTalk - The Lotus Cars Community
 1Likes
  • 1 Post By Glen
post #1 of 4 (permalink) Old 10-08-2018, 05:43 PM Thread Starter
Smoky's Avatar
So far I have tried:
a little bit of heat (afraid to use too much based on horror stories online)
fishing line (can't get beneath it at all)
fingernail polish remover (acetone, no effect after several "soakings")
Any other suggestions?
Thanks
-Smoky
Smoky is offline
post #2 of 4 (permalink) Old 10-08-2018, 08:03 PM
Nein Kinder
Glen's Avatar
@Smoky - A Google search reveals most of what you’ve tried. If you want to try heat, let the windshield heat up in the sun first. I seem to remember windshields can take about 120 F in temperature differential inside to outside. So don’t exceed that (minus a safety factor) if you heat the metal mount.
I’d try soaking a paper towel in MEK, then cover the mount and a little surrounding glass with the wet towel. Press some plastic wrap over all that to reduce evaporation and let it sit for at least an hour. You want it to still be wet when you come back to it. Cover your dash and interior parts where you might drip any liquid since MEK will definitely leave a mark or melt those materials. Once the MEK has had a chance to soak, try using a razor blade to gently pry the metal mount off the glass. Gently . . . because removing the mount usually entails breaking the glass.
Glen
Smoky likes this.
2011 Lotus Elise SC
Glen is offline
post #3 of 4 (permalink) Old 10-09-2018, 02:04 AM
PLAY-DOH's Avatar
Concentrated heat gun on the outside then just twist bracket with channel locks.
Easy as Velcro shoes
2011 Lotus Evora N/A Quartz Silver
PLAY-DOH is offline
post #4 of 4 (permalink) Old 10-09-2018, 02:33 AM Thread Starter
Smoky's Avatar
Originally Posted by Glen View Post
@Smoky - A Google search reveals most of what youve tried. If you want to try heat, let the windshield heat up in the sun first. I seem to remember windshields can take about 120 F in temperature differential inside to outside. So dont exceed that (minus a safety factor) if you heat the metal mount.
Id try soaking a paper towel in MEK, then cover the mount and a little surrounding glass with the wet towel. Press some plastic wrap over all that to reduce evaporation and let it sit for at least an hour. You want it to still be wet when you come back to it. Cover your dash and interior parts where you might drip any liquid since MEK will definitely leave a mark or melt those materials. Once the MEK has had a chance to soak, try using a razor blade to gently pry the metal mount off the glass. Gently . . . because removing the mount usually entails breaking the glass.
Glen
This sounds promising! I will give it a try.
-Smoky
Smoky is offline
