BOE Carbon Fiber Clam - Page 2 - LotusTalk - The Lotus Cars Community
 44Likes
post #21 of 168 (permalink) Old 12-23-2016, 06:57 AM
purveyor of lightness
darkSol's Avatar
Originally Posted by Lotus F1 View Post
where you get the engine lid
From Gabe a few years ago - it was a one-off - link to POST:[ https://www.lotustalk.com/forums/f92/...ml#post3359081 ]
d.a..v...i....d
David Thomas Stewart - [email protected]
2005 Midnight Silver Lotus Elise (www.darksol.com)
388hp (342whp) BOE RevX 1736lbs.
darkSol is offline
post #22 of 168 (permalink) Old 02-24-2017, 07:23 AM
darkSol's Avatar
Update: Slooooow progress.
They got all the white epoxy finish removed and applied two lightweight base filler coats to the front clam.
It still needs:
- Filler on rear
- Sanding/smoothing
- Final fit check/alignment
- Primer
- Paint
- Reassembly
One day it will be back on the road. Haven't driven it in over a year now
p.s. Headlights AND turn signals are going to be flush mounted WITHOUT gaps or rubber trim.
p.p.s. I reweighed the front clam when I was there - it's 0.2 lbs. more than it was when I dropped it off BUT that will drop again when they sand/smooth the filler
d.a..v...i....d
darkSol is offline
post #23 of 168 (permalink) Old 02-24-2017, 03:06 PM
ERDoc74's Avatar
Wish I woulda had them do the flush mount headlight/turn signal work...
2006 Graphite Grey Lotus Elise: BOE Fully built Long Rod Race motor with Solid Ferrea rockers, REV400 SC, Custom mounted BOE Front HEX.. Penske SA's , BOE CF Rear clam, Exige front clam + LOTS of other mods
ERDoc74 is offline
post #24 of 168 (permalink) Old 03-31-2017, 07:04 AM
darkSol's Avatar
Update this week - front clam is mounted and fits awesome!
Rear clam final finishing (including rear CF bandit mask) in progress...
TachItUp and ERDoc74 like this.
d.a..v...i....d
darkSol is offline
post #25 of 168 (permalink) Old 04-29-2017, 06:54 AM
darkSol's Avatar
Bandit mask update!
Looks like the "winglets" have been blended out as well
Progress is good!
Want it to look a lot like the last pic
rb26dett and ERDoc74 like this.
d.a..v...i....d
darkSol is offline
post #26 of 168 (permalink) Old 07-22-2017, 09:35 AM
darkSol's Avatar
Front is getting primer today!
Headlights and turn signals are blended flush with no trim rings
Deadline is August 4th... stay tuned!
Should weigh in at 1732 lbs. full, 1644 lbs. empty when I get her back!
John D. likes this.
d.a..v...i....d
darkSol is offline
post #27 of 168 (permalink) Old 07-22-2017, 01:16 PM
fsparv's Avatar
Originally Posted by darkSol View Post
BOE CF front clam = 15.2 lbs. (stock is 27.2 lbs.)
BOE CF rear clam = 19.7 lbs. (stock is 36.3 lbs.)
Savings of 12.0 front + 16.6 rear = 28.6 lbs.
I love the fact you post weight differences for things... I SOOO wish the vendors would do this.
2005 Lotus Elise, Starlight Black # 111 SSM NER SCCA Solo - 1835lbs up to 1.65 Lat [email protected]~55mph (asphalt) 193whp 142wtq Normally Aspirated.
fsparv is offline
post #28 of 168 (permalink) Old 07-23-2017, 10:32 PM
Sold my Exige S
+TSRAGR's Avatar
@darkSol Thanks for the updates. Is that A/C still intact? The entire HVAC, 2 quarts of coolant (IIRC), plumbing, air handler, and the recirc pump are about 36 lbs. That's an easy delete while the clams are still off! DO IT!
+TSRAGR is offline
post #29 of 168 (permalink) Old 07-24-2017, 10:37 AM
darkSol's Avatar
Sacrilege! - I am NOT losing my A/C - it's over 100 degrees here over the past two weeks WITH humidity!
d.a..v...i....d
darkSol is offline
post #30 of 168 (permalink) Old 08-03-2017, 07:35 AM
darkSol's Avatar
We have primer in the front
Rear almost complete.
And the new color will be... Tesla's Midnight Silver Metallic with copious amounts of violet & blue pearl mixed in for color shifting... The new Evora GT430 make me think several times about staying with GG... It's so much more elegant - especially with all the CF bits.
d.a..v...i....d
darkSol is offline
post #31 of 168 (permalink) Old 08-03-2017, 09:48 AM
Giantmcm's Avatar
Darksol,
I just stumbled across this thread...and love the color choice. It is similar to the Porsche Panamera graphite grey I was looking at...but I am not totally satisfied with the porsche color. Going to look into your Tesla color for sure.
Love to continue to see progress on this as you are going on.
Maverick ML8 - Other daily
Giantmcm is offline
post #32 of 168 (permalink) Old 08-03-2017, 10:00 AM
darkSol's Avatar
Thanks!
PMNG is the Tesla color code.
Pictures:
- PPG breakdown
- Will add a bunch of violet pearl
- And a twinge of blue pearl
- Difference between my stock GG and the CF side air intake...
- Finally the Midnight Silver Metallic (PMNG) will reduce that contrast so it doesn't stick out so much...
d.a..v...i....d
darkSol is offline
post #33 of 168 (permalink) Old 08-04-2017, 08:48 AM
Giantmcm's Avatar
Man is that a good looking color...just a touch darker than the OEM Graphite grey, with a little more pop of silver in it. I think that is exactly what I am looking for.
Have you seen this color yet:
It is called:
"Mighty Car Mods Squid Juice" from House of Kolor:
https://static.carthrottle.com/works...283aebd4b6.jpg
I think the Tesla color is a touch darker actually...but I am not 100% positive.
I honestly am excited to see how your color comes out. Can you take some good close up photos of the car in the sun light and out of sunlight? I want to see how the color "morphs" based on lighting on the car.
Giantmcm is offline
post #34 of 168 (permalink) Old 08-04-2017, 09:26 AM
darkSol's Avatar
It is called:
Dude are you kidding? When this thing is done it will have an entire thread of it's own.
Have. Not. Driven. Car. Since. Feb. 2016.
d.a..v...i....d
darkSol is offline
post #35 of 168 (permalink) Old 08-04-2017, 09:30 AM
Giantmcm's Avatar
So glad to hear that...
If you want to hear sadder...I have you beat still. I have not driven my car since August of 2015. It has been torn apart in my garage since October 2015, as I am doing all the work myself, and it has JUST recieved a nearly finalized rear clam on the rear end. Motor was pulled 3 weeks ago and hope to put everything back together by spring...repaint next August after all mechanical has been ironed out/finalized.
So I will be a bit envious of your finished product to my far from done product when you get yours back.
Giantmcm is offline
post #36 of 168 (permalink) Old 08-18-2017, 09:51 AM
darkSol's Avatar
Rear clam was primered this morning. Front clam back on.
Won't be long now
d.a..v...i....d
darkSol is offline
post #37 of 168 (permalink) Old 08-22-2017, 07:24 AM
darkSol's Avatar
...and it's back on the car... GETTING PAINTED on Thursday!...
d.a..v...i....d
darkSol is offline
post #38 of 168 (permalink) Old 08-22-2017, 08:41 AM
Giantmcm's Avatar
So excited for you!!! I am excited to see what it looks like when it is finished as well.
So what is the estimated weight of the vehicle after all is back on the car now? I know you have made a huge push to try and get lighter and lighter...wondering what the estimated final weight of the car will be.
Giantmcm is offline
post #39 of 168 (permalink) Old 08-22-2017, 09:42 AM
darkSol's Avatar
1644 lbs. (746 kg) : Empty (no gas, no top)
1732 lbs. (785 kg) : Full gas (full gas {14.25 gal}, no top)
1746 lbs. (792 kg) : +Poly Hardtop
1926 lbs. (873 kg) : +Driver + Clothes/Shoes (180 lbs. once I get back on my plan)
1862 lbs. (844 kg) : Drag Setup (-3/4 tank fuel, +helmet)
Considering stock 2005 LSS, non-touring Elise weighs in FULL at 1950 lbs. and the hardtop weighs 26 lbs... that's 1976 lbs. (896 kg).
My goal was to double the horsepower and take 100kg off WITH hardtop = 1755 lbs. (796kg). I've done that (if my calculations are correct)
Still have to add RevX, uprights and T45 wishbones but that's another chapter in the story...
d.a..v...i....d
darkSol is offline
post #40 of 168 (permalink) Old 08-22-2017, 09:59 AM
Giantmcm's Avatar
Nice work!!!
What did you do about suspension...or is it still OEM?
Giantmcm is offline
  LotusTalk - The Lotus Cars Community > Marketplace > Dealers/Aftermarket Suppliers Feedback
