2005 Lotus Elise with Supercharged Honda K24 $39,900 - LotusTalk - The Lotus Cars Community
 4Likes
post #1 of 25 (permalink) Old 05-09-2019, 06:56 AM Thread Starter
Elise Racer
wirewheel's Avatar
Nightfall Blue with black/charcoal interior
Only 4,000 miles, excellent overall condition
Modified when new with a supercharged Honda K24
Supercharged with an M90 supercharger
Skunk 72mm throttle body
AEM 310 LPH fuel pump
AEM fuel rail w/1000 cc injectors
Built by Prototype Racing in CA, professional and clean installation
6 speed Honda transmission from a Honda RSX
ACT heavy duty clutch
Innovative drive shafts
Custom made 4 into 1 header to a 3" stainless steel muffler
EFI Techonology X2 ECU, tunable
CAN Bus for stock Lotus dash
DRS Mil-Spec engine wire harness
Modified steering rack and steering arms
Modified rear suspension and subframe
Very quick stock looking Elise!
$39,900
Call Hayes 772-299-9788 or email [email protected]
Visit our website www.wirewheel.com
Trick Wheels likes this.
www.wirewheel.com
Member Vendor
wirewheel is offline
post #2 of 25 (permalink) Old 05-09-2019, 07:00 AM
Brandonm84's Avatar
Whatís the wheel HP?
Brandonm84 is online now
post #3 of 25 (permalink) Old 05-09-2019, 07:38 AM Thread Starter
Elise Racer
wirewheel's Avatar
Here's a video from the Car & Driver Challenge in about 2006:
This Lotus is about 6:50 on the bottom timer.
We've never had it on a dyno, but it's supposed to be about 320 HP.
Harix likes this.
www.wirewheel.com
Member Vendor
post #4 of 25 (permalink) Old 05-09-2019, 09:05 AM
Funny, this stock internal K-swapped Elise is making nearly the same power as the fully built BOE Elise.
I wish there were more Eliges for sale with K-swaps. I'm anxiously awaiting for a white Exige with a Kswap to show up.
Does this Elise have the AC fitted?
- 1300lbs, 170hp. British.
- 2100lbs, 200hp. Japanese.
- 2350lbs, 600hp. British.
- 2900lbs, 140hp. Japanese.
- 3500lbs, 280hp. Italian.
HondaCRX is offline
post #5 of 25 (permalink) Old 05-09-2019, 09:42 AM
30 percent motor will do that......
NumberSix likes this.
exigegus is online now
post #6 of 25 (permalink) Old 05-09-2019, 11:24 AM
Iphlye's Avatar
Iíve also been hoping a K swapped Exige would show up on the market. This is a straight forward and cost effective swap. I would add charge cooling for efficiency. Is the gearbox modified with a LSD? With a little effort this could put down 400hp at the wheels and be a reliable daily driver.
Iphlye is offline
post #7 of 25 (permalink) Old 05-09-2019, 12:12 PM
FrumpyBF's Avatar
The car in the video has a supercharger with the Jackson Racing logo on top. The car for sale has a different unit. Also, the car for sale is described as having a K24 swap, but the video says two liter Honda. Seems like things have changed for the car since '06.
FrumpyBF is offline
post #8 of 25 (permalink) Old 05-09-2019, 01:44 PM
kfennell's Avatar
A K24 swap is not cheap or cost effective there are a dozen examples probably on the forum and they all cost 20 grand in the end
kfennell is online now
post #9 of 25 (permalink) Old 05-09-2019, 07:00 PM
Iphlye's Avatar
Sure, if you pay someone else to do it for you...anything is expensive. Compared to other swaps, Honda gives the best bang for your buck.
Iphlye is offline
post #10 of 25 (permalink) Old 05-10-2019, 06:09 AM
It does add up, I think I was up to around 20K in my calculations, but that was for a turbo K20, and the money swung about 5-6K one way or the other depending on if i went with a built engine/trans. You could prob swap the k20 for less than 10k, but it'd be a near stock junkyard motor swap, and that's likely not worth it for a little over 200whp.
But I have about 14K in reciepts for everything related to my basic Rev400 setup without a built block or trans or HEX front mount... so figure built trans and engine would push this option well over 20K. For that money I'd rather have the Honda motor.
In fact my plan initially was to sell off all of the Rev400 equipment to partially fund a Turbo K20, but I think I'm just going to save up for an Ariel Atom instead.
Ls1Rx7 is online now
post #11 of 25 (permalink) Old 05-10-2019, 06:29 AM
Curious - thoughts on whether this swapped set-up (if done right) with modified everything (steer rack, suspension etc) is going to generally be (considered) more or less reliable than a comparable Rev400 set-up? If things break on this would shops be able to figure out how to fix it? This is a pretty interesting car.
onboost91 is offline
post #12 of 25 (permalink) Old 05-10-2019, 07:00 AM
Short Answer - Yes they'd be able to figure out how to fix it. In a lot of cases it would be easier for a speed shop to diagnose an issue with a Honda powered car than a modified 2ZZ car.
Long answer, what's going to break? Anything chassis suspension body related is the same Lotus specific repair process regardless of engine
Drivetrain is the same components as a Acura RSX or TSX again very common parts and lots of knowledge.
Swap parts - solid steel mounts don't usually break.. they typically work or dont, or maybe need some adjustment. The adjustment process is where things can technically get a bit hard to research, but there are plenty of other people in the world swapping K motors into everything and can help. ALso any good speed shop could also help here.
Essentially the knowledge with regards to Honda motors, tuning, electronics, hydraulics (all the smaller things people don't think of) is 1000X the available knowledge of tuning 2ZZs and that knowledge and ability is all concentrated within BOE.
So while the Rev400 kit is well engineered, if you have a problem with your Rev kit, there's essentially no one else on the planet you can go to for help other than one shop.
onboost91 likes this.
post #13 of 25 (permalink) Old 05-10-2019, 07:20 AM
It can be done cheaper if you're resourceful. I did a Kswap using all brand new parts (except the engine) for $16k.
Either way, this Wirewheel Elise seems enticing. If it retained the AC, I'd be even more attractive.
HondaCRX is offline
post #14 of 25 (permalink) Old 05-10-2019, 08:17 AM
TedR's Avatar
Looks like this car is missing the under engine panel and the fabric on the door cards is loose. Minor issues if the car checks out mechanically. Definitely can't reproduce it for the price.
TedR is offline
post #15 of 25 (permalink) Old 05-10-2019, 09:34 AM
Iphlye's Avatar
Anyone know what has been modified with the rear suspension or subframe? To my knowledge the Elige cars accept the Honda swap without requiring any suspension or frame mods.
Iphlye is offline
post #16 of 25 (permalink) Old 05-10-2019, 01:34 PM
Butters's Avatar
Definitely no need to modify the rear subframe or suspension.
2007 SUZUKI SV650 Track bike.
Butters is offline
post #17 of 25 (permalink) Old 05-10-2019, 01:43 PM
Butters's Avatar
I’ve also been hoping a K swapped Exige would show up on the market. This is a straight forward and cost effective swap. I would add charge cooling for efficiency. Is the gearbox modified with a LSD? With a little effort this could put down 400hp at the wheels and be a reliable daily driver.
I have a white Exige that I swapped an MPx90 supercharged K24 into. It's beastly. I've also fitted BOE's A2W front HEX with a chargecooler integrated into the manifold. Neat, but expensive. This Elise, if well sorted, is worth a lot more than what they're asking. Sure, you could get all the hard parts for cheaper but the time to integrate it all is not insignificant.
Not sure I'd ever sell mine. If I did, I'd be asking close to $50,000 which would be a No Go for most people, anyway.
All that to say, GLWS!
Butters is offline
post #18 of 25 (permalink) Old 05-10-2019, 02:45 PM
Iphlye's Avatar
Thanks Butters, Iíve seen yours on the forum. I didnít think there was any need to modify the rear, so Iím curious whatís been done to this one and why.
Iphlye is offline
post #19 of 25 (permalink) Old 05-10-2019, 04:23 PM
Will this car pass inspection or is it track car only after the k swap?
jcdeng is online now
post #20 of 25 (permalink) Old 05-11-2019, 08:04 AM
it would likely not pass emissions because 2x efi is not odb2. it is a stand alone ECU
lotus90 is offline
  LotusTalk - The Lotus Cars Community > Marketplace > Lotus Cars For Sale
Similar Threads
2005 Lotus Elise w/ Honda K24 Swap Ryno Lotus Cars For Sale 9 08-16-2018 04:44 AM
Lotus Elise w Honda/K24 swap AC wiring questions Deezel A/C, Heating and Ventilation 0 04-18-2018 10:03 AM
22k Miles 2006 Elise - 400+ hp Honda K24 Swapped WhatsADSM Lotus Cars For Sale 16 09-26-2014 05:27 PM
k24 build [was 2ZZ Motor Build [was K24 turbo build]] MNlotus Powertrain (Engine, Transmission, etc) 127 08-11-2013 08:51 AM
S1 with Honda K24 and center steering for sale cjspecial Lotus Cars For Sale 1 06-20-2007 08:58 PM
