FS: 2006 Lotus Exige Supercharged - Arctic Silver - LotusTalk - The Lotus Cars Community
post #1 of 33 (permalink) Old 06-10-2015, 11:12 AM Thread Starter
Kazi's Avatar
2006 Lotus Exige Supercharged VIN: SCCPC11186HL81933
47,1xx miles
PRICE: $44k (open to any offers as well!)
Clean title in hand
Near Raleigh, NC
Engine:
07 Lotus Exige S/C (recently rebuilt due to worn bearing, good to go for a long time)
RLS intercooler with gold foil AL heatshield, carbon fiber 3 point shroud, light weight tubes and side scoop ducts
Radium surge tank mounted in the trunk
Intake cams replaced at 41k miles
Wider mesh installed on factory side scoops
Cup intake
KoldFire 270 Tune
Upgraded clutch (ACT)
Lightened flywheel
Gpan V2 Baffled Oil Pan
Custom clutch-pedal stop (limits throw of clutch pedal, 5 min to put in or remove)
Oil line recall completed
Forged radiator
Engine mount inserts (provides a light body massage at stop lights)
Taller 6th gear
Catch Cans (Saikou)
BRAKES:
Carbotech XP12/10 Pads
BOE Stainless pistons up front
Titanium shims all around
SS brake lines
SUSPENSION
Half link kit
Nitron singles 24 levels of adjustment - Medium springs
V2 control arms
OTHER
08 Exige full mohawk roof
15/16" Rotas wrapped in R888s | 205 Front and 245 Rear (Rear right wheel got curb rashed, this was fixed and re-sprayed)
DBW adjustable pedals. Customize the position to make heal toe easy
New Schroth 4 point harnesses installed on both seats
Fire extinguisher on the passanger side
Carbon Fiber front lip with plinth removed (looks to be 100% carbon fiber, not fiberglass composite)
Carbon Fiber center console
AC resistor pack replaced, and relocated to avoid future corrosion
HID headlight kit (driving at night is no problem)
Backup camera
Clarion stereo with bluetooth & ipod hook up
Lightweight battery (oddessy style with Sector mount & cut-off)
StarShield (recently replaced on front and rear clam)
Has soft-top mounting hardware installed in clam
Harness bar camera mount
RLS wide view side mirrors
Trunk lid was replaced. Original one had an incident with a garage door. Most of the rear clam was re-sprayed to match, xpel installed afterwards
Sprayed with Nano Skin paint sealer twice while in my care
I am the 4th owner, bought the car at 41k miles. I have done 5 track days and added about 6k miles. The rocker panel star-shield needs replaced, I am going to schedule replacement this month. I'll post newer pictures when this is done.
Here is a thread detailing some of the changes I made: https://www.lotustalk.com/forums/f157...-build-215721/
This is a great street or track car. Whenever I went to the track I would adjust the suspension to be stiffer, then soften it before heading home. I've taken it for a weekend cruise on many mountain and back country roads. Brake pads are amazing on track and very street able. They only have a little squeal at slow stops, warm up with one or two quick stops.
I wasn't expecting to sell it any time soon, work is ramping up in pace and will be taking a lot more of my time over the next few years. It is going to sit around more than I would like.
If you want to ask a question but can't use the PM system, you can contact me here: paperthinportal at gmail com
Sound of supercharger when going all out (stock exhaust is now back on the car, at the time of video it had the BOE ST):
Kazi is offline
post #2 of 33 (permalink) Old 06-10-2015, 02:33 PM
Thoroughly enjoyed the video. Very nice Exige.
If it doesn't sell before the 20th and mine doesn't sell by then either we should meet up at Cars and Coffee. Only other Lotus cars I ever see are the occasional Evoras there.
Good luck with the sale!
Sergeant is offline
post #3 of 33 (permalink) Old 06-10-2015, 02:41 PM Thread Starter
Kazi's Avatar
Thanks!
Kazi is offline
post #4 of 33 (permalink) Old 06-10-2015, 03:28 PM
CUFisherman's Avatar
Car looks really good!
CUFisherman is offline
post #5 of 33 (permalink) Old 06-11-2015, 12:41 PM
carphoria's Avatar
Great looking Exige
2006 Exige KoldFire270 Bought in 2010 - Sold in 2014 - Bought again in 2018
Other Toys SOLD
2006 Elise "Toothless" FIRE=TOTAL LOSS
carphoria is online now
post #6 of 33 (permalink) Old 06-11-2015, 08:49 PM
Great looking Exige. Anyone with knowledge on the topic know if this '06 would be road-legal in CA with the '07 supercharged motor?
Elise_Noodle is offline
post #7 of 33 (permalink) Old 06-11-2015, 11:59 PM
carphoria's Avatar
I owned this car during the retrofit, living in Northern CA. Passed smog, for me.
Now importing it back , it would need to go through CHP, but it SHOULD be fine.
Other Toys SOLD
post #8 of 33 (permalink) Old 06-12-2015, 06:30 AM
Technically no, but I never had any issues given the fact that the car is so uncommon.
Nessal is offline
post #9 of 33 (permalink) Old 06-12-2015, 06:53 AM Thread Starter
Kazi's Avatar
I haven't touched the tune, so emissions should be the same as when carphoria owned it.
Kazi is offline
post #10 of 33 (permalink) Old 06-17-2015, 05:42 AM Thread Starter
Kazi's Avatar
Added vin: SCCPC11186HL81933
Kazi is offline
post #11 of 33 (permalink) Old 06-17-2015, 06:33 AM
The Kokdfire 270 tune isn't emissions legal however.
I also run the Kokdfire tune and have to flash back to the stock tune when smogging. It shouldn't be a problem because most smog techs don't even know what a exige is.
Nessal is offline
post #12 of 33 (permalink) Old 06-17-2015, 07:36 AM Thread Starter
Kazi's Avatar
Ah interesting. I was able to pass WA emissions through the OBDII port without any issues.
Kazi is offline
post #13 of 33 (permalink) Old 06-17-2015, 07:58 AM
cyow5's Avatar
California smog tests require a sniffer, so you can't 'cheat'. If you are running rich, a smog test will fail you, but an OBD test is none-the-wiser. This is also a concern now that some states like NY and VA are having issues with the OBD readers, so guys around here are having to go back to a sniffer test. But, assuming yours has a cat, it is a simple matter to take care of
cyow5 is offline
post #14 of 33 (permalink) Old 06-17-2015, 04:40 PM
California changed their smog test a few months back, it's strictly ob2 testing for years 2000+ cars
sirnonz is offline
post #15 of 33 (permalink) Old 06-17-2015, 06:29 PM
The Enforcer
oldmansan's Avatar
Where are you getting this information? I just checked the DMV site and it still says biannual smog checks.
https://www.dmv.ca.gov/portal/dmv/?1...smogfaq#BM2535
San
oldmansan is offline
post #16 of 33 (permalink) Old 06-17-2015, 06:33 PM
San
You still have to smog every 2 years but it's via obd2 scan and visual.
http://www.arb.ca.gov/msprog/smogche...bd_only_im.pdf
sirnonz is offline
post #17 of 33 (permalink) Old 06-17-2015, 11:15 PM
EddieA's Avatar
Same here, except I drop in a standard ECU.
My Koldfire fails in CA as it doesn't set the 2 O2 ready states, and CA only allows 1 state to be not ready. 2 not ready is an immediate fail.
Cheers.
2007 Exige S. Phantom Black/Black. KoldFire 270 SC.
1993 3000GT VR4. Green, not quite BRG, but close.
1988 Fiero GT. Red. RIP.
EddieA is online now
post #18 of 33 (permalink) Old 06-21-2015, 06:36 AM Thread Starter
Kazi's Avatar
Price reduced. Now closer to other listings I've found.
Kazi is offline
post #19 of 33 (permalink) Old 06-21-2015, 07:37 PM
ToddSanDiego's Avatar
I smog 2-5 cars in California weekly. 2000+ smog is tested through the obd2 port, not a sniffer test. During the test, the smog machine asks if the car is turbo/supercharged. If the monitors are complete, the car could pass smog if the visual inspection was overlooked which is very possible because most smog techs are not familiar with a lotus Elise/exige. As far as bringing a car from out of state, that does not have to be done through chp. A vin verification can be done at the DMV. The vin verification will consist of verifying the vin on the dash, door, and federal/California smog sticker under the engine hatch. A DMV inspector will most likely overlook any turbo/supercharger as they just try to get as many vin verifications as possible.
To my point, CA smog is possible. Good luck with your sale. Nice looking car.
Edit: I have no personal experience with the tune on this car. I can not say one way or another if monitors are/can be set with this tune or another.
2005 Nightfall Blue Lotus Elise with ACT LE1-XTSS
ToddSanDiego is offline
post #20 of 33 (permalink) Old 06-22-2015, 08:57 PM
chiarov's Avatar
Beautiful car! If I didn't already have an Elise I would buy this.
I just can't justify switching from an Elise to an Exige when I know that I'm not driving the Elise to it's limits yet (based on laptimes at my local tracks compared to the "fast" Elise drivers.)
2012 Porsche 991.1S white
2014 Audi Q5 3.0T scuba blue
chiarov is online now
  LotusTalk - The Lotus Cars Community > Marketplace > Lotus Cars For Sale
