Change in suspension settings from track to AX - LotusTalk - The Lotus Cars Community
post #1 of 5 (permalink) Old 12-05-2015, 05:56 PM Thread Starter
kfennell's Avatar
I am doing my first autocross tomorrow after putting on the DA Penske shocks.
I have the car setup for a relatively slow and very bumpy track right now, tomorrow's autocross is on a pretty flat lot, but it is typically very slippery, especially if you have to go in the morning.
I am starting with +2 compression all around and -2 rebound on the front as a change, is that enough extra compression? Any other thoughts?
Thanks!
kfennell is online now
post #2 of 5 (permalink) Old 12-05-2015, 06:43 PM
Gunpilot's Avatar
Not being an ass but its the day before AX. At this point you are in experimentation mode. Try what you have. Take notes. Make corrections. Take notes. Find what works for you.
Also you may want to email Fred Zust. He may be able to fill in some more blanks.
2012 Evora 2+0 IPS.
2007 Exige mental track toy.
2005 Elise.
1982 Brunette.
"CHARLIE DON'T SURF"
Gunpilot is offline
post #3 of 5 (permalink) Old 12-05-2015, 06:44 PM
Vulcan Grey's Avatar
In general, you'll want less rebound damping for a bumpy surface. Too much rebound damping will not allow the tires to follow the surface of the road, and will cause the tires to skip over the bumps.
Travis
Vulcan Grey Esprit 89 SE
Vulcan Grey is offline
post #4 of 5 (permalink) Old 12-06-2015, 04:34 AM
because racecar
dallasreed's Avatar
This
really changes aren't going to do you any good until you've drove it and know how it feels
I would mess with the sway bar first (Assuming you have one) until that is on the under steer side of neutral or neutral
Then
I would only mess with rebound until you get things feeling very neutral.
Think of compression as a fine adjustment after that
Assumes you like a neutral car. Bit on the side of under steer may be easier / and thus faster for you
Ymmv
dallasreed is offline
post #5 of 5 (permalink) Old 12-19-2015, 04:27 PM
jdawson's Avatar
Originally Posted by dallasreed View Post
This
Then
Ymmv
Agreed about starting where you are now, taking notes and making changes. Also agree about making bar changes early on.
However, I have found both rebound and compression to be very effective at inducing significant handling changes. With my S2000, rebound was my main adjustment knob. With my Elise, I have used both rebound and compression. Lately (after a BWR revalve) I have found compression to be more effective when making changes that don't cause cross talk.
So, my advice is to try out the full adjustment range of both compression and rebound.
2006 Lotus Elise
jdawson is offline
