Definitive best size wheel and tire thread for Exige/Elise - Page 6 - LotusTalk - The Lotus Cars Community
 21Likes
post #101 of 283 (permalink) Old 10-06-2015, 06:29 PM Thread Starter
ConeKilla's Avatar
Originally Posted by dougrobling View Post
I have 17x9's with 38mm offset on the rear of my Elise with no issues.
I have run both 245 (street) and 255 (AutoX) tires with only minimal rubbing on the inside.
I use the same size wheel in the back for both, but drop from a 16x7 street setup with 205's, to a 15x8 with 225's for AutoX. (Both 30mm offset)
I had no rubbing in the front at all, even before the Penskes.
But now that I have installed the BWR D/A shocks with springs that are much stiffer that the originals, I am considering letting them "hang out"
I fear for the life of my clams, but noticed several vettes running setups with tires sticking outside the fenders and not really any more clearance than I have......
hmm thanks for the info!
ConeKilla is offline
post #102 of 283 (permalink) Old 10-12-2015, 08:19 AM Thread Starter
ConeKilla's Avatar
Frustrating weekend at Auto-x. My laps feel so much faster than they are, I get the time slip and im so disappointed. To the topic though, I am running LSS wheels, Rs3 tires on the front and AD08's in the rear. Brakes have seen better days, but those could just be excuses.
Results, http://www.renoscca.org/results/solo...nd14Class.html
(car 23, Zach, Exige) I just couldent catch those guys. Round 15 wasnt much better.
post #103 of 283 (permalink) Old 10-12-2015, 08:26 AM
because racecar
dallasreed's Avatar
Mine hang out and I've had the clam rubbing the tires and had to cut more. And again after some more lowering. No damage there.
What did do some damage was removing the wheel arch liners and rocks getting tossed up at the clam from the inside. Caused some spots of spider webbing in the paint. I bought some craft foam and glued it to the inside on the clam as makeshift liners to prevent any further.
dallasreed is offline
post #104 of 283 (permalink) Old 10-12-2015, 11:10 AM
Giantmcm's Avatar
Hey Conekilla,
How old are the tires? How well are they holding grip? Does the front push, the rear swing/break loose easy...a little more input. I know lots of people here will say that having matching tires is important...and where I agree to this in general, I also believe that with the right tire combo (regardless of matching all four), as long as pairs match it should be Ok...especially if it helps out with the way the car actually handles.
Also, keep in mind, where you may feel it is faster...slower times generally means you are over driving the course. I did my last event...annoying. First run was the fastest run HANDS down...and everything else after that, I was just pushing it way to hard and not being able to stay up with the car.
Moop likes this.
Maverick ML8 - Other daily
Giantmcm is offline
post #105 of 283 (permalink) Old 10-12-2015, 02:43 PM
because racecar
dallasreed's Avatar
No idea your skill level but get someone who is a much better driver than you to drive your car and ride passenger. That will help a lot on figuring out where things are going wrong.
Moop likes this.
post #106 of 283 (permalink) Old 10-12-2015, 07:09 PM Thread Starter
ConeKilla's Avatar
Originally Posted by Giantmcm View Post
Hey Conekilla,
The tires are new for this season. I understeer and oversteer. I used to Drift 240sx's regularly, so I have good car control when the back steps out, I drift my Exige at least once at the event (usually unintentionally). I have had formal driving lessons for work, I am not new to driving fast around cones so thats whats so frustrating, however this is my first mid engine car.
I had one of the other much faster Lotus guys (greg from GRP) ride with me, he's a pretty smart guy and said my run felt pretty solid. Aside from a bit of a step out the only thing he could really critique was trying to take a wider line into some of the corners to brake later and turn after the weight has been transferred and not while im braking.
post #107 of 283 (permalink) Old 10-14-2015, 05:21 AM
Does your car have an LSD? I've been running LSDless for the past 2 + years and find that to be my biggest issue. I have trouble keeping the power down out of corners. I've been able to drive my friend's N/A but LSD cars faster than my S/C non LSD car.
Silver_Surfer is offline
post #108 of 283 (permalink) Old 10-14-2015, 08:10 PM Thread Starter
ConeKilla's Avatar
Im not sure, ive been trying to find the markings on my transmission.
post #109 of 283 (permalink) Old 10-27-2015, 09:11 AM
user /tron
RideMooch's Avatar
Originally Posted by Silver_Surfer View Post
there was an update on @949Racing 's thread about the new wheels; apparently the ND miata fitment wheels wont fit our cars well after all. They are going to work on post-machining to get the right offset for the 17x9 rears, but will have to develop all-new 15s" for the front. They're going to work on this winter, shooting for spring release. Hope they're ready for autocross season.
~Matt
'06 CO Elise
'17 Toyota 4Runner TRD Pro, cement grey
'16 VW GTI, Wifey's ride
Past toys: '02 WRX | '06 STI | '14 Subaru BRZ
RideMooch is offline
post #110 of 283 (permalink) Old 10-27-2015, 10:23 AM
The current 15s will fit, but I think a spacer is needed, so thats cool. I'm leaning more towards wide body so now I may need 17X10, I wonder if they can make a 1 off set in 4x100 since they already make a 17X10 5lug. Stupid modding addictions.
ERDoc74 likes this.
post #111 of 283 (permalink) Old 10-27-2015, 01:55 PM
because racecar
dallasreed's Avatar
For what its worth the 17x9 ethos wheels do fit without spacer and you can stick 275s on them. Did it with r888s and a7s. Worked fine. This was with cut fenders.
post #112 of 283 (permalink) Old 10-27-2015, 05:57 PM Thread Starter
ConeKilla's Avatar
We are trying to stick with uncut fenders.. thanks for the info though. I can fit just about anything with cut fenders
I am going to order these!
Advanti Racing Storm S1 4X100, 45mm - Matte Grey for MX5ND, 17x9
They should fit with 10mm spacers or so, maybe 15mm.
275 Turbo likes this.
post #113 of 283 (permalink) Old 11-12-2015, 07:31 PM
ERDoc74's Avatar
How about a 3 off? I'll take two sets please!
ERDoc74 is offline
post #114 of 283 (permalink) Old 11-24-2015, 05:46 AM
I contacted them yesterday... no go
post #115 of 283 (permalink) Old 11-24-2015, 08:22 AM Thread Starter
ConeKilla's Avatar
The offset is most likely +45, with a 10mm spacer they should fit, you may have to get extended lugs but 17x9 with et+35 will fit according to DBG who posted pics of his elise with them.
post #116 of 283 (permalink) Old 11-24-2015, 09:26 AM
I bought over fenders for the car, so now I'm looking at 17X10s or in that neighborhood.
post #117 of 283 (permalink) Old 11-24-2015, 09:29 AM
glagola1's Avatar
What over fenders did you get? Just curious.
glagola1 is offline
post #118 of 283 (permalink) Old 11-24-2015, 09:33 AM
The ones CK Lim sells.
The ones pictured were the prototypes, the ones I ordered have been modified into 2 pieces for the rear and the fronts have been made a little wider.
I will be running a 275/40/17rear and a 245/40/15 front.
post #119 of 283 (permalink) Old 11-24-2015, 03:40 PM Thread Starter
ConeKilla's Avatar
Those are the ones I want. How much did they run you? Did you get the fiberglass ones or the carbon fiber ones?
post #120 of 283 (permalink) Old 11-24-2015, 03:48 PM
$1400 for the fenders and ouch $750 for shipping, but the shipping was cut in half cause my friend bought a set also. I think shipping for 1 set was $500ish.
EDIT: fiberglass version
