Exhaust finish panel delete in SSM? - LotusTalk - The Lotus Cars Community
post #1 of 7 (permalink) Old 11-14-2014, 11:04 AM Thread Starter
Been pouring over the rules for SP and SM and searching the forum, and I can't really tell just yet... Can you delete the exhaust finish panel to facilitate installation of non-diffuser exit exhausts (ex the BOE ST-5 exhausts or the VF exhausts)
I found the following bits that seem rather ambiguous but may allow it:
Allowing removal of heat shields in SP (could you consider the finish panel to be a heat shield?)
Allowing mods up to 1 lb to allow fitment of parts in SM
Thanks!
ubersoph is offline
post #2 of 7 (permalink) Old 11-14-2014, 11:11 AM
glagola1's Avatar
I did it and nobody seemed to mind in grid.
No but really, look at 16.1.I. It says that rear facias may be modified or replaced. Pretty straight forward IMO.
glagola1 is offline
post #3 of 7 (permalink) Old 11-14-2014, 11:18 AM
glagola1's Avatar
What I want to do is put a cover on the diffuser to block the non-utilized hole that the exhaust use to go through.
Is that legal? I need to look it up but I vaguely remember some ST rule saying that you could cover unused exhaust cut outs.
glagola1 is offline
post #4 of 7 (permalink) Old 11-14-2014, 11:23 AM
glagola1's Avatar
Well, after a quick perusal of the rules, I don't see anything that allows for a cover to be placed over that hole.
Oh well.
glagola1 is offline
post #5 of 7 (permalink) Old 11-14-2014, 11:45 AM Thread Starter
Well I'll be darned, totally looked that over. Thanks for clearing that up.
Hmm, that diffuser hole - extra cooling?
ubersoph is offline
post #6 of 7 (permalink) Old 11-14-2014, 11:59 AM Thread Starter
You know... If that cover is under 1 lb you could probably argue for the cover being okay under 16.1.P.
ubersoph is offline
post #7 of 7 (permalink) Old 11-14-2014, 12:46 PM
glagola1's Avatar
Except that it's an additive process and can indeed be argued to add a performance benefit in that it makes the diffuser slightly more effective (maybe).
glagola1 is offline
