Hoosier A7 fitments - LotusTalk - The Lotus Cars Community
post #1 of 23 (permalink) Old 03-25-2015, 12:17 PM Thread Starter
Autoxer
ABQautoxer's Avatar
Hoosier A7 fitments
I'm just now starting to spec out some tires (and probably wheels) for SSP. I'm curious who's used A7s already and can comment about fitment, especially within stock clams. I'm not willing to cut and everyone says the A7 runs quite a bit wider than the A6. I'm hoping I can make 225/245 work under my Exige clams.
07 Exige S - Chrome Orange
SCCA/PCA autoxer
ABQautoxer is offline
post #2 of 23 (permalink) Old 03-25-2015, 02:53 PM
RBH
RBH's Avatar
I just ordered the R7s and it will be here next week. The front R7 was just released as they had a few left over of the R6s. I am going to use (Wheel Spacers (.190"/ 4.8mm) )
Do it once. Do it right.
RBH is offline
post #3 of 23 (permalink) Old 03-25-2015, 03:36 PM
Tire abuser
jefrac's Avatar
Proceed with caution.... I was at the track the weekend that EricH had the issues described in this thread.
https://www.lotustalk.com/forums/f91/...ubbing-266482/
He was not able to get a 245 width R7 to work on his Exige, even with spacers. Take special note of post #6 . Phil has VERY extensive experience with the Elige. If anyone could figure out a way to make them work, Phil would. Also, his car has the power to make use of the biggest tire out there. Good luck with it!
'06 Arctic Silver Elise | Touring |Traction Control |Supercharged | ST exhaust | Nitron singles | BWR anti-sway bar | RTD brace | V2 Arms | SS brake lines | Harness bar and Schroth harnesses | sys.6.pack |shifter reinforced | Ultralite lines | cup air box | Sport inserts | DBW Pedals | TALLrails | Team Dynamics 1.2's | TOC Oil Pan | ProRad | FW Torque tune | BOE surge tank and catch can | Radium Clam Kit
jefrac is offline
post #4 of 23 (permalink) Old 03-30-2015, 03:24 PM Thread Starter
Autoxer
ABQautoxer's Avatar
Auto notification fail on my part.
Thanks for the link Jefrac, that confirms what I was thinking is that I would simply be running 205/225 in the A7. I might be able to run 225 square (15/17) but not sure I want to experiment with that quite yet.
SCCA/PCA autoxer
post #5 of 23 (permalink) Old 03-30-2015, 06:00 PM
Tire abuser
jefrac's Avatar
Post up how they work on your car and include video of your FTD's !
jefrac is offline
post #6 of 23 (permalink) Old 03-31-2015, 08:03 AM
RBH
RBH's Avatar
After seeing the 245 R7s at the shop next to the old R6s I have decided to go with P225/45ZR17 + 4.8mm wheel Spacers.
RBH is offline
post #7 of 23 (permalink) Old 03-31-2015, 08:11 AM Thread Starter
Autoxer
ABQautoxer's Avatar
It might be awhile. Had some set backs on the house I'm buying this month and so I'll be running the ES MR2 Spyder a bit longer for most events. I'll run the Exige as is for PCA (NT01s) until my budget opens back up.
SCCA/PCA autoxer
post #8 of 23 (permalink) Old 04-01-2015, 09:02 AM
RBH
RBH's Avatar
Here is a pic for visualization. The R6 245 is almost the same size as the R7 225. The R7 245 is massive.
RBH is offline
post #9 of 23 (permalink) Old 04-01-2015, 11:24 AM
glagola1's Avatar
Looks like the used tire could have benefited from a bit more neg camber.
glagola1 is offline
post #10 of 23 (permalink) Old 04-02-2015, 01:29 PM Thread Starter
Autoxer
ABQautoxer's Avatar
Awesome thanks, confirms the 225 rears for me. Anyone have pics of the new 225/45/15 A7/R7 vs the A6/R6?
SCCA/PCA autoxer
post #11 of 23 (permalink) Old 05-04-2015, 09:49 PM
Welp, I have a set of 275/35/15 and 275/35/17 A7s on their way to my tire guy. I'll be able to compare vs the A6s shortly here. On one hand, wider sounds nice. On the other hand, I'm not sure I need any more rubbing up front.
David de Regt - Bellevue, WA
codingparadox is offline
post #12 of 23 (permalink) Old 05-04-2015, 10:02 PM
Plug Whisperer
turbophil's Avatar
The 275s didn't get much of a change in width when compared to the 245 and 225s. I've already got a pallet of 275 A7s and they're real close to the old 245 A6s... As mentioned, not so with the 225s and 245s. Those two tires grew to the widest DOT spec just like BFGs did some years back... It's just a catch up game for hoosier's specs as far as I can tell...
RBH, what tire temps are you running at the track to require the use of Rs rather than As?
-Phil
turbophil is offline
post #13 of 23 (permalink) Old 05-05-2015, 04:50 AM
glagola1's Avatar
The 275s are the same size... or very close to it. Unfortunately, I can't say if they drive any differently because I used them on a different surface with a different alignment, different springs, and a different sway bar setting.
They now have 31 runs on them on a pretty abrasive surface and they are looking pretty meaty still.
Also, I wouldn't bother hoarding the A6 if you know what I mean.
glagola1 is offline
post #14 of 23 (permalink) Old 05-05-2015, 05:15 AM Thread Starter
Autoxer
ABQautoxer's Avatar
Thanks for the feedback all, keep it coming.
Matt congrats on the Blytheville win.
SCCA/PCA autoxer
post #15 of 23 (permalink) Old 05-05-2015, 05:36 AM
Gunpilot's Avatar
Just put on a set of R7's 205/45 & 245/40 and drove at Road Atlanta this weekend. Those that know my car know it sits high but has been remedied with new Nitrons (as Phil says I got rid of that Rally look!). Heights are 125F and 130R. Have 4mm spacers all the way around. Slight amount of rubbing on the rear liners, other than that they performed admirably.
2012 Evora 2+0 IPS.
2007 Exige mental track toy.
2005 Elise.
1982 Brunette.
"CHARLIE DON'T SURF"
Gunpilot is offline
post #16 of 23 (permalink) Old 05-05-2015, 05:39 AM Thread Starter
Autoxer
ABQautoxer's Avatar
Stock clams or cut/flared?
SCCA/PCA autoxer
post #17 of 23 (permalink) Old 05-05-2015, 05:43 AM
Gunpilot's Avatar
Stock.........
2012 Evora 2+0 IPS.
2005 Elise.
1982 Brunette.
Gunpilot is offline
post #18 of 23 (permalink) Old 05-05-2015, 05:48 AM Thread Starter
Autoxer
ABQautoxer's Avatar
It sounds like you are running the stock wheels and this is on the 07 Exige? I'm wondering how they would do on 8" wide front and rear. You're the exact test fitment case I've been hoping to find
SCCA/PCA autoxer
post #19 of 23 (permalink) Old 05-05-2015, 05:57 AM
Gunpilot's Avatar
Yes on stock LSS wheels. That 225 will rub in front and you wont have full movement of your wheel, I tried it. Plus you have a front rake. With up springs I made it work but you sit high and it looks like ass. You can autox with it and track but cant turn the wheel all the way L or R.
For autox Fred Zust or Glag would be your best reference. They are the pros!
2012 Evora 2+0 IPS.
2005 Elise.
1982 Brunette.
Gunpilot is offline
post #20 of 23 (permalink) Old 05-05-2015, 06:10 AM
glagola1's Avatar
Thanks, Tom. It was a really fun event and I feel like I got lucky. Everybody had coned runs with times that could win. It's amazing how much luck is involved with a win.
glagola1 is offline
