LTS Damper Dynos - LotusTalk - The Lotus Cars Community
post #1 of 13 (permalink) Old 05-25-2015, 08:54 PM Thread Starter
jdawson's Avatar
LTS Damper Dynos
Sine wave input
1.5" stroke
LTS front damper
LTS rear damper
2006 Lotus Elise
jdawson is offline
post #2 of 13 (permalink) Old 05-26-2015, 06:00 AM
glagola1's Avatar
Cool! Those are pretty heavily valved. May explain why they don't feel that great for daily driving.
glagola1 is offline
post #3 of 13 (permalink) Old 05-26-2015, 07:00 PM
How many inches per second is the valve/piston moving during, say, a slalom? I've never had a feel for that.
Sharp bump, probably pretty quickly. Big input? Any ideas?
Iain
mannix is offline
post #4 of 13 (permalink) Old 05-26-2015, 07:17 PM
eldonz's Avatar
I would try to put more of a "Nose" on the shock and try more of a digressive rate for the rest. This should give you better control for Auto-X and not make the street ride so harsh. Also, most velocities that you are going to be interested in tuning is in the 1-2 in/sec range. Anything above that are bumps in the road.
Later,
Eldon
eldonz is offline
post #5 of 13 (permalink) Old 05-26-2015, 08:47 PM Thread Starter
jdawson's Avatar
Agreed - they could use a lot of tweaking to make them useful for auto-x. BWR has me covered, as far as shocks go.
Maybe I should have explained better... the plots are just for reference. I wanted some surrogate shocks to test my dyno setup before dynoing a set of LOV Ohlins. If my setup was configured incorrectly, I'd rather break a set of my Bilsteins than someone else's Ohlins.
jdawson is offline
post #6 of 13 (permalink) Old 05-27-2015, 12:21 PM Thread Starter
jdawson's Avatar
Iain
Iain, I haven't collected data... so, everything I've read is second hand (at best). Dennis Grant has some data for 3 auto-x sites. He doesn't break it down into slaloms, sweepers or other features.
Far North Racing - Autocross Secrets
2006 Lotus Elise
jdawson is offline
post #7 of 13 (permalink) Old 05-27-2015, 01:02 PM
glagola1's Avatar
So what kind of set up do you have that you're able to dyno your own shocks? That's pretty cool.
glagola1 is offline
post #8 of 13 (permalink) Old 05-27-2015, 01:05 PM
Thanks, will check DG's stuff out. Dyno graphs are neat, but I guess it depends on what one is after, and do I care about 9"/sec? Does it ever move that fast, outside the context of the Fast and the Furious?
I just don't know. Seems to me that 2-4"/sec is the important range, but that's sheer speculation.
Iain
mannix is offline
post #9 of 13 (permalink) Old 05-27-2015, 02:18 PM Thread Starter
jdawson's Avatar
6" stroke servo hydraulic actuator, MTS controller, 1000 lb strain gage load cell, 6" stroke LVDT, home-grown data acquisition system, MATLAB (or octave) for data processing.
2006 Lotus Elise
jdawson is offline
post #10 of 13 (permalink) Old 05-27-2015, 09:11 PM Thread Starter
jdawson's Avatar
More shock dyno plots in the following thread in the Suspension subforum.
https://www.lotustalk.com/forums/f91/...9/#post4099577
2006 Lotus Elise
jdawson is offline
post #11 of 13 (permalink) Old 05-27-2015, 11:23 PM
forkmeupscotty's Avatar
I take it this is s LSS Bilstein non-adjustable 'sport' dampers, not the Bilstien single adjustable 'track pack' dampers?
2001 2JZ-GE
2008 N54B30
2008 2ZZ-GZE
2015 N63B44O1
http://www.youtube.com/forkmeupscotty
forkmeupscotty is offline
post #12 of 13 (permalink) Old 05-28-2015, 04:51 AM
Autoxer
ABQautoxer's Avatar
Correct. I think Jake used LTS because the factory manual calls the track pack the Super Sport suspension.
07 Exige S - Chrome Orange
SCCA/PCA autoxer
ABQautoxer is offline
post #13 of 13 (permalink) Old 05-28-2015, 07:02 AM Thread Starter
jdawson's Avatar
Actually, these are the base dampers that come with cars that have the 5.5" wide front wheels.
As Tom mentioned, the wording in the Lotus service documentation is a bit contradictory to the nomenclature used on LT.
For this discussion:
LTS = base, 5.5" wheels
LSS = sport, 6.5" wheels
Track = track pack, single-adjustable Bilsteins
I'll likely have a set of LSS dampers to test this summer. My car was a base model, hence the LTS damper plots.
2006 Lotus Elise
jdawson is offline
